刚从学校出来,拿得出手的也只有英语和软件了;$ Q9 i) e$ J' z! c5 }
, P2 f$ E& r' b; W' H6 u
mechanics 机械学! ^) P9 b- x, h9 Z+ M. A
mechanism 机构. M5 f9 l+ k# z8 o4 L$ M7 g
structure 结构" H6 A# W' ^& g5 X% o, k
architecture 建筑9 q$ u1 [: L5 H
, ^$ R5 g4 z5 N- _# |' a
machining 加工
& F4 q+ G4 `( }1 y+ O1 z! P. ^) Amanufacture 制造
G% B3 @- Y) {7 K! ~2 oassemble 装配! Y1 p2 G% U. x) O
: c/ G' m2 X* u& t$ O0 Jhydraulic 液压 S" l4 I+ a" P# @! @, k. ^
pneumatic 气动
, h) X( O' t3 Z+ Xdynamic 动力学
6 A, S% I. d- D8 _+ |, nkinematic 运动学0 W1 R- e) e' p4 i. g
static 静力学' Z* b5 p: C6 _$ c! y/ }
thermodynamics 热力学7 G( ^0 B, L: k: y }
ergonomic 人机工程学7 a& f9 e4 I8 i- o" T3 O6 c
* U; `1 i4 G0 Olathe/turning 车; Z5 | U8 U, K w
mill 铣! g! I7 g* g* R! F/ U1 C) J
planer 刨
2 `2 o, T) Q) ^ y8 S! Jgrinding 磨$ D- e5 `; W! s* m1 m* N2 \
drill 钻 tapping 攻牙: J7 `6 |. s3 Y. H/ ~4 |% ^9 _3 `2 U
bore 镗; q) k& F8 Y0 W' ?
forge 锻2 n* D3 B. J( q; ]- Q7 }. c9 B
found/cast 铸" g- l: v5 t' `# X
punching 冲
' p' H3 [$ y5 L4 L jsheet 钣金, d/ g; V9 g; J/ N( {( |2 N, d u0 i
weld 焊* }3 B: F" Z4 K' l: ~- x5 {7 K
staking 铆 rivet 铆钉/ y. u d) x# v/ z0 \
broaching 拉孔$ \/ E* J5 f* [+ h" a8 S
to file burr 去毛刺 deburr7 X3 S5 k% w9 u5 m0 o
scrape 刮削3 s& f9 J/ l' W W3 C
lapping 研磨
) o' ^0 Y: q: u5 Apolishing 抛光
3 l+ P; @- }# `' v+ j% d Xshave 剃
% U9 D/ d6 B. L% F0 L7 ?3 }fraising 铰孔 reamer 铰刀
& M; O" V5 n+ B4 Y0 Rdie 模 mold0 J- \1 h+ O1 s$ J0 n: {
EDA electric discharge machining 放电加工 ' p- _4 ^& n" i1 u5 I. T6 X' u
electric sparkle 电火花加工6 f; ^' Q; `/ f2 E
Electrolysis 电解! \" z5 A" A; f4 [2 t& ]# ~$ y
adhesive bonding 粘结% X# j) [' Z- y& g; d9 S
5 P* i. }9 v' @0 N! E- X$ z
surface finish 表面处理5 w* ], D5 C' x( _% F) B
painting 喷涂,漆
3 O) k0 ~% Y1 c! Z; nElectroplate 电镀* h! m/ S+ w U" t* b0 k* A: o
electrophoresis 电泳
% K2 L3 u$ L4 O1 G3 igalvanization 镀锌 zinc plating
1 @/ f1 R- g, z- ~: y& c K1 C) w" DChrome plating 镀铬
) ]# `7 }9 a0 @% Znickel plating 镀镍
0 T! _- u, j; H9 N, J5 f1 j. ^1 ioxidation 氧化
7 q% F: X9 P6 u' ] d2 \! Z# _ anodizing 阳极氧化
- d9 f# N4 H. i- Q- E clear oxide 发白
( Z" C* X9 l6 g9 _$ L$ t% j% p2 \ black oxide 发黑 C8 B3 H+ I" k3 ?1 o0 g
Silk screen 丝印
3 `) T' R4 ]# a; f+ D+ T3 Rtextured 咬花 knurling 滚花 o5 @/ H5 I, s4 N. s
Sandblasting 喷砂
6 j% P" b K& \* {; d; _passivation 钝化
) F! B( O% Q: D- f8 [" [+ ~dacromet 达克罗——一种新型的表面处理,电镀方法,一切为了环保;- n: }0 A% L$ f6 G8 @$ ]& x) a1 ~
carburization 渗碳$ j# ]: Z$ R* q% D5 F' |
2 V4 \0 x4 J* X+ z8 {
reducer 减速机, [1 R. o- \2 `* ~: B, H
Transmission case 变速箱
% W* S7 H" D/ a$ m9 Qcrane 吊机
2 K$ K: y! e. Z" Lwindlass 卷扬机,辘轳,绞盘- f; ]$ u0 c' ^
crusher 破碎机3 V- L4 r& |7 r C( @
engraving machine 雕刻机
- s, K) Q) A8 LEDM wire cutting machine 线割机" W o' M' u' ^- F
Percussion machine 冲击机
' g) b+ _( `+ P. v A G
% n4 J6 J8 {0 G, a- M* Wfillet 嵌边,圆角% h* I; _' E, M$ y; h
embedded lump 镶块
5 [6 R5 z7 r+ s! g3 j' G* scrimping 卷边 }+ t9 ^; P" S( w
chamfer 倒角
8 j) I4 g5 d+ [1 |' A0 F5 n2 @. y2 B3 A# R3 t: Q+ h. }, t
pulling 拉伸 stretching" \& E) L- Q, _2 z+ B: F
compress 压缩: J: l r1 Z( i) }
shear 剪切! _7 M% ^8 {: [4 [$ k4 l. K
twist 扭转9 p. H9 b6 l+ H5 x, S& r
bending 弯曲( |& o, K, V, \, b/ n
9 |* p7 i$ E, T& zintensity 强度5 c% f! ]# h+ Z# ?" {% ~
rigidity 刚度4 C! m m- ]9 H6 x2 v$ \
hardness 硬度
# o, F5 [/ x j8 M5 k" E3 Bstability 稳定性; J+ N6 C- N# g& [* n3 _
durability 耐用性
# J, A. i0 L" [feasibility 可行性" s( R+ \; b/ j, U2 {! z& `3 G7 A
Flexibility 柔性
S0 C+ g" y# }2 abrittleness 脆性
+ v" _! o7 R; I. f- Y( B, s# iroughness 粗糙度
$ Z( I- R5 d7 }. W
: B+ {* F( N y6 J: b* y" Qstress 应力. I7 G. I* j2 U' F2 ^# F
load 负载
8 j' f- G2 p9 @
7 h( a+ e2 Q7 X, [* Ainterference 干涉9 A7 Q: t2 ~& @; i0 E( E
concussion 冲击、脑震荡
6 f+ N% `& v+ \( z3 b) T* Vdisplacement 位移
, b9 v% B" [& B1 Q& s, D! Rdistortion 变形
) H- \) E0 V4 q' d5 Ffracture 断裂
( e# U0 p6 ^0 p0 C1 Q$ r/ U) b% R: Nfatigue 疲劳
3 F' N4 U9 }8 i" Binvalidation 失效
6 I6 l, Z7 o: E1 b1 o$ g6 X/ \4 gshinkage cavity 缩孔
1 l/ ^6 l q, Z+ v1 M* t8 y0 ndents 压痕$ ~% Z5 Q+ \) V
scratch 刮伤
* x- c9 `& o2 e4 h' d. `deforming deformation 变形. H9 D6 D0 Z1 d. ?
defective to staking 铆合不良# n. e4 J% s3 c( \5 J9 ~
fasten 紧,锁紧
# d' p% ^4 {4 M, e( P' T1 Xloosed 松
% M! p0 @- O$ G+ _* q! W0 e0 U4 D* f4 K4 ]( p9 y: ~
wear 磨损
( u+ c6 I1 [+ Y+ ]0 D; X) x9 Grust 生锈3 g8 D# g0 B: j* H0 q
blocking 堵塞
& K! S) c. G, fcorrosion 腐蚀) h2 \. W: u2 Q& k. N
humidity 潮湿
5 G9 N$ w; E! Ooxidation 氧化
" `4 R" ^& J) ]; w/ ?; \! `; e, \residual stress 残余应力% o+ b) k5 F% n$ T5 P. t
( f( v6 m$ j$ @6 _* v3 F6 i6 t
hardening 淬火# @$ C1 u1 M2 y& N
quenching 水淬火/ B: ^! `+ m g
tempering 回火
: @' r, X7 J* A) o% Cannealing 退火! | b f( j; Q7 u' f* j
normalizing 正火
* a1 S+ e" {/ x6 j7 L q! Q& ~
! L# Z% X. I' h5 i2 W. i! htorsion 扭力
. H; a' y$ l: Ctorque 扭矩8 i& c) r6 R# `/ `7 F8 l
rolling bearing 滚动轴承
/ P& Q; c h" ~2 T1 `% L5 o3 r8 bsliding bearing 滑动轴承% L( }2 q5 G& f6 M# F% g' x5 G$ ]9 H$ m
: D4 |; [! m, T# J
horizontal 水平、卧式7 x8 }! W; S% s3 k8 y! K
vertical 垂直、立式
- E$ o0 R0 e( {: {parallel 平行" \+ { X3 ?! e2 ~
: B+ [8 ~! `' H1 a1 @7 O' P! K
discrete 离散,分散4 F2 j5 P! }- M; n( H9 t+ I
analogy 模拟,连续
- `) C( }) L; esimulation 模拟,仿真
& d2 \0 Z( ^0 L$ y$ k6 Q) @! F" n0 y
actuating motor 伺服电机 servo motor' f, f& O& y4 Q6 _
steper motor 步进电机- U1 W+ r0 ^( j* O( L9 o
induction motor 感应电机
6 h2 a1 O7 M) n/ B$ \3 X, \9 Oencoder 编码器
: [& i2 B+ u" I4 _7 z9 f% [! v5 [proximity switch 接近开关
; {* Z6 Z3 D D; ]! E" h& Greed switch 磁性开关
. ?4 Q# s3 z5 y* |; t& T6 ^photo sensor 光电传感器5 n) d* m a1 M$ q6 ~
fiber sensor 光纤传感器
& D2 \+ Z# ?4 |1 u( L; _6 Ilight curtain 光栅4 c1 J, o: q' x* _, {
load cell 压力传感器4 |5 x" O: {8 F% V( U* O) ~
displacement sensor 位移传感器" B8 Q0 c* H& `! x& E
relay 继电器
9 d# S( E5 \% h* ~. N* f. m, g& W1 c- kcontactor 接触器
: p! t* s8 O. ?( S1 ?* [. _feedback 反馈
. i/ j( I2 P* E. c3 ygenerator trigger flip-flop; Y2 \# T; u% O! N. J
' b! a, ~. R( P4 k
shaft 轴
# y$ x! [' l- O9 ^. T( E9 Espindle 主轴
6 \5 U+ [& b% B) l. Cheadstock 主轴箱* G0 A- p7 c# y4 Z' I) t
spline 花键
) u0 U; `$ V: i! V3 E% g4 k* ?/ ^- T
slide caliper 游标卡尺& d- C, S& d% Z! f4 y
micrometer caliper 千分尺
$ i8 ]% @5 P, M% }" X1 ~4 i3 f% @
multipurpose 万能! T( S2 w. b1 f% ^4 E, j+ d
universal 万能
" |; }7 s% b) v. E8 I
$ E5 c8 q0 O3 D: Fsquare 四角 方形. h. X- }- Z& G+ _" G( T, E
hexagon hex. 六角
8 [4 K4 n `8 v" S/ g3 p! Icircular round 圆; p" b8 Z' V/ Z3 M( Q
spherical 球9 k# z- a8 G9 t3 ]: _9 l+ I5 Q( u
rectangle 矩形
9 M7 N+ C$ |& G2 o! h& j& Apyramid 棱锥、金字塔 a5 v+ Z# u7 B) N
cone 圆锥
: }6 _0 A: {5 z. d" m8 Shelix 螺旋线
2 a5 [+ ]! q6 K9 |0 y7 Iarc 圆弧
; N0 i5 X/ L0 Q9 n
' k d& x; J; bsize 尺寸 dimension: ^, L8 l6 U+ }: x
length 长度( r. j$ T3 r9 W- F5 m( |
width 宽度& A! Q$ ~5 o" D
height 高度
- P' Z4 y8 x9 ?- i( dvolume 体积
( w3 `7 Y8 H! l6 Jdimension 维度
: j6 q$ Z" v. `8 @0 ldensity 密度4 m) A0 c' M; N8 p6 K
7 a0 j: I5 F2 B3 @/ Z$ g$ ?bearing 轴承5 P K: n( B; U( v; ?, e
washer 垫圈(华司)2 v6 v: o2 x K( s
spacer 垫片
6 N- E9 T0 _! F9 [" X" a/ [gasket/washer
: N7 c$ Y3 F% d) }3 y2 m" E1 f% V/ b& B% x9 m
spare parts 加持零件buffer# b& \1 V5 G$ ?& m
8 v8 g3 C( d8 i) _3 M( ^4 Lcutter 刀具+ L9 h @ ?- h$ Z3 c' A
friction 摩擦( T; C, j1 N- L' q ?5 A5 C1 Y. u% u& l
lubrication 润滑7 W H& S$ `* W
grease 润滑# G& K8 T2 }& V6 R7 V1 |4 U8 E
drive/transmission 驱动
/ h# J3 @$ k/ T+ U
0 ]# ~% S/ n8 {* Merror 误差
1 E- d8 o+ L( z2 |8 R- R6 zmistake 错误
5 K; f. r B$ d }
& u% m" b4 |8 ytransformer 变压器
& \$ w9 b: |" _allowance 余量) I1 l% ? ?1 l1 c& x
tolerance 公差 X/ K# u7 K& s/ s' b
interference fit 过盈配合
/ Z* Z2 ~3 Q3 V0 l2 C2 D5 L) lclearance fit 间隙配合/ p& J' K: q+ Y
transition fit 过渡配合$ H R f1 Y2 F, v% R0 W' }& m
roughness 粗糙度
4 B* T6 D4 Y9 Eflatness 平面度
3 \' G: `4 j0 d$ R# v, p) ostraightness 直线度
) l/ X ~5 p9 G3 z* L2 R1 kroundness 圆度
0 f. L) n; {& b6 m' ~cylindricity 圆注度
2 b. k: ?, Q3 ?" ]$ Y: ?. |profile of line
8 }- u. j( q) O; i9 _2 Aprofile of surface
9 L T- q9 m7 iperpendicularity 垂直度
, A6 g" ^7 i) G' Q6 o k& z oangularity 斜度
! Y9 A# {- @9 n. Rparallelism 平行度
- y- e# C* w4 j2 _4 G2 Pposition 位置度2 A4 e* g. J6 ~$ n
concentricity 同轴度
# ]4 {5 r. g X( H( wcircular runout 圆跳动/ [/ O: ~* t8 A( D! U/ k& R
total runout 全跳动, R% {6 q& ^2 u! c Y% p) ~5 Y
9 _6 z# M' C3 `0 `* Y* Q
" u4 n% V! H( B3 f6 y: \* Z% i( |
clutch 离合器
! `2 [' [( W6 t2 _1 b" z: rcoupling 联轴器
2 A o2 X0 q- n* I; L! d4 ?) \indexing table 分割器$ G9 s6 K/ T' }5 T
bowl feeder 振动盘* W) q9 r& B, ]# D7 {; I2 ?
+ ^6 p: U$ Z; Y p; p4 D8 nthread 螺线 helix 螺旋 screw 螺钉 bolt 螺栓/ o* c& \( J% a; k/ u) n) i
feed movement 进给运动
. |# A# p' U9 [rake 犁
3 {. O( U) h7 urake angle 前角) ?% w# e8 [7 W- W0 ]/ r1 _1 k
rake face 前刀面+ } K% G1 p# `* @# D
0 u7 q/ E# |! e& z2 f. {& E# Fclamping 夹具
( n; R7 b* ~: I* Nsleave 套筒 axle sleeve
2 ~5 D5 O3 k# K5 YSpacer ring 隔圈
* Y' i- U/ C+ B ?6 V- Q* O/ uchuck 卡盘/ M6 E1 ^; z* W; O. W1 O
fixture 固定夹具$ F9 W! |8 g% L: E& K' B
gripper 抓取夹具, S+ d( E8 l) I2 l
pallet 随行夹具
) m. ~, Y* h5 ^: d( F. Q
/ [5 J1 B1 r" b* n0 Nbenchmark 基准# H$ H6 p: n8 n7 W s' I; ~
locksmith 钳工
! x, l$ \2 B, N: y' C
! P1 e F* j9 cfluid 流体
( R3 V# z d' i3 `hydraulic
( \0 f8 b( t3 l0 G- b! fcylinder
0 b! Q( s' h Vpneumatic) ?. o" B" K* {" T- g# d9 H
pump 泵
$ p! `9 g+ W, `: w2 xphase 相, o. ~1 y. ?% O1 a0 {
valve 阀
' O. q2 D2 d; mvalve bank 阀岛
& D, C% u. C* m0 M$ H3 xsolenoid valve 电磁阀
2 a* P- {7 b/ X. qvacuum cupule 真空吸盘" e1 Q. O4 Q) z, ?9 @ y
suction cup 吸盘2 f- J4 \3 }2 H6 |% e
throttle valve 节流阀
+ D( q v- l- j% X0 _regular valve 减压阀
! A6 D7 i+ W" Q2 l! z1 m2 Ahose 气管 K* P' U3 ]! R7 ]8 n& e/ @9 n
medium 介质
3 ?$ a+ d3 J' S0 P- `2 w% ushock absorber 缓冲器* _0 r. N# y* |; Z: N0 Y9 g6 L Z
reed switch 磁性开关# ]0 n& J* z' U
coolant 冷却液
3 ~0 d% z5 j3 k) B
$ F- A" d; M/ g: v2 q8 h3 T+ [stroke 行程,冲程$ t. |& o: t4 E
seal 密封
7 c8 u% _# S: u8 u# zpiston 活塞
( B) j9 y8 N( K* inominal pressure 公称压力
$ e# ^1 O4 y" W; I# e& iaxis guide 轴套" Q" T- B0 G5 f+ [
flange 法兰
# ^. M8 r) F% d! Z' k3 \
1 \$ U! a; H/ B3 _& Rsubassembly 组件
( E1 O+ N! L' z" {part 零件0 I6 u, [5 Y+ u$ H, _
component 构件; ]0 |0 b* w. l+ m( H/ ^' m- U
diagram 原理图# ^! w, E* s7 @6 _/ I" E$ I
sketch 草图 draft
; n& D& a" f# G: p0 n2 V# }drawing 工程图( n0 c# V% [3 ~* T" Q' w4 v& C
protocol 草案
; [' A) n$ Q, |* V* A% W" s& Rprototype 原型
& \1 h( z- x0 g! b% T8 s
. b2 w: ^4 I) F9 Zsynthetic fiber 合成纤维5 e% ]9 |& ^3 Y) U$ ~% o* u+ D9 L
plastic 塑料1 ?5 B O0 M: _- z( x7 w. ~
rubber 橡胶
. Z/ z# o3 D/ H; \$ W( l& Aceramics 陶瓷
& J0 B* f, y) U5 E P t+ u# B% M. E, I# W- c
spline 花键2 M+ y$ [$ l3 w$ }
key 键+ L0 z- A( D2 q% y6 W# F; W; M: w( V
keyway 键槽! H( W9 W: ?6 ]" H% i2 m* Y/ Q6 B/ s
pin 销- N2 g$ _ l' x4 F
tapping machine 攻丝机0 e4 X# W- G9 Y+ x2 m5 U
screw tap 丝锥
0 `( m, \; q# b) }
6 N0 n6 s1 g; s/ c! y+ v: s& l7 bbrake/arrester 刹车- P; ]/ f5 \. t, l7 B4 S0 R
suspension 悬挂5 M4 E* n; @4 g4 e- V+ O- @
chain 链1 [7 R3 n4 y E+ S% Z. n
strap 带
* U$ ~! \) P1 o4 h" w8 _. K6 n! h6 ?. s
bush 直线轴承7 [* I- Y t& f& e0 [% Z0 r
lead rail 导轨
( v) y- E4 {7 Y- A" gscrew rod 丝杆
4 _, T- R4 Z6 B6 K# ?ball screw 滚珠丝杠
/ `6 f$ E3 C/ l+ {1 Ilinear rail 直线导轨3 e3 K6 h. I8 }
timing belt 同步带
. I* G# t( E% c' y9 vpulley 带轮
) O3 X O. d6 S" J4 V* T1 G; N3 Z* g+ K8 E9 G
finish machining 精加工: z. B% X# i6 r% f
rough machining 粗加工0 `( k! M/ Q0 Z( j2 G7 ?1 C
cold machining 冷加工8 t8 Z2 ], [) K# h
; L, L- y: Q( \% L/ g: k( Vspanner 扳手 wrench
9 b5 H$ |7 a M: T8 wpliers 钳
7 g! a( Q: B3 t' j# P( Gvises 虎钳
% k% S' D) p" F8 D5 z8 e5 X4 Z3 p, O8 A8 c
crank 曲柄' X( [+ m# N' Z+ Y, x/ X/ ]* I& l& C
racke 摇杆
/ m' X% ^/ J4 P; j1 @* ~9 Sgear 齿轮6 j w3 Z- f0 r6 z% k
worm gear 蜗轮( ~9 {! E4 b: @
gear rack 齿条' D: Q5 x# h& o* S, C
cam 凸轮
% I& f( B [4 a/ H0 ?0 u# X1 H
" P0 L7 e: s6 F7 g: E+ Xratchet 棘轮
' O$ R3 L" A/ @ s6 Bflywheel 飞轮) Y2 N4 l/ S9 o4 o# a. f
link rod 连杆+ z, n |7 d q' o _
# R! T6 y" w# X3 ^
vector 矢量+ J8 N H7 y% v3 j" b
scalar 标量
* Z9 G2 O: t6 C* Q. i# o3 uposition 位置
) H, E+ d+ Y% Z6 ~; H1 j/ cvelocity 速度 speed
t4 O! r- h& ]: xaccelerated 加速度( V( v2 t9 {. E9 r( Q9 z
. G5 n$ q& M! `* {& ~
patent 专利. k: k }8 d$ Y, w5 O
barcode 条码6 {/ ^+ D+ f/ T3 p. G, X# i
; ^$ u$ L# w. O5 b( C# V# |flow line 流水线
' e( n9 k2 w/ s2 s' Q8 Q4 Q; Hconveyor 传输装置5 n: h- }% e. j" ?( V" L
orientation 定向" V- y! S% v: @" e
location 定位6 l3 \: y4 w5 O0 x" @( g
picking 抓取, w% z% A/ y/ S4 C" \% d5 w1 L
sorting 排序
b& J0 a! E* A/ z1 y+ E% L d* a1 V& M* B9 M: Z9 |+ |* b* y" r+ `
feeding 进给5 u6 C. i4 t3 s# h {6 Q
loading 上料
: G: M0 q) }/ Z& t8 K6 Y. I0 w, u! v8 ]offloading 卸料
* {5 j h# p% Y. q( c& M" G
2 t' T, p5 `8 d/ S8 x* E/ d$ B @# L( Xrack 支架 bracket1 r3 h9 o. ?8 z9 S4 O; g$ t/ c
fine piece 落料+ E O$ Z8 z4 t& G- G$ k
coil stock 卷料; ?- V0 L) u; I8 D2 @+ p. H5 `
sheet stock 片料/ @7 _5 C% D! c" H$ B, y# c
, B& B- E* X# Y, w
responsible department 负责单位0 ]2 l0 h5 x! K( p$ g
censorship 审查机构
, s& N8 g7 b5 p9 Q$ j) G1 Garbitration 仲裁# Y6 P+ _" ]6 A' }+ w5 z6 f
Relevant departments 有关部门) H) o" e/ e+ z( z9 |
cosmetic inspect 外观检查' p# E4 e$ i+ [3 A4 p& m
qualified part 合格品0 [ C, {+ ]& ~! O5 W
rejected part 不合格品) X+ W$ z# V6 R, x! r
confirm 确认
9 H) F' ~6 G1 y! t! Icheck 审核6 _$ h: C& o3 V
approve 批准, ?# `8 y. X4 S& I+ T
6 C3 A* i% J! d2 }/ C, lbuzzle buzz 蜂鸣器6 x* b0 e5 V+ Y2 w* Q1 X7 |
wafer 晶圆0 h, c7 T& t$ ?- o% p3 y! Z! j" n
semiconductor 半导体
, T. M7 L- [( W6 e/ R8 Ztrailer long vehicle 拖板车7 |( w$ K6 ]- n5 @! t
single axis actuator 单轴机械手; x* N# S; {0 Q- t- P. m
SCARA robot 四轴机器人
; x, N+ I; \8 v8 n6 [* Wmanipulator 机械手
* W, {3 h( m( I3 O6 [ P" b: s O0 v: f# j' M P0 Y
curvature 曲率
5 v5 j( p) l0 {) U% c: dinertia 惯量
' _' R+ G) m& P, \; w' idomain 域" P# p& Y3 i# c0 g }. y
conjugate 共轭
" |2 n# f) |4 B# X5 Rrandom 随机
; q) j9 V9 B3 A/ W5 Csequence 顺序、序列) g" o/ s- ?7 W0 {. Q8 a. h
Statistics 统计
& J6 s/ x! t% [probability 概率
$ E7 a" f3 G# n. V0 u+ ^/ [( ?& ]matrix 矩阵
7 U0 }# ? w( ?( y2 q& o9 i' _orbit 轨迹
2 f2 P% [3 i. H/ E: G3 K2 f* ?$ yremote 远程 L N; a0 m2 Z4 O6 ]3 m
Modularization 模块化
( d! S- S, }4 x* w3 n1 D
8 ?6 H! O, }. u/ C! |( c* D0 k0 U& G" f+ a
" Q' O( ?" j. x. c& D M( q( A& a
- q5 I! j5 V7 c3 Q# [1 E E |
