网上搜索到如下方法,暂未验证,谨慎使用8 N8 n# s+ g, B8 N
1、VBA编程法--- Sanjay Ramaswamy
* `6 e- ~+ f7 m3 P% d; c: z' _- H/ O" \
5 W C9 b6 y) P# Q0 K* H8 `/ w8 Z0 M
" i, L Z8 V# _2 e1 v- O# Q$ W- ~& y y4 K, ^+ h0 a7 Y/ x# C1 R
用法就是新建一个空的Excel表格, 然后再VBA 编辑器里面复制下面的代码,然后add a reference to “Microsoft Excel 12.0 Object Library”。 运行即可。7 {# [, w: \3 g: }, @& S
5 P) B* M* |/ m4 s0 y. _
F; @9 N& A9 q0 Y4 p( b( Q
& K+ E- F. ]* D% q1 Q) p0 V, ZPublic Sub ExportParameters()$ M4 c1 C: H: ^+ l$ r# a+ Z
. D" E/ a" I. l- P+ i+ j5 R
- r7 j$ N Q* }) p3 R( [
% R6 d, e! W' Q# u Err.Clear
; m* X g; U2 D0 a% A2 d* G4 ]: F. _1 ^& o! K7 m3 g t
Dim oExcel As Excel.Application0 c" A& F3 _( _
; Q9 z, E q- R' E
Set oExcel = GetObject(, "Excel.Application")
" |' G8 F' o j0 g, l& n8 d6 |+ z
2 u( h% m! P, {- U# v( \ If Err <> 0 Then e7 ^% A5 A, z4 n. x+ F
, Y9 d3 k; f! N: o& ~7 `5 E
MsgBox "Excel must be running"" x* Y: z# s# h/ q
# U% R* u+ v" ^. | Exit Sub
6 f; q. p F+ B$ U4 e6 ^/ y2 ^6 `1 ?. x: L/ R" r
End If
G; f7 k+ [- D v4 |- j6 E0 L8 Q6 o; T* L
' _' N4 }4 Y3 ^4 P+ l' i( A9 \. o- Q5 |% S- r p5 o
Err.Clear( _5 ~: L& E- Q* ?
( t! ~+ d% U! e
Dim oSheet As Excel.WorkSheet
6 w1 Q9 _( ]) O r; d* l3 N; r9 j& I& q
Set oSheet = oExcel.ActiveSheet: Y3 N; a% Q4 A' m4 j
2 Q: i( t! x9 f: V
If Err <> 0 Then7 x% a3 A( K) h
, Z1 Q" E( ?# O, W
MsgBox "An empty must be active in Excel"- R5 K8 o4 g4 J/ ^9 Y- g, J
9 X) B1 x+ R* ~! {9 Q5 c
Exit Sub) T7 ]; I2 v" @) f8 p7 M1 C9 k
* w: P9 K% G; z# ]$ F8 u- Q3 t
End If" X- u5 h8 C1 |) a9 j* s
' b4 R3 b+ P8 _1 ~$ |" l; r) P
& Z( L) M( e" m* R% g# @8 E
& J8 F* W5 }/ p( R' D) G Dim oDoc As Document
3 o- R0 H1 [# L! S; @/ Z+ \: Y; K$ s/ R8 L2 D! g
Set oDoc = ThisApplication.ActiveDocument
, C6 D! u8 U" Y: j, T$ e+ M2 F- }# ]6 I0 O# ]
, }. y2 ` S# {$ V3 y! p; w; F! @6 R- p' ~1 t1 r2 K/ K
oSheet.Cells(1, 1).Value = "Name"
$ L. H! v8 [5 m
* W4 h0 s, H# U8 w0 k8 | H oSheet.Cells(1, 2).Value = "Units"; b4 E" E# E# G$ ^2 w/ R' Z
! R5 \* T$ ~- g
oSheet.Cells(1, 3).Value = "Equation"
, _0 {% j2 Z' h. ~2 W! C
. |1 z% @2 h+ M J8 y8 D oSheet.Cells(1, 4).Value = "Value (cm)"3 O" n+ B( w, Z
0 i+ g8 A3 J; f: l3 U
% n7 ~: h. ~) B# f1 ^- M% x4 D- k) S0 m0 N: Q2 s: o/ u
oSheet.Cells(1, 1).HorizontalAlignment = Excel.xlCenter
8 k$ k) D( p) ]: x+ R
; Z1 N# M0 |1 D+ g9 b# t8 I oSheet.Cells(1, 2).HorizontalAlignment = Excel.xlCenter
- J+ O: T9 g$ s" D) B( q U: n1 Y* t# q
oSheet.Cells(1, 3).HorizontalAlignment = Excel.xlCenter6 Y6 f+ r' i; O& c
- [8 `. J1 Y7 g B- g. C3 h% n
oSheet.Cells(1, 4).HorizontalAlignment = Excel.xlCenter5 G6 C+ A; @; v# C4 @5 q9 H2 _
3 |/ z6 e. Y. N* p* \8 K oSheet.Cells(1, 1).Font.Bold = True
% }1 u! \3 w S9 {
0 t2 s1 [7 l6 _! U oSheet.Cells(1, 2).Font.Bold = True# B ?& A% y4 d, x& T! Q
$ ^! {/ Z& y, G
oSheet.Cells(1, 3).Font.Bold = True5 J3 \6 t, e* x5 B
. Z4 X C6 J5 F4 ~) f
oSheet.Cells(1, 4).Font.Bold = True! d5 p0 p! ^6 g o# E& j6 z* ^: Q
: T _7 ]4 B7 \5 ]. M
0 c" N4 u% ?* ?
$ N" @. I. c7 x oSheet.Cells(3, 1).Value = "Model Parameters". r2 J/ p( Y; B1 k" } H8 i9 n
- E2 L9 K! W5 z oSheet.Cells(3, 1).Font.Bold = True
: ]0 l( K" B$ q3 ]& R% I0 b( u6 a
7 ^/ D( @7 C7 Y1 F% \2 X
( k$ p5 v9 l6 Q Dim i As Long* ^- p/ |% v# h' |* e9 B
7 e1 ?8 Y$ v9 m, q S i = 44 O2 e# b5 \" g: r6 v
2 I. [2 F& Z5 D4 H* K, V9 B4 L8 R, x
Dim oModelParam As ModelParameter
7 m3 F" e5 b; b1 Z, R# t0 c/ j( z( v+ O) n- }
For Each oModelParam In oDoc.ComponentDefinition.Parameters.ModelParameters, i) y! s+ r: T
( `& X/ `/ S3 k; X
: x+ r3 E* @' A, `- j3 |3 E: \- d) G% h& `- ~ n1 G9 K
oSheet.Cells(i, 1).Value = oModelParam.Name
3 i9 a7 l. ?9 x8 A9 q E7 f* a. P+ a7 t8 W# C2 A( U
oSheet.Cells(i, 2).Value = oModelParam.Units. s! N0 g" r2 P; [3 j, Y! L
# P3 P4 ]+ P; v+ c
oSheet.Cells(i, 3).Value = oModelParam.Expression' ^; ]0 @% J$ F% R, x# \$ M
) I4 ?# z' G$ B
oSheet.Cells(i, 4).Value = oModelParam.Value8 D {) w; {$ y3 g; P2 ]# K; H
; ?. B+ Z' v ]- J8 ~
" P' Y1 W, c5 i2 ?4 r' }% j& X1 _' |5 ^2 d2 o
i = i + 1/ \2 c4 U$ V' X; y1 w! A
" y" I+ g$ `0 O2 Q# B Next3 e* M2 F/ v5 u2 R
$ m6 w8 D! K3 k4 K, Q0 o: }: L
! |; t$ M# W- g5 w, I) m. e3 O. Y
i = i + 1
$ R4 e5 ?0 l8 p& b/ p/ S
3 G8 z7 f6 @" z O5 j oSheet.Cells(i, 1).Value = "Reference Parameters"' ?2 Q7 N) u. y# ^3 v
4 t* z/ X0 w/ j+ h. U) [1 C oSheet.Cells(i, 1).Font.Bold = True
* v( K F6 `6 l# h2 K% x4 H2 S2 n* Y3 J9 ]" d
i = i + 18 L( A: b8 i0 ?0 L7 c! {$ C
; U- {, \3 G. u9 i2 S) c j
y$ _ E0 J4 q8 l6 B5 ~) D3 w( m$ L( {" \# V9 d
Dim oRefParam As ReferenceParameter7 w8 x; \6 B& Z! M9 z
' }2 q8 P+ u8 N- K# x8 f5 p5 }5 Q For Each oRefParam In oDoc.ComponentDefinition.Parameters.ReferenceParameters [, p5 [& a J2 i$ [
# P5 J8 Q" R/ x3 Q6 M N
! Q. L( {! Q- i, k7 M9 r
$ k! z9 O+ U' `# p; S) q" ^" R$ y0 E oSheet.Cells(i, 1).Value = oRefParam.Name( i- ~* l9 E: J* x D: e! @6 M
8 r8 v: z) Y- q5 u- y( z3 f9 b oSheet.Cells(i, 2).Value = oRefParam.Units
1 N; o# l4 ~7 R! ~/ P/ a: Y5 g* c: A
oSheet.Cells(i, 3).Value = oRefParam.Expression
* Q3 I7 K# N3 f$ c6 Z# m9 F6 _5 y1 ^2 t1 v- ]0 A; ^
oSheet.Cells(i, 4).Value = oRefParam.Value+ c0 d# j9 G- |. M" _' j
% v1 C" u, }* y% d" T
; ^$ w0 X7 Y( U8 E
: l9 n. U1 M b1 N4 q% ^$ J8 S" f i = i + 16 c9 J* w) q1 S1 z/ t
# r, e1 W% c" V" { Next, A* U6 }- B: X
/ P5 G: c+ k, J; o$ \# Z
# s) C0 J0 L" {3 e' C: l5 }/ _8 l. } S
i = i + 1
$ M. U8 t# J- @( g% g5 D E# s( E/ o/ e X/ s. q
oSheet.Cells(i, 1).Value = "User Parameters"- k; o- `0 m: u
: G" I7 \* A0 [9 a8 x
oSheet.Cells(i, 1).Font.Bold = True6 v5 F: {7 T* ~8 z
& t& Y6 r9 W; a1 N
i = i + 1# H; o2 T9 g5 w K8 \
" q4 @: L/ u! J# U) N3 o. ~" b) g |. f ) X& x ^* e% e% |6 r* @; u
5 I* I" o/ K8 E0 W
Dim oUserParam As UserParameter0 ?, S1 L. p5 u' o1 f2 s4 Y
/ g) v6 r8 b! ^ H! f2 l
For Each oUserParam In oDoc.ComponentDefinition.Parameters.UserParameters( n. E$ ]7 f) V" y7 K5 ~- z
( U/ J% b+ g% f: u, `" D3 f5 u
7 G1 c. U9 F( B U# k' `$ M; k" N& q$ w& m* G
oSheet.Cells(i, 1).Value = oUserParam.Name* @' b F9 T- g, C
8 `( y. q# U1 g
oSheet.Cells(i, 2).Value = oUserParam.Units
9 f/ j) Y% r$ g; V3 h: W
$ p; C7 x+ l7 k+ t/ p oSheet.Cells(i, 3).Value = oUserParam.Expression$ }; ?1 a" N% \8 ^5 p+ n
5 C1 \; v4 T6 J7 k
oSheet.Cells(i, 4).Value = oUserParam.Value. q" L3 r8 j: a7 C& t u+ w- R, A
% X; t1 X" r1 J6 Y: ^
4 _) {- c& r8 p$ M6 |( s
' f& E1 E0 Y# `9 \8 T+ P u7 p i = i + 1
6 m' [' v, y/ p) x, Z Z/ u+ j+ ^1 a ^; F" ^& X- i& b n
Next
- U* H1 w5 z) g- H1 T1 ?, h
# F p9 _* W# U6 W' H" `, [
4 d5 X0 B! ` q9 d' U4 u9 f# h! p! t
Dim oParamTable As ParameterTable
6 v7 X5 d; E( `. O
2 r5 ~* X5 \+ i4 O+ M For Each oParamTable In oDoc.ComponentDefinition.Parameters.ParameterTables
8 r+ @" P# {/ B) r& ~+ i! ~0 q- n W" E0 c2 N( j3 k' q* J& ]" j
) x$ F( y( H6 b
0 n% q6 a% }( w3 F i = i + 1
+ I" J; B( q' o0 x% M) G. h. q+ g. L+ g8 l+ I, I* U
oSheet.Cells(i, 1).Value = "Table Parameters - " & oParamTable.FileName0 f$ W. d: f) i5 m! T! h
- z( s) @! y4 p; N, z$ W oSheet.Cells(i, 1).Font.Bold = True
, x) X' O5 @; ~6 K2 L& L5 W" z6 l. Y5 }
i = i + 1
" S6 s: Y( w: A5 J- f1 {9 F, t Z2 z+ [
6 a; s P; ~; z Z1 T3 q1 `
: ~# L. l& j) ^ Dim oTableParam As TableParameter; f1 g; Q9 E! e; M
- f/ p( T6 w+ v, ?9 m& L# [5 _, [
For Each oTableParam In oParamTable.TableParameters
. }2 I4 J& O- S
/ h% X+ R: m* B$ R
9 g$ w/ T, M8 t" E' y4 G" T5 }% d4 h
oSheet.Cells(i, 1).Value = oTableParam.Name
) V# ^3 X7 s! a" m6 W8 q& d) B+ g' e) \! D
oSheet.Cells(i, 2).Value = oTableParam.Units- r5 A. m M0 E. N
6 a \8 ~- X9 n2 w1 g; I oSheet.Cells(i, 3).Value = oTableParam.Expression0 ?: `; H; ]. i
0 Z+ X B* H' T2 y @9 w" U oSheet.Cells(i, 4).Value = oTableParam.Value0 V$ o1 j' t2 c8 Q3 V; M% U' p
+ C, S6 F2 p! i6 f* Q4 K8 }# ]3 E
$ N: m$ ~; N- ^
' D0 {0 o% K! W' ^ N- W i = i + 1
2 F! Z% n; u# A
$ {2 }+ A; e0 g& _1 \$ `3 B9 W Next
- ~6 V* O7 W$ J& f; N( m! p4 x( u* g( N+ k E8 L( `
Next, ^3 P; ?& t+ |4 ^" Y: T Z, o/ \
4 b# {$ k9 W+ ^1 V$ _8 b
7 x- O! g) _# F. C
" q# [% S7 P3 R: S3 |
Dim oDerivedParamTable As DerivedParameterTable
) H; V+ Q: E% i0 z* S+ e+ R6 H5 H- D! o- w; Y+ p7 V) n9 O
For Each oDerivedParamTable In oDoc.ComponentDefinition.Parameters.DerivedParameterTables+ q1 D2 Z: u' \+ j& e, ~
& h: R; Z7 y& k" v' v
& r) }' q0 _ v& e( U/ O( u0 U$ [9 K j, N# H0 o
i = i + 17 _: Q$ \$ R$ F$ Y' W
& N: d( h. y+ a- J% Y; T4 C4 Z* ?3 i oSheet.Cells(i, 1).Value = "Derived Parameters - " & oDerivedParamTable.ReferencedDocumentDescriptor.FullDocumentName5 c9 q7 j: h2 L3 F4 A; w* [
! S y9 l; B% h0 ~0 K( h oSheet.Cells(i, 1).Font.Bold = True& ~, L9 _. J; z9 _
3 @+ _% R5 j. K0 \: H. E, f i = i + 1
& |- g0 |: }) }. u+ j! b9 v! ]7 D: _% K, P2 m5 i: S! O' c$ S& v
. Q. N3 ?: P P& ~; o* K7 S e8 {
% P; ]6 L, t$ Q$ }9 m Dim oDerivedParam As DerivedParameter
: U" b, w, ?- {8 t9 `$ O9 S4 g2 P5 G J2 i
For Each oDerivedParam In oDerivedParamTable.DerivedParameters+ i. T& G$ F2 Z. [- |: i
9 |8 i" r* N5 _1 K( ]7 { % w- t' C, Q* U2 c+ x/ V! L
! `8 k8 j8 u% D5 o2 m' ?, s- \6 D oSheet.Cells(i, 1).Value = oDerivedParam.Name
) {9 `4 z. R. W! V; O8 `& r: l6 C, b) r. O
oSheet.Cells(i, 2).Value = oDerivedParam.Units+ c, |# `/ d- h: N. x% u5 n
! g v% Q5 d8 u oSheet.Cells(i, 3).Value = oDerivedParam.Expression
" N6 o7 l' k, E" |9 Z# y5 y" p% F8 N
1 P6 B' n5 E. Y- [! [" |# r" F% q oSheet.Cells(i, 4).Value = oDerivedParam.Value" A' Z8 G+ S- i0 ~9 ~. ?
/ ]" S/ }# x7 G6 o
- N$ E k/ M; H# P4 G, Q* Q7 G
# u/ y- ?+ q& @1 j8 B. L! g# ] i = i + 1 Q! H. c0 Y# @9 b
2 i* ?- ~7 B5 `- P
Next
4 A6 K% x# @) i$ ^& n
$ M7 j- v ^( N' H$ X( P( n( E+ `. y Next1 u6 r* l$ F! W$ S* Y
3 e6 [. {/ D/ g. R+ MEnd Sub
; n$ k' {& j, E v, C
- ~0 k4 M+ L7 k6 e
. l- X2 [* `7 ]% T$ f |
+ s0 h. x) O2 l
% ^) E3 V& O0 B* v9 K6 N
7 }+ P6 N+ r8 w' C第二个方法--- iLogic方法 , 感谢xiaodong Liang) L9 I! Z o G4 h' C1 A9 P2 u; V
a) R" B3 ?$ s: V
" H, c6 V6 S! U* K# L
5 ^: U" S! g1 W, K( W. v2 C( @; E& \
用法,新建一个test.xlsx在C盘下面,然后复制下面内容到一个规则里面。运行即可。4 k( ]3 V% z7 V' j/ K) b
, e6 A0 [9 i1 n$ U! C- z
+ M2 k* B1 G6 R1 w! l( y0 f; H! b( L& l5 a) j. Z$ f
0 e+ [) e" Y2 z5 p
7 J6 D* _" p: L, Z+ E O: I 'Open Excel7 l6 {8 P# N/ F! @! `7 P
GoExcel.Open("c:test.xlsx", "Sheet1")
0 ]2 g: P2 A9 _- P3 \5 h# I; E+ @# n' K' a
'Title of column
: z, y! q" N. K6 t! i6 R. I GoExcel.CellValue("c:test.xlsx", "Sheet1", "A1") = "Name", \" ~0 e3 W8 q+ f; N
GoExcel.CellValue("c:test.xlsx", "Sheet1", "B1") = "Units"+ B- w% E, ~9 q4 v* c
GoExcel.CellValue("c:test.xlsx", "Sheet1", "C1") = "Equation"
) b5 g% f# L2 {8 `1 f& z GoExcel.CellValue("c:test.xlsx", "Sheet1", "D1") = "Value (cm)"
4 x9 B3 ?( ~* ?
* u/ G2 h# K3 x+ \. u, A 'Model Parameters
. O X- f. O* c4 i Dim oCurrentIndex As Long = 3
( e6 r0 B- Z t$ w, Z GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex)) = "Model Parameters"
' F. R! {1 ^! V L/ N1 l0 ?* A
' }1 b7 E8 R' O$ }3 J4 _' c8 M Dim index As Long1 j& j" y5 ] v, b6 w% X8 T& O
Dim oIndexStr As String + Y, }. k' u; ~3 a4 s" |8 @
( y# M6 x# O2 L8 w
Dim oModelPs& F5 h4 e6 g# B4 S% I: ^$ i
oModelPs = ThisApplication.Activedocument.ComponentDefinition.Parameters.ModelParameters! V! T! n6 A2 S+ L
6 I" V2 R9 L9 |9 z4 i
For index = 1 To oModelPs.Count8 P- C: S; j$ D! X4 s
$ S9 a9 ^ x( F- M8 D) T% v: i7 L
. O/ _" ^( B2 p, d) J4 w oIndexStr = "A" & CStr(oCurrentIndex + index)/ v$ U; Y0 s& b* @2 c X+ e% _9 D
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oModelPs(index).Name
0 b) g# k; s+ M$ q/ Q& ^8 {
) e0 O$ j+ g8 O; t. b7 \ | oIndexStr = "B" & CStr(oCurrentIndex + index)
: \# `1 W9 Y/ {" ]4 y& S GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oModelPs(index).Units( p2 l) I! ^; N) ^! @" `+ U
& W2 }( y* T# N6 B5 W9 W- j0 g p oIndexStr = "C" & CStr(oCurrentIndex + index) * R+ K8 ~2 e4 _5 Q5 m
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oModelPs(index).Expression
+ p0 R3 M4 Q9 f3 G 8 |+ ~5 p R# Z* Y
oIndexStr = "D" & CStr(oCurrentIndex + index)
1 x; s1 K8 l& z8 m) _0 g1 F# U GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oModelPs(index).Value* {1 t9 O8 z' U7 l9 U* W- m: e
Next p. t8 ^" P4 O1 E* d
7 w7 P) J6 O0 S# I8 s5 \
'Reference Parameters
6 _* G* M3 }! f/ `0 ?+ Q; T- z! i8 roCurrentIndex = oCurrentIndex + oModelPs.Count + 13 Y6 s/ ^: e3 o( G6 m& p
GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "Reference Parameters"; f4 ~; p& N0 p( z
! N0 r8 a5 W( D6 u$ K Dim oRefPs
# \; h; |6 o! poRefPs = ThisApplication.Activedocument.ComponentDefinition.Parameters.ReferenceParameters _* x* x: K5 |- S( t5 E& l
/ a+ g, b' x `For index = 1 To oRefPs.Count% K; t4 I" t6 x
! a: ~% F2 S& I9 e oIndexStr = "A" & CStr(oCurrentIndex + index)
7 y N; R( ]3 U0 W. F5 B& q: {5 v GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oRefPs(index).Name p9 O: k$ _/ y' W* Q; S; C3 [9 B
! Z* J2 k- O0 k! `+ ] oIndexStr = "B" & CStr(oCurrentIndex + index) - t& C% {" c. E/ n4 R
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oRefPs(index).Units" z( w' e. E* Q) a+ Q+ g
; B2 S6 j1 `* t" F8 v, y oIndexStr = "C" & CStr(oCurrentIndex + index) . Z! F4 T+ y; g2 ]2 I. Z" `
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oRefPs(index).Expression1 x) w9 p% L+ @1 l5 R* L ]
C3 V4 |+ c' D' m* j! R/ H. s oIndexStr = "D" & CStr(oCurrentIndex + index)
8 ?4 k! s3 J( ?2 L0 \( b, w2 y3 D GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oRefPs(index).Value0 k9 G! q6 D1 X2 M1 ?! Q* w* j: U
Next6 \' b/ d- ?1 N+ N' o$ g
, r0 H5 _ X" l2 I0 b C: c'User Parameters
% s1 i3 [8 ~1 JoCurrentIndex = oCurrentIndex + oRefPs.Count + 1, O* k7 e6 b3 M& K3 E
GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "User Parameters"* J) ]: j4 l; o& j8 x
; C) _; |4 T4 r# D* o5 x
Dim oUserPs& E& I5 N: b6 Z8 O
oUserPs = ThisApplication.Activedocument.ComponentDefinition.Parameters.UserParameters, e+ P E! ]% Z9 c" n( i
; P+ j& q# g, O& w: T" f
For index = 1 To oUserPs.Count
4 c3 q' F9 d1 _% j5 F; x
% k+ p% y. P" ~2 l3 i oIndexStr = "A" & CStr(oCurrentIndex + index)0 ^$ \/ N! \) g: L" v* p
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oUserPs(index).Name
4 E# P3 }& W7 R- B V) P! q' h( x5 ~
oIndexStr = "B" & CStr(oCurrentIndex + index) + Q. b, y" K2 i1 |
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oUserPs(index).Units
+ Q* k7 ^1 ?. x. ~5 L+ d 0 m3 W7 y1 n3 t7 }0 u7 `
% ~ X9 [4 Z0 Q# T( ?+ h GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oUserPs(index).Expression8 C, n) n2 ^ [0 Q! Y
4 t* n: V' a/ I B oIndexStr = "D" & CStr(oCurrentIndex + index) : k; X4 @ T9 E* F: ]! u
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oUserPs(index).Value
' j; N, C7 R- W: @Next& p7 Y$ i/ l5 R
V3 ?: [/ z I/ O# j ^- |1 H a
3 g2 I+ ` p7 t! k& J
'ParameterTables# d/ @* O2 o0 w% a# f
oCurrentIndex = oCurrentIndex +oUserPs.Count + 18 o: a( o8 C# Y6 @4 y: e9 b
GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "Parameter Table"
+ O9 @% q# U: M. Z 1 g2 ~! p$ x6 q' ]! r. b
Dim oPTables
8 ^; L" u6 i5 xoPTables = ThisApplication.Activedocument.ComponentDefinition.Parameters.ParameterTables! U' Z! n# B1 I9 \
! k. d/ d7 Q2 y$ S, w, k- A" W' c
For i = 1 To oPTables.Count
4 _ e7 d( N* Q2 C; o" q \; {. o ; @* u9 C1 _ E( w8 {8 W
Dim oEachPTable
. F) F0 N9 z" e( P' r2 W; J/ b oEachPTable = oPTables(i)
$ J/ S- C4 Q/ Y( j % b; X9 c4 G0 j3 l+ @/ k, {
Dim oPTableParas
8 l- n$ l8 o6 z8 ?- l" M6 R$ f/ z oPTableParas = oEachPTable.TableParameters 0 E4 \& [) i$ I% S- c
! x$ u- q! S$ `# D. { oCurrentIndex = oCurrentIndex + 1* d! y6 }6 {# W/ ]# G- r
GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "Table Parameters - " & oEachPTable.FileName
- @& I9 g# t/ b. E7 R 1 J* R; p$ R5 p2 X
For index = 1 To oPTableParas.Count
, ]* g6 D+ c: T( m5 ~ t1 n( A: {) k! ]
Dim oEachP
) q5 y: H6 ?3 K0 j m2 i oEachP = oPTableParas(index)
. b8 {$ x6 K( a2 |: c. n, `' N! T
1 B; A8 R4 j: K0 X# O oIndexStr = "A" & CStr(index + oCurrentIndex)6 M6 V1 `. N' M% y7 w, U
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachP.Name
# q+ |: Y7 ?. ^0 {9 \+ n 0 F* ^$ E) x! d
oIndexStr = "B" & CStr(index +oCurrentIndex)
/ J0 s0 p# L( ]9 Z# e1 {3 d GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachP.Units
& \( @! G+ H) c5 V( [: l
* |6 F( y5 y- J oIndexStr = "C" & CStr(index +oCurrentIndex) ) j( k5 r/ E8 b! E$ n% R
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachP.Expression
% Y+ b% o: W: G0 Z- Y7 s 9 g1 R: G/ y- c6 A0 u. Q
oIndexStr = "D" & CStr(index + oCurrentIndex) 5 e2 ~- N+ \% ?# O# h) J
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachP.Value + i, V- J& @8 r% ]# O: V+ x
Next
' h/ Z1 o7 `; ]4 Y/ q. d0 U2 q
# \) \. ]( @: V+ l oCurrentIndex = oCurrentIndex + oPTableParas.Count
9 G* s5 O1 I5 K4 K - l6 s9 K; m: g! M/ g; ]( P( p
Next
, [! J# n+ \) n, W
6 n9 [; ? V: `# t3 y$ a'Derived Parameter Table ]( [ S3 K% X' a
oCurrentIndex = oCurrentIndex + 1/ Q! H; B# y3 S2 x6 I" V8 o
GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "Derived Parameter Table"
" l$ n$ K- F- g' @
; k! q/ ^# H6 Z$ o* z* F, Z% O Dim oDTables" \5 j! g7 F/ o2 a/ I5 Z
oDTables = ThisApplication.Activedocument.ComponentDefinition.Parameters.DerivedParameterTables
% b5 @9 g! [( t F9 O6 \3 M
$ l+ n4 B+ X& O8 V# xFor i = 1 To oDTables.Count
3 o0 o6 ?: [2 Q/ }$ k( S. l
; A( [1 b( F. z r& i+ u Dim oEachDTable3 ?- q' s V5 H8 V
oEachDTable = oDTables(i)/ R3 g: ~) q0 I5 O; w5 _* Y- y
; B, v; Y. I* x8 I1 @ Dim oDTableParas
+ L8 x( W( o# y oDTableParas = oEachDTable.DerivedParameters / e/ r! C5 J* i6 |: a
* l" A( j7 N2 b4 j; T" I
7 R8 y0 v; c3 h) G: x! T GoExcel.CellValue("c:test.xlsx", "Sheet1", "A" & CStr(oCurrentIndex) ) = "Table Parameters - " & oEachDTable.ReferencedDocumentDescriptor.FullDocumentName& l6 J$ W/ z6 X! C/ o) u, B/ C* z, M8 G
T! |! N; a o For index = 1 To oDTableParas.Count: o# {* D* [, d
3 |8 R' W# z& F6 J1 \( _
Dim oEachDP6 t2 K) D! W; w& o5 |& s
oEachDP = oDTableParas(index) N! C) [4 z& X4 X% j' v+ g
# ^1 k c& w+ o; R! C! M
oIndexStr = "A" & CStr(index + oCurrentIndex)/ y2 e+ Q0 y" O9 Y9 A6 }
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachDP.Name
1 g8 E8 V/ R3 U0 t: t0 @
& ~$ ]9 `+ `- s z oIndexStr = "B" & CStr(index +oCurrentIndex) 6 h8 z' S7 o9 [% r
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachDP.Units- D) k! ~9 Z2 z% H
' u* x5 z4 P; H9 { oIndexStr = "C" & CStr(index +oCurrentIndex) ) u/ D6 u& |7 M. T
GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachDP.Expression% p+ A6 T/ D6 D8 P) Z" O
+ D# S+ g6 P& g% \ p oIndexStr = "D" & CStr(index + oCurrentIndex)
/ j A# r' {! _9 A$ j# Y GoExcel.CellValue("c:test.xlsx", "Sheet1", oIndexStr) = oEachDP.Value 2 @$ Z. D* W1 U/ X
Next2 h; ]$ A6 s \( g* K9 r, I6 Y" n
oCurrentIndex = oCurrentIndex + oDTableParas.Count' {( s1 G, `) C6 R$ C# i, p% ^
1 s+ ~# I( |: Q& B$ p
Next
8 y; a# r5 O+ y, {
+ F* x( N% v# d
) V- {& Y9 Q+ H+ W3 v- ~4 `
& r1 x$ x. {- w; H& {6 hGoExcel.Save+ Q8 T A8 [' r3 z; @- X! I! `
GoExcel.Close |
