查看: 3768|回复: 8
管螺纹
发表于 2008-10-22 10:19:01 | 显示全部楼层 |阅读模式
MRA Pipe Thread Design Summary; e! x7 g; v' i" @. q& x
Types and specifications of pipe threads Pg 23 f" t1 i. S. O, n
Key dimensions for NPT and NPSC Pg 37 z3 f# T% ]" j6 Q4 t, e, P
Comments on typical thread element combinations
& E3 b) {4 e, X7 X/ y& L+ LStandard NPT Tapered Thread Joints Pg 4
6 J% o- t5 I2 @! P" f6 ^Level Seal in Female NPT Pg 5
# c9 V% ?/ |( X. r* N& w! X4 v8 YStandard Male NPT in Female NPS Pg 62 Q$ P7 ]2 J# V& E
Level Seal in Female NPS Pg 7; H7 e! t9 v: y& K
Standard Dryseal Pg 8
; H2 C( e  O8 S2 D5 @9 z5 BPipe Sealant Information (note curing times)* v# F7 q0 t+ Z4 L6 D5 U
Loctite 545 Pg 9) x! Z* b& I- p. Z% j
Loctite 565 Pg 12- w2 {1 Z0 J: ]5 v
Loctite 567 Pg 15$ t& t3 U+ I1 j( F* m5 n# `
Loctite 592 Pg 18
* c3 U& h* c& SDescription of ANPT gauging practices Pg 20
发表于 2008-10-22 12:19:51 | 显示全部楼层
谢谢楼主无私
发表于 2008-11-8 15:30:15 | 显示全部楼层
大度空间~~感谢
发表于 2008-11-11 15:32:08 | 显示全部楼层
楼主大方!
* }! s, T# o8 m* [  t+ \这个是美国产品常用的管螺纹,牙型角是60度。
发表于 2008-11-24 23:57:01 | 显示全部楼层
只看该作者
谢谢楼主提供好资料!
发表于 2008-12-21 22:33:32 | 显示全部楼层
谢谢楼主提供好资料!
发表于 2009-1-7 23:12:38 | 显示全部楼层
回复 1# susanlliu 的帖子
谢谢楼主无私!!!!!!!!!
发表于 2009-5-8 10:38:41 | 显示全部楼层
Good for you
发表于 2009-5-25 15:04:06 | 显示全部楼层
thank you for you sharing
GMT+8, 2025-2-22 22:18 , Processed in 0.057927 second(s), 15 queries , Gzip On.
