本人现有英国一套机床图纸,马上要投产但,因外语水平太差,看不懂。5 B. x- V Q' k+ D
希望大家帮忙翻译以下,不胜感激!2 C1 L7 f& w/ B4 i
(这些专业英文,软件都翻译不出来)
5 a( T6 Q- P( v3 D# [) j' A8 e) f有点多,大家有时间的话帮忙翻译一下,翻译多少是多少。
$ c1 m2 t0 e, l; n. q& l7 k" o$ BCompression Spring | Stud M6 × 30 Long | Feet Button | T-Slot Bolt M8×8×32 | Collar Nut M8 | Tooling Assembly .A530 | 50mm A/F Spindle Spanne | C'Spanner For 100 TGB L | L'nut Assy For 100 TGB | Standard Collet | Drill Bush Holder-Typ | A530,OmniSprint,Elec Pa | Rectifer Silicon Brg 2 | Circul Lege Plate-60mm | Blanking Plate 22mm-Bla | Body & Contact Block N/ | PB Op Head Black Flush | Flourescent Light-30W 2 | H/Whl-E:Stop-3/4 Axis l | H/Whl Socket | 3 Pole Busbar-63A-fit 4 | 3 Pole Busbar-63A-fit 2 | Relay 10A 24V SPCO | Base For 10A SPCO Relay | Aux. Contact 1NO+1NC VO | Term Shrouds for V3&V4 | Aux. Contact -NO+NC fit G | Cable/Drwg FNC-AK08-0.5 | Cable/Drwg FNC-AK12-2.0 | Cable/Drwg FNC-AK12-1.0 | Heat Exchanger-15 W/K- | Relay 5A 24V DPCO | Base for G2R2-SN DPCO r | 3 Pole Term Block-63A f | Slot Deep (15mm) Omega | Enc. 1800×1200×500mm Do | Cabinet Plinth 100×1200 | Cable/Drwg FNC-VDEO 15M | Fillter Suppressor | Philips PL-L Lamp cool | CCB-Single Pole 1Amp | CCB-Single Pole 2Amp | CCB-Single Pole 4Amp | Aux Sw(OF) Monitor for | Cable/Drwg FNC-AK22 6.5 | Cable/Drwg FNC-AK22 8.5 | Cable/Drwg FNC-AK22 9.5 | DIN Rail Mount Int/face | 50 Core Ribbon Cable 0. | Cable/Draw FNC-AK12 15M | Trans,380/460-220 1KVA | RC Suppressor 0.22uF 47 | TubeLight ,24W,23v,Comp | Relay 24V 1A 1C/O | Tx 230-90/100 1ph 100VA | PSU 400V 3PH - 24Vdc 10 | Safety Relay XPS-AC5121 | Contactor ,12A,24Vdc | Contactor ,18A,24Vdc | Contactor ,32A,24Vdc | Relay ,5NO,24Vdc | Relay ,3NO 2NC ,24Vdc | Aux Contacts 2NC ,2NO | Aux Contacts 4NO | Off Delay Blk,0.1-3s | Relay 4PCO 230Vac MY4IN | Relay Base 4PCO relay | MCB,60-100A,3pole | DiscSw,63A,3pole | MCB,0.63-1.0A,3pole | MCB,1.0.1.6A,3pole | MCB,2.5-4.0A,3pole | MCB,4.0-6.3A,3Pole | MCB,9.0-14.0A,3Pole | MCB,20.0-25.0A,3Pole | MCB,1-1.6A,3pole.Trans | MCB,1.6-2.5A,3pole,Tran | MCB,9-14A,3pole,Trans | MCB,TermShield | Pb,Flush,White,+1No, | Pb,Flush,Yellow,+1No, | Pb,Flush,Blue,+1No, | Pb,E-Stop,Red,+2Nc, | Key,2-posn,1No | Add on block,1Nc | I Im Pb,White,1No,1Nc,24 | CNC,Omni,PM-Ih | Oride/ModeSw,16posn |
