查看: 4221|回复: 10
德国机械设备制造业联合会(VDMA)的液压密封培训教材
发表于 2008-10-4 15:51:43 | 显示全部楼层 |阅读模式
德国机械设备制造业联合会(VDMA)的液压密封培训教材,ppt格式,一共19个压缩包。目录如下:  A7 C, }0 ~! H8 N! n0 ^
Basics of Sealing Technology
+ y6 I& l- O! S$ f# I3 F9 q: `Application fields for fluid seals: ]  H3 m  p2 t) ^4 ]1 S/ [
2 o/ F+ H7 e  [9 qSeal types 8 f% R: O; v* |9 W9 Z5 v$ @
Sealing mechanism
7 ^  r" k3 H5 J4 k, q, y4 I4 Y5 ?Friction
  _: M3 R" K# ^3 dParameters influencing sealing mechanism and friction
6 M! ~) e1 e% t0 ?% A
# v, A- ~! b9 iSealing Materials
9 a7 ^/ H5 w* u* G7 pMaterial overview 6 t* E+ y) ?& }( P! ^
Thermoplastic elastomers 3 q, e0 T5 C4 \  J0 h; d
Elastomers . I, r: T- v4 G" Y0 K( |$ Z
Thermoplastics
# G9 y5 U' |. n
' [. a6 X9 [1 ?& I4 HManufacturing Processes for Seals# ~0 q; _& z1 ~
2 V' b; [8 ?1 h# C. n5 B
Processing of rubber and rubber fabrics
* ~! `. W' T# ?4 IProcessing of plastics by injection moulding
% L# `9 N+ x5 Z! n2 xProcessing of PTFE , |7 l3 A* ~, T) Y
Engineering Design Guidelines ' {  b$ ]9 C2 q' W) W, D) `% z
Introduction ) r  E/ e/ s  E5 o6 c0 p5 _9 j3 l: w
Basic function of the seal
% d( M$ v" A6 Q: vSeal assembly 8 @# v* ~! [7 ?
Sealing surfaces ) N: e; _9 g$ n) N1 [) Y
Gaps & i  J! O( L+ `# S5 I6 A; h
Wipers/scrapers
# O9 x/ n* J9 OFlow turbulences
* u" N  ]2 _: r, w1 _* }Excess pressure loads
" C/ `! c  J, {“Seal-friendly“ surfaces
5 _( ]5 H$ W) |( [6 ?# oConcentricity 1 _4 l8 I- A: W. o% W0 A) w/ u
Installation spaces for O-rings ! k1 x7 [  A$ J
Installation spaces for lip seals
8 ^% l' ^  ?. S  w6 t( b+ o  }0 HInstallation spaces for chevron packings
% C/ `7 j( s5 M" ?( S. fInstallation spaces rubber-activated coaxial seals- n* P0 |- \+ Y) R2 B
4 a( K8 m- d- t) B  U( e) wInstallation spaces for compact seals # v2 E& Y' F3 y
Installation spaces for guide tapes
5 q3 ]  R1 U9 |4 TTypical design errors involving seals
. Q# [! P7 e7 a" cFavourable design features for seal assembly& e' |* S% E& ?9 [
+ X4 N4 J' s; h+ r  b, w" nStandards
/ Y+ W% d6 ^9 CSeal Types & G3 Z1 O# U7 E7 d! T/ ?( g6 r
Hydraulic seals   d" Z$ b8 s5 O: u8 b5 c2 T
Pneumatic seals
, w0 k3 k" B1 _' h% @& ^5 i; UStatic seals ; e. v- r1 g. ]: O( j2 Y* T
Rotary seals 2 K. s1 s$ i% Q' C! O( |& a
/ _7 D5 f9 o  d% d$ K/ s: @Application Examples
$ G, p+ M/ h( y7 T" M$ k' w+ }: F, ]( KHydraulics . ?& C" W4 g! Y8 V+ z- E
Pneumatics
& `* R) N* A+ {) @9 L
8 C1 x: Z2 d' I# _! ~. J4 MFailures
9 K2 K6 N( s/ A* F0 n5 kFailure causes 4 [* W3 r+ e- G9 o+ g0 |
Failures (examples) 1 R- U5 c3 r3 U1 R4 l2 A/ f
% W# Y* c, w" ^/ A* g0 X
Company Contacts
 楼主| 发表于 2008-10-4 15:59:58 | 显示全部楼层
发表于 2008-10-4 16:35:16 | 显示全部楼层
这么多啊,支持一下LZ,辛苦你了
发表于 2008-10-4 17:23:14 | 显示全部楼层
辛苦了!支持!
发表于 2008-10-10 09:23:17 | 显示全部楼层
审阅中.......
发表于 2008-10-24 16:37:25 | 显示全部楼层
下不来啊。郁闷
发表于 2008-10-26 13:16:13 | 显示全部楼层
学学
学学学习..
发表于 2009-3-4 16:09:22 | 显示全部楼层
要这么高的下载权限啊
发表于 2009-3-5 10:00:47 | 显示全部楼层
下不了啊!!
发表于 2009-3-5 18:44:34 | 显示全部楼层
英文的,有些看不懂
GMT+8, 2024-11-28 03:27 , Processed in 0.057656 second(s), 16 queries , Gzip On.
