楼主 |
发表于 2018-11-25 09:12:54
显示全部楼层
以下是我改过的宏,不知道哪里出了问题?附件压缩包是写字板格式的。
$ c; B- j6 X6 r2 _& y1 n8 E' ******************************************************************************
& {# r% j& t$ q2 U L* E' C:\Users\admin\AppData\Local\Temp\swx8144\Macro1.swb - macro recorded on 11/22/18 by mqlu
& j7 w q4 k. q' ******************************************************************************
1 p9 M% C& H7 I( J1 oDim swApp As Object
; u4 C# y% p) p$ F6 W' F5 ^4 k- ~6 ]7 pDim Part As Object
) L N+ G1 z: H. ~2 j4 qDim boolstatus As Boolean' t) P, I6 {4 `7 ~# R$ v3 F
Dim longstatus As Long, longwarnings As Long
, D7 p! \9 z. G
6 l c) \% e5 B; r7 ~, _Dim SelMgr As Object; z4 f# I2 f6 |
Dim Feature As Object
0 V8 Q# o6 A" U# q- F" GDim a As Integer3 O0 A0 \0 K+ c6 }7 @( r( M: S
Dim b As String2 x3 g% @5 p/ i- |7 Z+ v% Z
Dim m As String$ l A2 w, [+ S! h/ m3 C8 A |
Dim e As String
1 T$ T* Y4 ^8 JDim k As String6 F1 K4 l9 \9 ~, Q) ^
Dim t As String8 C6 J1 |2 | P$ g" ]2 u% i! A
Dim c As String
) |; y" u6 J5 R% ?: M6 f0 p+ V0 _5 CDim j As Integer
- y: N: O- ^9 Z5 w; ADim strmat As String K3 i8 j& g: `- ]
Dim tempvalue As String
. e+ e! v6 m G- d2 E) w7 a8 z9 ?6 @: m: i1 L9 O1 q
Sub main() '刪除所有配置屬性0 v1 H) [( J8 O0 u& d* |
Set swApp = Application.SldWorks
2 U; Z% E( p+ w1 X' V+ YSet Part = swApp.ActiveDoc% Z6 E8 F" K+ @: M( T" x
CurCFGname = Part.GetConfigurationNames)
& n2 x/ A! I, c' s$ M! M0 xCurCFGnameCount = Part.GetConfigurationCount0 O5 b Y: G9 d2 j: C/ @" |9 a! m y
For i = 0 To CurCFGnameCount - 1
- P! J0 _$ M; Q, ]. D: I3 p Set CusPropMgr = Part.Extension.CustomPropertyManager(CurCFGname(i))0 q" {9 q" ^3 U2 d
Vnamearr = CusPropMgr.GetNames
! a4 V$ u. z5 v* N& B( o If Not IsEmpty(Vnamearr) Then: g. t. l9 S$ i' |9 e0 l/ m
For Each Vnamearr2 In Vnamearr
! ?/ W) i7 p N4 Q7 m& k3 M bRet = Part.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)* l& X$ v+ d2 p K& c
Next& ~: ]0 x$ i% M% H' e
End If
8 j9 r, e# \' ^0 j+ pNext
+ X ?5 C8 U9 R4 e' d/ T' p8 KCall 刪除自定義屬性1 p/ q' g }* u8 o$ z/ \
Call partitionTM* a b5 T" Y; [2 Z4 R/ D5 X' M
3 C# F+ n' \4 sEnd Sub* v/ ^' ^+ x/ L4 K. G. C
# q/ j, N3 e! a/ U1 e5 g2 u9 F' x'~~~ 刪除自定義屬性 ~~~, z* o2 A6 A: o! w+ o8 }. X
Sub '刪除自定義屬性: I/ s; A" t. I6 Z
'Dim swApp As Object
; x# Q+ Y# j% a) b( B/ dDim swModel2 As SldWorks.ModelDoc2
, `* n( E" {4 SDim vCustInfoNameArr2 As Variant
4 u1 L; S$ `& P8 |3 t' I) k: H+ T5 W" w5 _3 Y1 h/ a4 I
9 u% I- n( J' Y+ M# d* B+ XSet swModel2 = swApp.ActiveDoc
5 N) t5 Y4 H& X4 JvCustInfoNameArr2 = swModel2.GetCustomInfoNames& _4 ], K9 V: z
If Not IsEmpty(vCustInfoNameArr2) Then/ P$ }$ q$ }" g3 ?% ~
For Each vCustInfoName2 In vCustInfoNameArr2
& Y L3 _0 T1 O! R/ z' N bRet = swModel2.DeleteCustomInfo(vCustInfoName2)3 k$ T) L0 W. q: W
Next
7 K4 L% v2 l; I5 N; H. A! v3 @ End If
: F" W# n' j; X1 ZEnd Sub
# W2 I/ q: w. f" Q# }" Q
( l' Y$ R8 O# _+ @'~~~ partitionTM ~~~, K2 s- |9 ^ j6 s7 E& c9 Q! _
Sub partitionTM() 'partitionTM- W5 D: K' ^; v! v# y1 w: S
# Q7 }* H v4 X+ h
'link solidworks! [2 V+ Y: R# N' t8 o
( c* G$ j8 x% ?( d2 VSet Part = swApp.ActiveDoc
& B# S' n# [. G, w1 m/ v7 l# R6 h4 \Set SelMgr = Part.SelectionManager T- J2 c( r. ?( C& P, l, d
swApp.ActiveDoc.ActiveView.FrameState = 1
6 K& ?$ O" W0 g+ v9 R& Z'扢隅曹講5 r$ h( l" S# g, z1 ]; o
c = swApp.ActiveDoc.GetTitle() '錨璃靡+ P9 \: U. U" Z I1 O
strmat = Chr(34) + Trim("SW-Material" + "@") + c + Chr(34)5 C7 Q0 s; y8 e# _, t& R7 c4 C& |
'tempvalue = Part.CustomInfo2("", "第蹋")/ c: j$ u# H$ S2 y4 `; A
blnretval = Part.DeleteCustomInfo2("", "測瘍")3 E4 q4 O6 V4 ~3 Z5 B `) ~ S
blnretval = Part.DeleteCustomInfo2("", "靡備")
5 Q2 [! X1 @, E7 Pblnretval = Part.DeleteCustomInfo2("", "第蹋")
7 F) F% ~2 a2 x4 Fa = InStr(c, " ") - 1, Y! z: g! p4 ~6 o* Q) V1 q' x
If a > 0 Then8 L" Z, j# s: a* D" [* X: e
k = Left(c, a)7 \1 {9 j d6 J8 V; g e
t = Left(LTrim(e), 3)
" a+ q) A, Z- h f1 F If t = "GBT" Then! R; L( s" D/ l: O7 l$ a: L- h
e = "GB/T" + Mid(k, 4)6 b* I: s9 r! X+ \3 t' W# B
Else& E: F' j4 [, x; D
e = k
2 p8 o( @/ z! L. ]" X End If'7 a- s7 e! W8 S3 K
b = Mid(c, a + 2)0 o% q; O" x0 @ b1 `
t = Right(c, 7)
" r8 @* a) i: A, v If t = ".SLDPRT" Or t = ".SLDASM" Then# `9 }' ?5 y4 N( x' x& |
j = Len(b) - 7
9 `9 ?) E4 S7 f- s! x- Y v/ I Else
+ }: M6 c" S4 y6 z6 U j = Len(b)
2 K- H. H7 g R1 {% G End If
7 e( _* A" D5 n7 |! H; [8 q% \ m = Left(b, j)* x7 _" P& C! h5 ?% Q/ [2 X
End If$ E" U' J. Z7 Z# }( e# V
blnretval = Part.AddCustomInfo3("", "測瘍", swCustomInfoText, e)
& Y$ t: x$ j* X, P N0 }blnretval = Part.AddCustomInfo3("", "靡備", swCustomInfoText, m)& S8 k; H. L0 L% }* Z+ A
blnretval = Part.AddCustomInfo3("", "第蹋", swCustomInfoText, strmat)4 {3 u. d# @0 x9 t, S
blnretval = Part.AddCustomInfo3("", "等笭", swCustomInfoText, " ")
) b7 k o7 c. Bblnretval = Part.AddCustomInfo3("", "掘蛁", swCustomInfoText, " ")1 m9 g1 H3 K- z+ g
& b2 U& H2 P' Q* K8 i: g
End Sub |
