' c# L7 D1 l1 _7 u1 p0 I这是我转CAD 过来的 图层 下面是我的映射文件。 线粗 为啥没跟着变啊? 不然打印 得重新设置线宽。' {/ [, [5 u( ?
[Version]
# }- b/ T8 O' Z- v$ T. eSW9900018 S* ~' c% S9 N2 y; X5 q
; Z3 J* Y* m. d' c9 R0 N
[Layers]5 R: t+ q/ i: `) j, M* g# o3 b
0 = 7, 0; Y5 Q. f- P' M" z$ d0 [0 g
1轮廓实线层 = 7, -2
; P2 U* C% I0 i, k% r2细线层 = 4, -2
3 L0 P8 m3 n: b7 j% ?5 Q3中心线层 = 1, 7
5 S. x- \, N! l f; L4虚线层 = 6, 2
# [ o/ f0 j3 C# n% v4 [5剖面线层 = 2, -20 A. i2 h% G: D7 n! ?5 z! S, \
6文字层 = 3, -2
( o9 M! h1 B* M, f' Z! k: k2 h9 i7 o' z7标注层 = 4, -2
' ` W: i5 F% S) M+ t/ z8符号标注层 = 31, -2
7 N/ L% ` s0 n/ [; X9双点划线层 = 6, 9
$ ~- m W$ V- S
* i# Q8 V5 C( e" H& D9 H( x[Entities]6 @0 k0 h. |/ Z
几何体 [0] = BYLAYER, BYLAYER, 1轮廓实线层
4 X6 X; H: L2 `" K+ Z* ~7 i尺寸 [1] = BYLAYER, BYLAYER, 2细线层
$ }' a( ^ ~. y, _注释 [2] = BYLAYER, BYLAYER, 6文字层% W9 l0 r7 \: z) Y' X6 N
形位公差 [3] = BYLAYER, BYLAYER, 7标注层. i) w$ l. M! C% S" k& j) T
中心符号线 [4] = BYLAYER, BYLAYER, 3中心线层9 A+ ~ h8 U9 q; j* i
剖面线 [5] = BYLAYER, BYLAYER, 5剖面线层6 H& h7 j$ h9 \
局部视图图标 [6] = BYLAYER, BYLAYER, 8符号标注层
: q& J+ D! |; M) o符号 [7] = BYLAYER, BYLAYER, 8符号标注层
0 V3 F; K! I. l6 C- k! u# Y! L基准目标 [8] = BYLAYER, BYLAYER, 8符号标注层7 P- A Z7 c; J! O5 H2 y H% l
基准目标符号 [9] = BYLAYER, BYLAYER, 8符号标注层# }8 S' m% |; T9 D$ ^
焊接符号 [10] = BYLAYER, BYLAYER, 7标注层, c+ ?$ h9 m0 c9 r3 H5 `
装饰螺纹线 [11] = BYLAYER, BYLAYER, 2细线层
6 S9 [, d4 c6 S& i+ ?" C7 u材料明细表 [12] = BYLAYER, BYLAYER, 7标注层2 {/ v3 q# V0 J, F3 F4 y* x
块 [13] = BYLAYER, BYLAYER, 2细线层
# O0 \4 D% ?, }5 v s4 [' C中心线 [14] = BYLAYER, BYLAYER, 3中心线层) g; g. U; ^; L8 c
隐藏线 [15] = BYLAYER, BYLAYER, 4虚线层; m1 \, J0 Y3 X
草图直线 [16] = BYLAYER, BYLAYER, 2细线层, x3 m+ z1 k6 U6 ]& a. q
剖面线 [17] = BYLAYER, BYLAYER, 5剖面线层% Y* }& v" ]; m; g0 p5 _1 Z% f: g# i
局部视图边界 [18] = BYLAYER, BYLAYER, 5剖面线层
: n; ^ h0 ?4 I8 T& Z' d; k相切线 [19] = BYLAYER, BYLAYER, 2细线层4 m5 A' _- K/ X# m# ]
用户 - 虚线 [20] = BYLAYER, BYLAYER, 4虚线层4 t) e1 L2 S' R4 E, A! w; c7 k
用户 - 双点画线 [21] = BYLAYER, BYLAYER, 9双点划线层: a% T, z F' T, M; u
用户 - 中心线 [22] = BYLAYER, BYLAYER, 3中心线层: I7 J( q* z9 t, E2 n
多转折引线 [23] = BYLAYER, BYLAYER, 2细线层
6 a0 V) g; s" _/ P& i! r( k! @$ s8 F2 |销钉符号 [24] = BYLAYER, BYLAYER, 8符号标注层
z* }! ?1 |2 A, Z# e; L折断线 [25] = BYLAYER, BYLAYER, 2细线层5 @- Z" d: s$ B w8 N
块实例 [26] = BYLAYER, BYLAYER, 2细线层$ z$ \% o6 d+ u( i5 z% `5 Q/ F
中心线 [27] = BYLAYER, BYLAYER, 3中心线层. j. P6 b% `, `& N* M! H5 i2 Q
表格注解 [28] = BYLAYER, BYLAYER, 2细线层2 E" V3 Y9 |: p3 K
孔表格原点 [29] = BYLAYER, BYLAYER, 8符号标注层* U, A. n6 \1 P L2 ?' S+ q
焊缝 [30] = BYLAYER, BYLAYER, 2细线层3 l, S9 Y8 z9 E# X! y/ k
) d r6 P0 N1 c# R8 m1 e8 U[Colors]
% F3 z. }0 k7 _. S$ o/ K4 p! d0 -> 0) A8 T( }* S H6 n3 _$ G2 D& V
& ?4 R% ?- w; g& t) U/ {. P/ E
6 U* a% X9 \# q9 }" H0 s
2 _+ k: B$ v- x4 I9 m |
