大家好,有谁能帮我翻译下面这段话,是关于光学玻璃材料参数的内容5 k8 S4 K$ i, E T1 n
Code 2540 was a soda lime silicate glass based infrared transmitting,
7 A" g* t# b2 K8 fvisible absorbing optical filter. Transmission for a 2.3mm glass was 57%& N& k4 {7 h' C% F" Q& n
at 1000nm, and only ~ 20% at 900nm. $ b3 r. Q6 Q/ P
6 T: d: B, A: t+ h: n; MCode 2404 was a Soda zinc borosilicate glass sharp cut infrared
; U0 q- s/ I- p$ r' ttransmitting filter, with the visible 50% transmission edge cut at ~) i+ Q% y4 d# E/ g) b
630nm (3 mm thick glass). There is essentially no transmission below ~9 h; t8 {* B m! ]- ]5 z' C
585nm for the 3mm thickness.
1 g# h8 P! V% T" L' T* @# D, s C" B& O& G8 ]* ~/ o
We do have much of the details on these glasses in the REMIS database of6 a" A9 Q# W" `" A7 Q8 F
properties, as well as composition information from the released
X8 _ ~, B$ t& ~" }1 `& y4 Umaterial folders in the TIC vault.& t8 ]2 P4 l8 @' R0 n, b/ T
7 Q- g& C# W+ HThese were just 2 of many filter glasses that Corning sold until the- e1 L9 M- F$ Z* v
1990's. The business was sold to Kopp Glass of Pittsburgh, PA. I have a
% d! ]( B1 w" G$ ~2 j( S2 IKopp Filter Glass catalog that shows these filters have been produced by5 i% I: Y# c9 n4 m% m6 k# i; \! u- q. w
Kopp. They have their own catalog numbers for them (CS-Number 7-56 =
) M0 d% l: z0 H# [* {. W$ b1 n+ _Code 2540 & CS-Number 2-59 = Code 2404) , but they also maintain the
7 N" T- S; Y' K1 T0 uCorning glass code numbers as well for each specific filter glass. |
