![](static/image/common/ico_lz.png)
楼主 |
发表于 2018-10-17 13:53:03
显示全部楼层
5 u4 f7 j G2 n* ]
多討論多思考不管是對是錯總是會有進步.& B4 U* I' a! o1 N
; H* q% b/ X* i/ q9 P* a, y6 n1#動畫就是如s大說的作法,附sw2012文件及宏swp文件. & O+ J0 s3 w( ~/ A! o2 R
# h# m3 Z5 }$ q# z' _% Q; r/ v) F }8 f7 K0 H1 Y- i
- W' p: p0 E. g1 J2 _' L - ' macro recorded on 01/16/17 by scliang
6 P' a+ c0 a! c; T - ' ***********************************************
! _) ], P: D+ u - Option Explicit '強制用戶需先聲明定義變數型態
2 P$ n: z/ ]. c- r
4 H$ T$ ?4 O% L9 r9 m- Dim swApp As SldWorks.SldWorks '(Early Binding)8 v$ V0 H% i4 |: F
- Dim Part As SldWorks.ModelDoc23 B9 n9 `$ u2 F& {1 j
- Dim myModelView As ModelView 'Object 通用數據類型(Late Binding 運算速度較慢)
, T n r9 |, f* r3 E - Dim boolstatus As Boolean1 h1 e: U! S2 D
- Dim L, L1, L2, D1, D2, M2, N1, N2 As Double
& }7 E3 V+ s2 X4 L( T# @ - # t" `( \* W! W% J# O
- Sub main(): D2 Q9 D Y1 `3 o) G
- Set swApp = Application.SldWorks
0 v( w7 j4 ~$ S4 t! c. n- } - Set Part = swApp.ActiveDoc& J+ @; |* c- l6 l6 L
- Set myModelView = Part.ActiveView
R% N% c9 {: f/ _
% [0 n/ Y; S( j+ f! E- Dim myDimension_1 As Dimension 'Object- |6 |3 {( }# j5 U$ b8 V1 N
- Dim myDimension_2 As Dimension
) L& s: X; E# t7 O g9 Z - Set myDimension_1 = Part.Parameter("D5@螺旋曲線/渦捲線1") '材料圈數: D% z# [ P, ~" d3 A) \: J- f& ]
- Set myDimension_2 = Part.Parameter("D5@螺旋曲線/渦捲線2") '彈簧圈數" z- T$ u! o( t7 n1 G
- ) R2 P' L* L$ ?, ]8 |" {+ I
- myDimension_1.SystemValue = 10
1 z8 U4 ]% H$ i9 t+ Z: W - myDimension_2.SystemValue = 0.5
4 d. h( d8 b/ l+ ^ - boolstatus = Part.EditRebuild3()
) Z! V$ E5 J t8 y - myModelView.RotateAboutCenter 0, 0
' O8 e" F- v2 _; q d- ^1 M1 k+ g7 M3 b
3 I, X* C% G' n- L = 3788.97938701496 '"D5@螺旋曲線/渦捲線1"+"D5@螺旋曲線/渦捲線2" 的線圈總長7 _) g0 w" W( r
- D1 = 376.996476741742 '"D5@螺旋曲線/渦捲線1" 的單圈長
! D \2 {# g! I j! C - D2 = 38.0292391950834 '"D5@螺旋曲線/渦捲線2" 的單圈長! I$ W% t8 F( h: P$ G( k0 T$ H
- ' x) j3 c/ S D7 ]1 m* a; ]& N& j
- For N2 = 1 To 25.5 Step 0.5 '彈簧圈數之循環" f& B( A1 c! U( Z/ u
- myDimension_2.SystemValue = N2& t4 }' n% o8 O3 g+ h: O
- L2 = D2 * (N2 - 0.5) '"D5@螺旋曲線/渦捲線2"展開長的增量- t/ ~! N8 A8 j, i7 I f
- L1 = L - L2 '"D5@螺旋曲線/渦捲線1" 的目前展開長
$ t+ a$ o7 h* _1 ` - N1 = L1 / D1 '"D5@螺旋曲線/渦捲線1" 的目前圈數
- t O5 x0 X6 U - myDimension_1.SystemValue = N1
5 s9 p7 ]. _0 r# i+ z( I - boolstatus = Part.EditRebuild3()
' l2 I. d% f1 n" F* z) b - myModelView.RotateAboutCenter 0, 06 ?" D0 C$ e0 c) b# M. L' s
- Next/ e. @# O) h5 t& J6 e; ^* l
- " r7 d' h4 [; [# ?" x
- Debug.Print "END"
4 c" c# z7 K( }/ X - End Sub
8 [ X4 s- q$ u6 s* `
复制代码 4 I6 ~# B# H5 }
f$ A# x# F1 b7 a
* D: \* f. ]# L7 u p! b) u! S; c! ?/ o* K- u" T
