所标尺寸为处理前的( X/ o* k3 a" d8 V9 P! {
5 o y6 F5 Z# N! ^# [1 m# D
美国MIL-C-5541标准 (Chemical conversion coating on Aluminium and their alloy)。+ Y3 j- F8 ~& ~. U, S. r
V$ |2 u5 B0 A1 P: Z* u3 k* D1 k
% M8 h5 j8 y; S9 UMIL-C-81706标准(Chemical conversion material for coating Aluminium & Aluminium alloy) etc. Chem-film (Alodine.)) k) z1 x2 ?- k& w: w) R2 r/ f' S
: M9 M# m- N+ Z( q. `# F) X
ASTM B-449 也有部份関係。
* l8 u: u9 ^% Q9 v/ F) [ g+ a1)化学导电氧化与alodyne是相同的处理办法。alodyne也有其导电性能。
5 l# W8 L0 x( E) f- C Z) S! I) P# W$ u) T
Chemical Films(化成皮膜)
$ U, c* i& W" R; B8 d, Z. \+ t2 P! w( _( \
Coatings for aluminum. Color can vary from colorless to golden - iridescent - brown. Materials should conform to Mil - C - 81706. Coatings shall be continuous free from powdery areas, breaks, scratches, etc.2 [! P3 Z) L. f; @1 U
4 y/ X: N' R/ o5 D5 U
MIL-C-5541E No dimensional change 。Normally yellow. Specify CLEAR if needed.
; T* ?7 A% A' `1 p+ a4 I* | Z
! M1 n( ^ ]0 s2 U4 G# G; h k, OClass 1 A 5 d. q: a6 [ K
Class 1A is used as a corrosion preventative film (unpainted) or to improve adhesion of paint finish systems.For maximum protection against corrosion for surfaces to be painted or left unpainted.
" \2 B$ p- F! Q5 f. l" C Q9 Q e+ ^: C
Class 3 * ]6 D: v' h b, n+ t" a
Class 3 is used as a corrosion preventive film for electrical and electronic applications, where low resistance contacts are required.(MAX CONDUCTIVITY)。 |
