查看: 6025|回复: 7
浅析啤酒灌装液位的一致性
发表于 2008-11-27 12:49:18 | 显示全部楼层 |阅读模式
浅析啤酒灌装液位的一致性
发表于 2008-11-27 15:28:08 | 显示全部楼层
学习了,楼 主感恩节快乐
发表于 2008-11-27 20:28:00 | 显示全部楼层
保持液位一致是一个很麻烦的问题!
发表于 2009-2-20 13:49:01 | 显示全部楼层
一般的在线灌装液位检测设备能达到1200个分,1mm检测精度。8 o, n# S$ E+ z% I+ w
但是随着传送带的振动,瓶位置的偏差会影响检测精度。$ ]# w) j& {" C/ l3 ^# @: ]
2 J' k$ J: X- K* ]2 w8 y
最高性能和稳定性的检测设备是哪个公司的呢?
; }/ E8 k; K" z' H% c" l+ T* e5 Q. \+ i2 q5 t
' ]7 U/ E. e6 V4 c3 N. s* z
Feature  a  J" |" x0 J: p, E) o$ Q
Industry-leading high speed and high accuracy of inspection
0 I0 ~2 V9 Z& U$ P* {+ T(High speed ) Max.2000 bottles/minute
. O  B7 x' e  Z' y/ l3 [3 D4 d  W(High accuracy)±1mm (at transportation)※it may change depending on use conditions.
9 a$ w$ b8 ?1 g3 x- eAchieved overwhelming energy saving compare to same kind products.
! Q! w( \' L$ J% K, L4 p(Electric power used) 0.5KVA (1/3 of same kind products)
6 C  q% G$ c- W( c; A1 x' h$ P) F; K(Weight)  20% lighter than same kind products * L' I/ O5 _: [; K  u( s0 V: @
Amount of leakage is under 1μSv7 s% d  H( J9 ^# k
Leakage of radiation is far below the legal level.  So you don’t have to install the X-ray supervisor nor the supervised area.
, V4 @$ F) T- @
, R, y2 u5 S! [. I) Z9 S( p5 p5 p- J  R
Main specifications5 ~; p, u+ I- X' }3 u0 j! l, H
Items of inspection
6 x- t. N* j6 W; ~" IOver or shortage of the content of filled bottles6 N; u' S5 h; g3 O
9 G. i& {7 [) s8 c# @Detecting range( X$ u" F& h1 U+ B
The travelling height at the center of sensor; 65~265mm from the bottom of bottles.
* z: `6 F3 o  q+ L; lThe range of up and down setting limit; ±7mm from the center of sensor.
; n6 ~2 g! m! Q. n# ?0 s2 _2 l. F* c
Accuracy of inspection
  J& j/ \4 b# _& _±1mm# B" C! Y' E: I6 G: O
when waving of the liquid surface is large because of  setting places and/or conveyers etc. the accuracy may deteriorate.9 [7 c! k1 B& A: M
' c2 a) T6 F4 ]% A6 H5 [6 R$ N- `Speed of inspection% }2 J- Z' X0 }4 m4 C2 z
2,000CPM Max.  Conveyer speed ; Max 150m/min.6 O3 q2 F$ B) n9 E' ]
7 u4 J' N- D  x6 zElectric power supply
& N- G8 P. V& A6 d7 p100VAC±10%, 50/60Hz. w8 }# K7 a# M1 @- `# z
$ X7 A) f# v0 r3 q# p: ^Allowable ambient temperature . @3 ~+ ^- E) A# P
0~40℃ (Dew condensation not allowable)
, R( J2 p" D2 K
5 F* ]& g1 A! A4 x6 Q: c2 }% g7 m( Z- |
Model
, @2 _# U6 {& ^- s: aLE4-50
发表于 2009-3-17 22:45:35 | 显示全部楼层
保持液位一致是一个很麻烦的问题
发表于 2014-12-15 21:16:42 | 显示全部楼层
学习一下
发表于 2015-5-24 09:38:01 | 显示全部楼层
学习一下
发表于 2021-8-13 18:12:28 | 显示全部楼层
这个是啤酒泡沫液体专用的液位传感器,了解一下
GMT+8, 2024-11-23 04:27 , Processed in 0.056075 second(s), 17 queries , Gzip On.
