楼主: arter_2006
SOLIDWORKS 宏合并执行的问题
发表于 2018-11-25 11:32:35 | 显示全部楼层
就是如下的繁体字改為簡体字就是) q! s5 A; n' m* m: ]8 q, y
' n' v4 d3 ~2 Z( [' h/ P  d) S4 v2 t" d: g
  1. ' ******************************************************************************, T: W* ^' _8 _7 L+ S; a8 t
  2. ' C:\Users\admin\AppData\Local\Temp\swx8144\Macro1.swb - macro recorded on 11/22/18 by mqlu
    . A. J- a1 M, H! b' Y" A6 D. F: T6 x
  3. ' ******************************************************************************7 n$ M4 i5 R1 S0 V  y
  4. Dim swApp As Object/ W2 ?) `& ~; o3 @1 r! s0 e
  5. Dim Part As Object: B) s8 x" d  `0 ?8 L$ ?3 j
  6. Dim boolstatus As Boolean. K. `) B+ k/ r8 U- Q' G+ H+ z
  7. Dim longstatus As Long, longwarnings As Long0 ?) e9 [& b  L/ l* V
  8. 4 B5 Y, G* s& ]( k1 x+ P! r
  9. Dim SelMgr As Object
    $ x5 u. F( [  \9 c$ N) l0 }: r+ `& D+ I
  10. Dim Feature As Object
    & B8 E4 i2 @+ F  G. z
  11. Dim a As Integer4 }4 N6 r/ s$ @/ y0 k0 X+ Q% w
  12. Dim b As String
    / w; o. m4 S: Y# @$ R& T' w, a5 m
  13. Dim m As String2 k  s: G$ y- _; y, i: ], d
  14. Dim e As String  M% Y) ^! O2 T5 W! m! q
  15. Dim k As String" Q# S' P# y5 b/ r( d3 f
  16. Dim t As String
    7 p; u* P; b. {; E/ D# K6 n+ }
  17. Dim c As String8 N4 _, g9 i# f1 B/ J  D. L
  18. Dim j As Integer7 A, T8 u" T  X, m+ \
  19. Dim strmat As String
    - g3 j/ X4 m4 R( h5 D* z% c
  20. Dim tempvalue As String1 Q% \: j" d5 |/ Z4 j
  21. ! Z% b' z8 Z5 ]! m) V" z
  22. Sub main() '刪除所有配置屬性6 o# p* I1 ~4 p( e; _+ e
  23. Set swApp = Application.SldWorks5 F% T$ P1 k  i# D
  24. Set Part = swApp.ActiveDoc0 v$ f  w/ e( ^- C+ Y  k0 Y7 ^
  25. CurCFGname = Part.GetConfigurationNames
    # T: k. m( m# |/ e, Y6 O
  26. CurCFGnameCount = Part.GetConfigurationCount9 E6 N# [. r+ x7 @0 T
  27. For i = 0 To CurCFGnameCount - 10 b+ n. r- ]. T
  28.     Set CusPropMgr = Part.Extension.CustomPropertyManager(CurCFGname(i))
    5 E6 e0 i# t' g; `5 R
  29.     Vnamearr = CusPropMgr.GetNames
    - K( K8 Q+ e% B. [% S
  30.     If Not IsEmpty(Vnamearr) Then
    " o3 z) {! q* t: Z
  31.         For Each Vnamearr2 In Vnamearr) `; _  g5 N& p
  32.             bRet = Part.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)
    6 M6 I! }5 O# L0 D  A
  33.         Next$ u% a* K' U7 i5 ]* |3 i
  34.     End If" [) p- _6 K5 l; M- K
  35. Next' J+ v7 ^; _) g! N6 U6 @
  36. Call 刪除自定義屬性: ?2 `) F7 W) t- P; g- Q
  37. Call partitionTM: R2 S$ ^5 U; F# ]
  38. 4 X5 z1 E4 [4 R' w
  39. End Sub
      x  m) i0 ~9 T9 B/ M' w
  40. ! P, ?0 F$ e! B' d! B+ o  Y
  41. '~~~ 刪除自定義屬性 ~~~
    * m/ V- T! c( v7 g8 d8 v
  42. Sub 刪除自定義屬性()
    " C9 y5 `" H! e% T- x+ V! S
  43. 'Dim swApp As Object
    8 C2 `0 k/ n( L/ z- R
  44. Dim swModel2 As SldWorks.ModelDoc2& w8 U7 ^- x, I# U3 u, i1 K
  45. Dim vCustInfoNameArr2 As Variant  m7 \/ Z" y# h+ t
  46. 2 z  Q. ?& r" C1 l& _
  47. Set swApp = Application.SldWorks: c7 c# S8 n4 n( i
  48. Set swModel2 = swApp.ActiveDoc
    / J: W( X$ j6 J& ]" n( i
  49. vCustInfoNameArr2 = swModel2.GetCustomInfoNames" a' e; K  n& t0 V/ S
  50.   If Not IsEmpty(vCustInfoNameArr2) Then* w, o- Z2 s4 b6 P" a
  51.      For Each vCustInfoName2 In vCustInfoNameArr2
    * K$ E3 S* g, D" v
  52.          bRet = swModel2.DeleteCustomInfo(vCustInfoName2)
    9 Y  }, J- m3 @- s) E6 p5 X
  53.       Next
    ' S* W* X2 k/ v- a( N8 N; h
  54.   End If1 I- |( F+ Y" p% {! f9 t
  55. End Sub% p' d* X; D% _8 F; e8 z1 L
  56. ! Y, v' |: i, _2 n0 X
  57. '~~~ partitionTM ~~~
    - q6 O! E1 [4 Z5 t  }& ~( H4 f, \
  58. Sub partitionTM() 'partitionTM
    . b# Y: b) S/ s8 n% s
  59. ! X- N* L/ `& O& G" Q# `  y1 i
  60. 'link solidworks) x( u: C: [) D( a7 c
  61. Set swApp = Application.SldWorks6 K/ u; v( j6 w2 h
  62. Set Part = swApp.ActiveDoc
    + Y; f, n6 Q% o0 h
  63. Set SelMgr = Part.SelectionManager
    % h/ M* l, _+ l+ ]" q
  64. swApp.ActiveDoc.ActiveView.FrameState = 1
    6 y2 A+ Q6 O/ C* p" @! P. j
  65. '設定變量
    3 X7 r' |: c9 n$ G
  66. c = swApp.ActiveDoc.GetTitle() '零件名
    % l: T7 a0 X6 @  U% i* S
  67. strmat = Chr(34) + Trim("SW-Material" + "@") + c + Chr(34)' b3 U% l# P' b/ ^. r
  68. 'tempvalue = Part.CustomInfo2("", "材料")' f" D+ ?. j1 g+ w8 {& e- h) ^* I5 s
  69. blnretval = Part.DeleteCustomInfo2("", "代號")
    + c$ Q0 X- K4 W8 ?
  70. blnretval = Part.DeleteCustomInfo2("", "名稱")
    8 a+ u4 g/ }4 ]& v0 l2 _6 u% j
  71. blnretval = Part.DeleteCustomInfo2("", "材料")5 Z  J- f' Z% K* D2 q/ u
  72. a = InStr(c, " ") - 1& @+ Z7 d! V* J. F* F
  73. If a > 0 Then  ^+ E* Q. `5 N" n0 m+ I5 S# O/ B
  74.     k = Left(c, a)" z) e- X0 r2 h( `
  75.     t = Left(LTrim(e), 3)
    % A2 R5 O' q/ s  y
  76.     If t = "GBT" Then4 P2 r9 k8 B. ~1 X
  77.         e = "GB/T" + Mid(k, 4)3 C! o( f; s  y0 V* z6 C
  78.     Else
    - _% D. a5 O0 ?8 V4 t& b" J
  79.         e = k" d, u; Q8 H) S% w
  80.     End If" V/ j# q" n' E& P8 }' d
  81.     b = Mid(c, a + 2)
    % a" X4 B8 T9 p( R
  82.     t = Right(c, 7)
    ! n0 u( B/ [, p6 J0 Z
  83.     If t = ".SLDPRT" Or t = ".SLDASM" Then
    3 L! x0 ~& ]1 J; W6 I
  84.         j = Len(b) - 7
    # ~3 y  q3 e# j" O8 d$ H
  85.     Else) U" O2 d% R' }/ n; n0 s
  86.         j = Len(b)
    5 P. B* x6 x3 I* L0 a7 e( L
  87.     End If
    7 t! m9 n3 }( U; @0 v
  88.     m = Left(b, j)
    ' H) `. S! r, h2 A" u3 x8 F
  89. End If
    / W; `* p5 [) Q9 o- o* V
  90. blnretval = Part.AddCustomInfo3("", "代號", swCustomInfoText, e)
    / }1 o8 ]7 U( }% B
  91. blnretval = Part.AddCustomInfo3("", "名稱", swCustomInfoText, m)# Q) n( W% c3 {2 \# M) t
  92. blnretval = Part.AddCustomInfo3("", "材料", swCustomInfoText, strmat)6 X7 R! z9 a/ ~9 h( N5 z
  93. blnretval = Part.AddCustomInfo3("", "單重", swCustomInfoText, " ")
    + O# L9 g" P8 w
  94. blnretval = Part.AddCustomInfo3("", "備註", swCustomInfoText, " "): c1 V& ^' o/ h; q* ?* O
  95. $ ~( k) T- d# }  I6 W' q
  96. End Sub
复制代码
2 Z/ I+ v: L) J; g  g8 ^
& `' W, C. H+ J0 i
( R! u/ l9 f. i& K7 C. l
# l; u, |1 J, v: r9 I- G5 J! ~6 o
 楼主| 发表于 2018-11-26 15:11:45 | 显示全部楼层
ryouss 发表于 2018-11-25 11:32
& Y! r. P" g* U0 K9 g+ s' b& O0 u0 H就是如下的繁体字改為簡体字就是
1 C  ?1 v  S/ a; e: G
执行后无反应,属性都没改,不知道问题出在哪里?让您费心了。+ ^7 j6 N- [4 Z1 `  Y
  g8 g3 c$ s' T  m( \' ******************************************************************************) S9 ?6 m+ F. v' V* `4 w( n. m( }
5 e4 G7 N9 {, v- t' ******************************************************************************$ ?, C! z% S1 ]8 U9 U: R; r
Dim swApp As Object
0 B7 d  C' V) Z" @) `; A- W' }6 j. yDim Part As Object) b  F; c) a- l& Q1 Z" N
, `( a/ r  M2 ?0 lDim longstatus As Long, longwarnings As Long1 }7 u9 N- U% W2 }7 D) N; F4 Y
- s$ X/ N( k- I0 h+ k% L# XDim SelMgr As Object
7 |, r: {" p- V0 A2 cDim Feature As Object0 m- o7 R% V5 |8 t1 e1 C3 s
Dim a As Integer
! A! `$ V* I* E/ ~; V( @; eDim b As String& ~; w& l) y& x: ]+ z! ~
Dim m As String" U- K* H* X. k6 G/ }- l
Dim e As String8 P$ ]! Z/ Q$ g+ ]! i% V) ~
Dim k As String
2 H) ~: q, k8 ?Dim t As String; @1 a9 [" Q3 Y& f0 {% ]
Dim c As String
% h( Q; P/ v( M& t: a- qDim j As Integer
8 A9 a' G1 E$ ^# e5 y1 T$ S( DDim strmat As String( @3 m5 V2 P+ Y
% ?+ f4 m# w) d6 d4 ]- Q  m- d9 g, E7 m! W/ H; ?
Sub main() '刪除所有配置属性
- D8 s# V3 c" f7 M/ O  ^' R3 vSet swApp = Application.SldWorks8 p9 j0 ^5 B: S2 s- z
Set Part = swApp.ActiveDoc1 X9 q+ j. d/ d# {- O0 [
  S" M$ C7 I; cCurCFGnameCount = Part.GetConfigurationCount
% R4 x: S. ]$ O. m- S# g4 ~( |For i = 0 To CurCFGnameCount - 1
* @/ ?) c7 g: T5 t' R  ^* R  }    Set CusPropMgr = Part.Extension.CustomPropertyManager(CurCFGname(i))$ |# ?% p  Z! P4 R1 r2 ]  \
    Vnamearr = CusPropMgr.GetNames* x, b: i2 P4 w( ^- D- h
8 e0 p5 W, H* v        For Each Vnamearr2 In Vnamearr
3 h6 i2 l- L8 O- K' T; k3 _, a: ]) A            bRet = Part.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)
' ]1 a$ v8 N$ ^: R2 T/ X        Next
# r/ _5 @2 }2 A$ q7 @9 ?    End If3 I/ g6 I( x  r+ H/ P: d6 ?
Next
9 F& X4 J0 K2 W: D( ]; ZCall 刪除自定义属性
" J! c  Y1 g4 R: P! L& ECall partitionTM
; U$ I- M+ L- M4 Y& w* X( i$ F, x; s
" V' w/ U  E# \" `- [8 nEnd Sub7 g. V2 K& Q3 f5 D
4 Q6 S% P8 G5 `6 i' u8 d/ F0 ^'~~~ 刪除自定义属性 ~~~5 G% R: R% W4 w* |3 O" z
Sub 刪除自定义属性()
9 Q7 K* b0 N' x( K8 J0 B$ q6 Q6 i'Dim swApp As Object8 g- R8 I5 s+ P4 E% \3 }. \
, [% m) q' n- x3 [Dim vCustInfoNameArr2 As Variant
& r( G+ Y  V6 `- v4 A* a# p
* x" A5 x) O/ H. J4 dSet swApp = Application.SldWorks
. f' U) k0 K5 wSet swModel2 = swApp.ActiveDoc
; n; \& d0 o2 KvCustInfoNameArr2 = swModel2.GetCustomInfoNames! e, p) I2 q+ T( n2 w  X3 d
  If Not IsEmpty(vCustInfoNameArr2) Then  I% W4 y% @% N; t7 p/ c' R
; V% O6 O1 y' U3 M( r         bRet = swModel2.DeleteCustomInfo(vCustInfoName2)  S( s( q. ]8 u% @; r
      Next  J$ b" h/ a* @+ m5 V; M" U$ m
  End If4 f) |; v. u6 @8 `4 |! H
End Sub# b  n$ ]; z  ~6 t+ |
- [3 j+ E. c# B6 y9 ^
'~~~ partitionTM ~~~: L. E; E0 J4 z/ N; V& d
, s+ a* E7 g+ r1 _) _
" h: I7 T6 x/ o+ L0 M'link solidworks5 W- ?: ]/ ?5 `9 ^: S% I- y
Set swApp = Application.SldWorks1 ]' Z0 K9 O$ P1 G  C6 {+ V# y
, b0 r3 L6 y. H: B: P  p% |Set SelMgr = Part.SelectionManager9 O3 \' _, p1 }5 o% E* g6 Q" H
swApp.ActiveDoc.ActiveView.FrameState = 1% l& p. n- x: B8 u8 f' X
'设定变量2 B1 i: v1 F4 d( S; P* |* c  m
c = swApp.ActiveDoc.GetTitle() '零件名3 R4 D% @- B9 h9 _
strmat = Chr(34) + Trim("SW-Material" + "@") + c + Chr(34)/ E( v+ u# l& e4 `/ o% K( Z4 [; v, d
'tempvalue = Part.CustomInfo2("", "材料"): e+ ~/ F" \7 Y1 a* l+ p
blnretval = Part.DeleteCustomInfo2("", "代号"): {1 k% D: f; x& g2 F
blnretval = Part.DeleteCustomInfo2("", "名称")
' A- |* h! ]1 W2 Oblnretval = Part.DeleteCustomInfo2("", "材料")
, ]2 P. e: ~* Ta = InStr(c, " ") - 1
7 G4 [4 C+ p+ R/ @( RIf a > 0 Then
; P9 J& k6 [' `, J    k = Left(c, a)
. c- H3 x( T: }3 C9 }    t = Left(LTrim(e), 3)4 [  o! p% |$ [( ^' R; L
    If t = "GBT" Then
& w6 _8 L3 n+ F3 ~% l7 V        e = "GB/T" + Mid(k, 4)6 n2 u9 m! o- Y5 w. d3 E" l% X  l
    Else
- W, M/ z2 W) Q( \8 e$ O        e = k
. Z4 B; p/ ]" }2 F    End If5 ^+ Y; A0 N- }
    b = Mid(c, a + 2)
4 @* O, a8 w( ~8 C, N: ]! L0 r    t = Right(c, 7)
6 X# W+ o3 J6 `; M5 d    If t = ".SLDPRT" Or t = ".SLDASM" Then4 r0 f+ i3 y1 I2 `( ]
        j = Len(b) - 7
( Y0 I5 F$ U2 ~& t/ f& C3 v! V$ L    Else
$ a- E3 S. a9 ]' s, a        j = Len(b)
4 f9 {5 ]7 \" |" G: A3 Z( g0 C    End If
' U( u5 {/ e& A; k! G- V% ?6 F5 p2 P    m = Left(b, j)
0 z, _+ }6 h7 k/ d6 NEnd If
) e& R. {2 }! wblnretval = Part.AddCustomInfo3("", "代号", swCustomInfoText, e)
/ |$ ~0 m( q6 jblnretval = Part.AddCustomInfo3("", "名称", swCustomInfoText, m)
$ c+ r3 W) o0 Sblnretval = Part.AddCustomInfo3("", "材料", swCustomInfoText, strmat)
( U. \% p" w' i, ~0 rblnretval = Part.AddCustomInfo3("", "单重", swCustomInfoText, " ")
4 K! Y# j) P# _  P  dblnretval = Part.AddCustomInfo3("", "备注", swCustomInfoText, " ")& a* c$ o# u# z6 `- D
2 S- c7 B- ^' f4 q# k) ~
End Sub
  l; W: m6 l7 L) X; ]8 B/ l4 ~# ~0 z
您需要 登录 才可以下载或查看,没有账号?注册会员
发表于 2018-11-26 16:58:44 | 显示全部楼层
& M& L) n4 n1 k9 o8 J' l
arter_2006 发表于 2018-11-26 15:115 K3 ~& T, C& n/ `* g9 L7 F6 O
执行后无反应,属性都没改,不知道问题出在哪里?让您费心了。" O, Y3 N7 H5 p" D
4 _4 a; W. l/ i  }' ********************************** ...
% |2 d* V& i/ F0 P5 P  L3 csw2017 測試OK
7 @- E' O" l8 K2 D/ D有否顯示什麼錯誤提示?4 H# a( w; j2 C) z; k% V! T2 J
; q* t/ C" m* z0 g
; y: ^; Z. f& m/ V4 w( {6 \
, q, s, m6 F+ w5 ~& }9 z
# q: x6 j& F# \
 楼主| 发表于 2018-11-26 17:00:36 | 显示全部楼层
我的是Solidworks 2018,看来可能是版本的问题了
发表于 2018-11-26 17:05:55 | 显示全部楼层
arter_2006 发表于 2018-11-26 17:00( o9 W: ^4 L* j- P- b+ l
' N9 q: T# w3 L. u
2018 沒版本能試0 l7 T6 F; o6 t4 A) L, s; T
 楼主| 发表于 2018-11-26 17:19:04 | 显示全部楼层
ryouss 发表于 2018-11-26 17:05! y& ]( P/ x6 W5 `* Y6 L1 ~5 p
2018 沒版本能試
6 j4 c4 C; Y, c/ s/ b非常感谢您,让您费心了。
) c# \: O4 |9 A! e" R
不客氣,相互學習!  发表于 2018-11-26 17:28
 楼主| 发表于 2018-11-26 17:27:57 | 显示全部楼层
2 y8 o- [: D6 j( f  {4 t$ `2018 沒版本能試
9 ?" t) y. F" ]3 Y" ~, q能否把您的SWP文件发上来,我刚才用solidworks 2014也试了一下,发现也不行,但是别的宏都可以。
7 i6 D& g; b  a我从网页上复制下来的都变成下面这个样子了,所以要删掉很多多出来的东西,我怀疑是不是这个原因导致的,但是校对很费时间,也难发现。
% C/ ]  Z. k& a5 Y5 h% Z
  J6 m0 Q& v. l0 R; [0 M! W' ******************************************************************************3 \3 X) J3 n, I6 @4 |0 x
7 ^7 g7 V2 w7 ~3 e' C:\Users\admin\AppData\Local\Temp\swx8144\Macro1.swb - macro recorded on 11/22/18 by mqlu' a$ M. \3 S6 C, S! A1 C; ]5 P; G2 x6 l
' ******************************************************************************" d  h/ |" X+ o. O
: n% \( F) I, C+ j: _& m6 bDim swApp As Object8 \7 ]+ v! Z# l& Q8 `; v
' e* i- B# F; m% [6 c9 t+ \0 }Dim Part As Object! t9 ?1 q2 c' K2 l9 ^4 X" G5 |5 t1 J9 w& L$ a& e0 E# e
Dim boolstatus As Boolean- I8 s/ Y$ i' W. N0 _1 [; {- K5 j& T1 D
1 N- G# `& `' e  i% _$ }4 [4 B1 W8 u' q( \3 d4 Y/ K1 v" N; D
" C5 x& E- d" D! _' \7 D3 J( R9 \8 _3 m& \) d/ \Dim SelMgr As Object& B) v9 H! u. u( `' {5 x9 z
: S& D4 E8 I: d4 K4 q9 f0 e& f5 HDim Feature As Object
! [9 }; C5 Z+ V- o+ y9 G2 @9 Z7 s$ z: N6 b! v  l! SDim a As Integer6 D+ o. T9 t% ^3 p) d( ?2 |
& P" q% F6 [5 U$ N  F7 l5 _1 iDim b As String/ a) E' o9 v7 y0 L) H; T4 a/ J& Z% M
- W/ K$ M8 c1 L) qDim m As String+ ?/ w( `) D: S9 x- U: @4 a+ w0 s; J' o" p
Dim e As String" t" l1 k  K7 K8 U: @# s; `5 h% P$ e! T* T: i& T) r6 @& U: u0 K
Dim k As String* ?4 t9 u7 n+ _9 ]: B2 q! V: E: a3 y
Dim t As String) M) H% l- `% V: F, a+ |+ o
% R* ?6 C5 B( @3 D& DDim c As String
2 |! u: ]+ Z+ I( P! K3 d. @4 X+ d/ Q. _. p: yDim j As Integer3 N( z+ v  K2 q* v6 D
# l( ]3 U& R9 \0 ~Dim strmat As String. _: b( |% N! ~& @: F# C1 J# B) O
" F! d7 t6 p- DDim tempvalue As String
7 a1 F$ v( H) h9 I- {5 i1 C- ]& E& r" D5 F  G0 |% Q: b, Y
$ J  P6 I% v2 X( t5 x- o) ?$ `2 a( G& L5 x7 Q- B3 Z( ISub main() '刪除所有配置屬性
+ A* K# h; d( k5 S; c8 H3 l/ z* n* R9 KSet swApp = Application.SldWorks9 g. p. p7 K6 u7 ?4 x4 W6 n2 K$ Y/ l# ~/ r2 @- Q
Set Part = swApp.ActiveDoc$ q6 |& ^2 b7 ~/ ]( ^0 R4 s! _" \9 s" c2 [0 J$ @3 I# [7 }
3 o+ t7 a8 p2 a0 j0 |6 K- [5 v: x. U8 U( V* kCurCFGnameCount = Part.GetConfigurationCount5 |- f& u& O  P6 b: H9 o
" c- O# J: c, c5 w7 Y0 T. @for i = 0 To CurCFGnameCount - 1& {$ V* E/ x+ ~. V  }! X# C3 e8 [. ]6 T
' d! j4 `2 ^+ s  j. G( J! L$ ?  c% B6 }    Vnamearr = CusPropMgr.GetNames4 B$ N4 Q* X) q- [; f8 r0 ^5 {
# \" ~6 C" M, l$ W    If Not IsEmpty(Vnamearr) Then' t" n; u" h( T) S& m/ ]% o7 K6 d/ y+ ^9 G9 x
) ]! L5 X% O  @+ E- n8 t& |, B: B/ V9 S4 d, F7 Z            bRet = Part.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)+ h. {$ P6 Q5 M: i
9 ?0 x9 G4 }  p        Next- P& E; Z$ s7 V+ a( t' E% T
4 _5 E8 |) N3 D$ B3 y9 u( S    End If
2 }  y8 R3 T; ^  w& r$ A3 @6 S" n' d2 eNext
3 e, T# L# O) M  Z. ?1 B% ?  k" k4 f; K$ vCall 刪除自定義屬性( U7 e$ ?1 j2 k! N
( A- x) f" C" d8 G6 }) {# {' iCall partitionTM4 }2 o$ e' E7 t; p( O+ w7 h- N4 `2 @  k
: `6 k9 z, x( m6 z2 @8 q. ~" b  {% q" `4 h6 {End Sub% O+ ^/ c' N( W/ S4 ^, v( |( ]5 v
% e; G6 r) ]# @' p5 ]3 e4 i! s+ Y- x
" D7 r# [' m2 U5 Z7 k9 B. O: ?'~~~ 刪除自定義屬性 ~~~
1 u0 k9 R' f2 z: Q6 `! G2 u. ]" |4 i. ?Sub 刪除自定義屬性()0 U3 g8 T' ?; |6 t
  B# r$ |5 d2 b. o4 x5 W" n+ J'Dim swApp As Object2 Q# s7 O1 ~+ I" }; R6 w, c3 c$ P, Q1 V3 x7 N
) [" M; y% y" N+ g- A# O3 P- f6 [! f' g# o6 S, e, W4 z+ EDim vCustInfoNameArr2 As Variant7 J* i  U% A! t0 \0 D! h, V
+ X# v- e# j- T5 M0 y! j7 n( z/ Q
7 Q" C7 y5 H0 Z: q- K" x+ X- v- E% b! h6 i* p! ], |9 USet swApp = Application.SldWorks
0 O+ x! U# a& K1 ?6 j8 D" ]4 S  i4 [' W6 ]0 I* U0 V' O' B+ NSet swModel2 = swApp.ActiveDoc3 u) Z+ D2 D4 z; M# d4 {
5 ^! s2 Q3 F/ ]: ^/ ~& ~& JvCustInfoNameArr2 = swModel2.GetCustomInfoNames- N/ C9 m0 n2 t* k9 u
3 o) q% ~5 f7 D  If Not IsEmpty(vCustInfoNameArr2) Then  X# y* k# Z+ n0 J
! V# Z5 s; g8 P9 J( v  m% Z     For Each vCustInfoName2 In vCustInfoNameArr2- \% O7 w% [: r; T3 |5 M6 O, @( Z7 {+ ^" ^1 ]
4 y* T5 [0 N9 _; ]* t2 q. ?" R/ r# I! y' x7 _' X      Next9 U+ R% V2 G# P
: ]/ z( y6 J0 r  End If
: k" X/ E3 @( V, |& i& V, L( M& Q4 l& b0 TEnd Sub, j& F" A$ ?% v
6 M- K7 `: z' w) T+ c$ V; G( r, f% Z3 T# j  b* g0 K" T. H
/ j9 |  ?( U5 a+ K'~~~ partitionTM ~~~7 O3 t. l4 R1 [+ ]3 K  G+ M
. ?  R! r6 g+ L8 N* p7 c3 qSub partitionTM() 'partitionTM( j# ]! b. Q, G0 M9 E4 f8 B2 J
( }+ W: h/ o0 m% l; E) x# ~4 [& t0 {8 [
8 X5 K/ X  ]5 T9 i% S; a'link solidworks( C, c- [# N+ Z* [8 E8 p3 q& Z& R
Set swApp = Application.SldWorks+ w1 D3 {4 b7 ^# i5 p4 ~2 p8 \7 X1 a' m. z
" Q; C' Q! B! i+ {% \) k" c8 Y, z+ b# A0 `9 OSet SelMgr = Part.SelectionManager% m# Z: n! Q: I/ M* d( j' c% a: v9 _* e+ A3 t8 N$ M
swApp.ActiveDoc.ActiveView.FrameState = 1& ?6 I  _. Y+ \4 m7 P" c% W/ h: K) y! M! x% n) f! _( p* e( F$ C
'設定變量& }. N& d* J$ W) S8 M0 t" f( v0 R+ d: F0 J
; V5 P% {2 ]3 W! y- b. {8 L5 ~" z0 y# g! I" Estrmat = Chr(34) + Trim("SW-Material" + "@") + c + Chr(34). w+ f3 v( W- `* D! G! v. z
7 R# k2 q& {- a5 e+ }'tempvalue = Part.CustomInfo2("", "材料")% ?- i) I" l3 x6 r
& U; y& P! d9 n  V  X0 H+ J1 Yblnretval = Part.DeleteCustomInfo2("", "代號")3 w1 A4 Q. Z1 \, x1 N/ e; R
; Z+ W8 m  Q2 [  y# Zblnretval = Part.DeleteCustomInfo2("", "名稱"). }" r" K0 E! E4 n9 m  J) W) i( ?) I2 k
2 g6 J5 n8 g) D; D8 V! }+ U) d- F; R- ]4 V0 e- k2 J; Sa = InStr(c, " ") - 1
# w* w) D/ E5 V2 I6 A' v4 [" v0 S% D. r) K$ `' iIf a > 0 Then
7 E% Y; ]0 m1 l' G6 o6 B7 m0 D& _% k+ M" K3 ~    k = Left(c, a)0 D( T  G4 u* @' Z: h# g5 h) k" n# s/ b% S/ @- H: D
    t = Left(LTrim(e), 3)0 |: d+ H% K1 I5 d; ^& r
, }# S7 g# O' J  U: k: n    If t = "GBT" Then0 a: k4 H  }1 j) y
+ }# H0 S( i5 f8 g8 I6 z        e = "GB/T" + Mid(k, 4)0 C& x4 F4 D' ], i* s8 T
3 Q% ?% b* f0 u0 n: d3 P  A    Else9 W" a/ ?7 B6 c# m5 t& L& i) ^
! W2 i7 C- b( f1 H* X4 B; P        e = k& O7 M7 ]$ E: v$ n5 ]  ?0 p$ z) D3 L  x- J7 [7 Q
    End If! C- h9 R! k; n% D6 G+ S; P/ ]- \  ^5 {& n, ?2 z
    b = Mid(c, a + 2)7 v5 }4 q& t5 e7 [  \' S. W, [
1 a, _" o% b/ ^0 j8 S  T    t = Right(c, 7)" {! n! F8 L$ D" z$ [. |1 Y1 ^( [* y
( H6 S2 ?' U+ d5 X" f: a    If t = ".SLDPRT" Or t = ".SLDASM" Then* @3 p5 Z" n) }+ v; b
( m# n+ r. ]5 p& Q/ I! e        j = Len(b) - 7: f; _- _+ L% W8 E) q2 `; Z9 B' \
* e1 y+ L* W1 I5 q    Else& f9 y# D- W/ Y! i& w- H
. P; q# {5 A0 j        j = Len(b); J( ?# E, |  ?5 _) J. A: k1 X- d
    End If8 @/ x5 s, N; \. _& V# V% b* F' y! Z1 J% o1 r) V
    m = Left(b, j)
+ b* w/ X  t( g& S4 n. P: e' A' P) l4 b& \End If( o3 u- a' n" g; c4 t2 s& ]
' W  E5 y+ R* C( Rblnretval = Part.AddCustomInfo3("", "代號", swCustomInfoText, e)  ^0 X: z$ b4 z0 A2 K: x; z* }
: F  K  N' M% L5 C4 Hblnretval = Part.AddCustomInfo3("", "名稱", swCustomInfoText, m)7 a/ m( J8 q$ B) ^& B( M# Q' V* y# Q2 ?: |6 _  V- ], g- f
3 b. e# D* f( ^  u9 Z0 O2 e0 Q6 cblnretval = Part.AddCustomInfo3("", "單重", swCustomInfoText, " ")/ C9 N8 v# h9 L
  V; G2 e# V. L; H; {2 wblnretval = Part.AddCustomInfo3("", "備註", swCustomInfoText, " ")
1 I4 X9 Q) p! i0 h" I. v# J- k: i2 D6 }7 z- @1 t: i# Q, P, {! f% c" J- {6 u; t  v% J9 l& n: d, Z
End Sub( P) C# ?( y  g
$ I" h4 [/ N/ g8 M6 [7 f) W7 z
发表于 2018-11-26 18:42:16 | 显示全部楼层
arter_2006 发表于 2018-11-26 17:27( [: u; \9 x: \" d
: i2 S7 W$ s2 H7 i2 _我从网 ...
8 g8 C6 }$ X- k# v: E0 T3 N
附swp繁体版
1 K  [7 |- n+ A6 p- n0 E
发表于 2018-11-27 13:26:40 | 显示全部楼层
+ r% W9 H0 M) z, |' H6 `) E" ~0 P  _$ e2 r; m# ^5 ^7 L, F
試試把   CurCFGname = swApp.GetConfigurationNames
, V. _: n( v9 g) H( m+ Z6 R* h8 E$ N. r6 B) y- j2 i
改為      CurCFGname = swApp.GetConfigurationNames(swApp.ActiveDoc.GetPathName) '補加零件文件的路徑及名稱: b! ^$ y9 k- U5 I6 v$ r2 ?! u* s' u
' t# u. P: A4 ?; k" o2 C2 u- F2 l
在沒補加 (swApp.ActiveDoc.GetPathName) 時在2012及2015版是會有提示錯誤的(如附图)! @5 F- R2 p5 F9 f0 W
另VBA編程在   " '  " 符號后的文字是會跳過不執行的.' t; V9 Z/ A0 i$ W: u6 |$ n
  t8 r0 f, g" j/ B' {* M$ y6 L% g8 f6 ?  B& L+ G  _
# D" ^: C; r5 ?, E% M) A
 楼主| 发表于 2018-11-28 13:49:36 | 显示全部楼层
我试过了,改之前,改之后一个样,而且执行中没有任何错误提示。, _/ H( J& S, I3 M
) h3 u+ E. ?& v1 N3 _) k' C:\Users\admin\AppData\Local\Temp\swx8144\Macro1.swb - macro recorded on 11/22/18 by mqlu/ x. L- v- \5 u- Y. c
. G6 z* z: ~+ NDim swApp As Object4 W# V7 l+ V7 L: [
Dim Part As Object
( ]# l% T6 m( \0 h7 r+ |  ]! X3 UDim boolstatus As Boolean& H" A- m0 m: g' \
8 a/ z% J5 r& O
' T+ `. |- N8 S1 Y3 n2 m- V9 H. ~' oDim SelMgr As Object2 L* m9 Y. W0 T# b
Dim Feature As Object8 m* }% k8 b. {1 B0 I$ D; J, u
Dim a As Integer
' X" J4 C$ h5 v" oDim b As String: U+ P4 }2 U$ G# y# ^; r4 O, N  g
Dim m As String5 w: Q! W$ E- t: r; m2 V& E
Dim e As String) Z: N# T9 b0 a' K; @
Dim k As String
+ I. w9 r; ~  Q7 P- [Dim t As String' ], L% [" t9 p/ K& `3 F- N
Dim c As String7 U" K) h/ |% s9 L
Dim j As Integer, c1 {5 o7 A1 k! m4 x* ~0 P+ T
$ u+ j+ o% y  Z! d0 tDim tempvalue As String
; t, E3 A: r5 N0 S. E
" ?) D, R8 v# g  p5 ~1 ySub main() '刪除所有配置属性
# Q% l/ @* X) d: M4 j, {Set swApp = Application.SldWorks
  `2 K; M7 i3 i& i' x: |% JSet Part = swApp.ActiveDoc
( |1 e4 p6 e% H- \5 R1 S) r& ICurCFGname = swApp.GetConfigurationNames(swApp.ActiveDoc.GetPathName) '补加零件文件的路径及名称
# {1 Y/ I8 q7 b7 A  E. MCurCFGnameCount = Part.GetConfigurationCount3 j$ F- }+ _2 K% l
' M- q! }: I' d! f- b    Set CusPropMgr = Part.Extension.CustomPropertyManager(CurCFGname(i))& X6 v. b; w+ R
9 c# @/ _1 V, m0 {$ ?7 O( l    If Not IsEmpty(Vnamearr) Then
" O. u+ a: w" g  _6 ^1 _2 l$ P: _; e        For Each Vnamearr2 In Vnamearr; C- c6 c% b9 {# q* E( X; G5 h/ _' I( [
            bRet = Part.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)' J/ s4 H0 h4 w4 v6 v
        Next7 o8 l; [- q3 U! t; L) L
    End If7 l* u7 p! p6 Y
Next- n. L) I) t) C4 H3 }% u
Call 刪除自定义属性6 K5 P  z5 J1 w
Call partitionTM
( D4 ]7 Q$ o6 ?3 z) J4 M* {9 p% g: L( }+ E
End Sub# D6 H6 U, ^: l% j2 C! U
/ X7 i* Z* O1 d5 ^- M
'~~~ 刪除自定义属性 ~~~0 \) A( O) _9 u4 j% _8 z/ O3 L6 z
Sub 刪除自定义属性()
: E2 i: ]3 R8 f' K- }% Y2 x: s'Dim swApp As Object5 s! U! W( \- g0 \  R( q2 q% T; X0 M/ i
0 ?2 l2 E/ q9 u  ~( A) z4 ^Dim vCustInfoNameArr2 As Variant4 _4 x+ \2 s7 i! F
6 l: B* b2 Q9 t% Q1 x
Set swApp = Application.SldWorks/ k8 A% l, L6 g! C7 M  w
6 P' a4 w6 Y/ W: e5 ?0 ~vCustInfoNameArr2 = swModel2.GetCustomInfoNames
0 {! [. _+ {& R% V5 C/ S' _  If Not IsEmpty(vCustInfoNameArr2) Then
# b1 u' O7 X) _# f$ ?     For Each vCustInfoName2 In vCustInfoNameArr2
  v2 f6 ^, ~  S% K( a         bRet = swModel2.DeleteCustomInfo(vCustInfoName2)/ N" A0 e; c$ {" _/ E6 V/ r! h+ K1 k# v
      Next7 h6 c+ G! p3 S! |" {
  End If
3 c0 U" |8 l6 V4 S& I5 O; t/ NEnd Sub
3 \! k/ B  d! ]1 Z& i
+ F. @, U' S! j9 }' m'~~~ partitionTM ~~~
: C: T  A( b. _9 pSub partitionTM() 'partitionTM
0 C5 z1 x+ j, K; b: v
/ K6 r  X( w& M3 S'link solidworks7 A. H* c% U2 S% [1 B
5 T, p2 [+ m$ m" S& `6 cSet Part = swApp.ActiveDoc
0 x# x2 X% C% k1 K& P* D2 p" ^Set SelMgr = Part.SelectionManager
( C. \  ^) {  Q, X, X2 ~! iswApp.ActiveDoc.ActiveView.FrameState = 1
0 P1 C- m! s5 n2 I3 S/ _0 Z'设定变量' j& [% S6 r+ Q) k# ^# m  l
! m0 {1 D9 O/ b1 @4 [) S; sstrmat = Chr(34) + Trim("SW-Material" + "@") + c + Chr(34); K, L+ r* U4 N& Z7 s. h- B
'tempvalue = Part.CustomInfo2("", "材料")$ q+ J; _  L% A4 h1 W- w
1 D+ M5 z& l) x' C& R& N! s  v3 l6 ?blnretval = Part.DeleteCustomInfo2("", "名称")
9 Q  s/ f: v. X, Yblnretval = Part.DeleteCustomInfo2("", "材料")
$ g) J& L! _1 o2 H7 s+ l* [4 H+ [* j) s& M
- J1 S) S5 Z7 v% x/ F* D
% q5 t7 W; `: j# S# ?If a > 0 Then
- l" @  B& U" w* }& z) ^    k = Left(c, a)
& V: z, I4 {/ l3 R& [+ Y    t = Left(LTrim(e), 3)
! d9 {+ j- E, y1 w0 W% m1 N, L1 D! P, [
    If t = "GBT" Then( e* n* F& y2 f4 V" f
        e = "GB/T" + Mid(k, 4)) B, m9 c8 G6 L
    Else
3 K& I* F0 j- p3 l5 U        e = k, u" o- j/ K$ e  l
    End If6 D5 v6 i% A5 e2 ?: p; a6 @
- p( G) ]+ @8 B$ O" @& I
    b = Mid(c, a + 2)
8 s4 Z, I, w+ J. [; T! t    t = Right(c, 7)
$ C9 ]: y3 d4 B) H9 @  J    If t = ".SLDPRT" Or t = ".SLDASM" Then3 ?: o( `3 s! K+ a6 k
        j = Len(b) - 7
+ r  u7 O4 M3 v" E4 O. U4 |    Else4 }* Q# @: H$ H. R% M6 Y
        j = Len(b)
- {; u! T9 c. W$ s- A  n    End If
- n& U9 x. E4 i  C    m = Left(b, j)
; e- i6 e( y/ ~8 w2 m0 ~End If& X2 [5 {0 E; Y9 F" p5 E6 i& x
' m! y# N  U5 \2 ^# X& ^" sblnretval = Part.AddCustomInfo3("", "代号", swCustomInfoText, e)4 n) m8 q2 ^/ w- Q* V" G  v+ |* M
blnretval = Part.AddCustomInfo3("", "名称", swCustomInfoText, m)% `& V8 n) `$ }. _* W8 I5 V  ~! }
1 R; V' j( F. U% ablnretval = Part.AddCustomInfo3("", "单重", swCustomInfoText, " ")
& p7 S7 `$ p4 E1 |* cblnretval = Part.AddCustomInfo3("", "备注", swCustomInfoText, " ")
& {$ P) G% m  q( e0 L' l( ~) Y  ^8 m% m: K, f: J. r
End Sub
試了 2014版 嗎?  发表于 2018-11-28 15:56
那可能就是2018版本問題了!  发表于 2018-11-28 15:55
GMT+8, 2025-9-19 12:14 , Processed in 0.063938 second(s), 15 queries , Gzip On.
