发表于 2018-6-4 09:57:24
显示全部楼层
6 s* q: F& D# \8 T: G$ l" I9 y" J e
! P" M9 _1 Y+ z一个简单的宏程序供参考:- Option Explicit
# @* n* d% y- b& ^5 @3 b3 Y - Dim swApp As SldWorks.SldWorks
% v# m5 l' p4 |7 |; C( E. u) h2 V - Dim swModel As SldWorks.ModelDoc2
( G4 t# R1 [( O, `: H! D - Dim PartName As String$ Y% a& f* V7 X2 o: f% N
- Dim ConfigNameArr As Variant
9 C! \$ U6 W' |; [) ]( Y - Dim ConfigName As Variant9 q# R9 y* J/ K
- Dim AConfigName As String
* i; Y' E1 X* F* ~% @ - Dim FilePathName As String
" x' @1 ]1 n$ {7 r9 D - 8 p# X$ j6 _0 f0 r/ Y$ A0 V
- Sub main()) O- N. v+ T: w& N
- Set swApp = Application.SldWorks
! A, B1 x/ J0 u3 G1 y* ?4 f - Set swModel = swApp.ActiveDoc2 c; x# v- n7 J) ], d
- If swModel Is Nothing Then Exit Sub
, a1 {8 A. l1 r* u" f; q - If swModel.GetType <> 1 Then Exit Sub
1 A" n: V: u) D" I+ D$ ^ - PartName = Left(swModel.GetPathName, Len(swModel.GetPathName) - 7)$ K9 Y' ]1 e3 G! j ]* ]
- ConfigNameArr = swModel.GetConfigurationNames
3 l* g- F' }3 F - AConfigName = swModel.GetActiveConfiguration.Name% z3 d3 n5 F, h1 Q( p! t
- For Each ConfigName In ConfigNameArr7 y3 z% a7 n3 l4 B" q
- swModel.ShowConfiguration2 ConfigName
1 `" b, }" A% O2 n: w! b& I F5 O - FilePathName = PartName & " " & ConfigName & ".X_T"
, U( ]. T# H5 r - swModel.SaveAs2 FilePathName, 0, True, False; B2 k* k8 a* A
- Next7 J8 T( Q6 f1 u3 V
- swModel.ShowConfiguration2 AConfigName4 o; C u, J& i! |
- End Sub( H6 h9 ]) E. P* ^2 {/ v
复制代码 4 O3 _* |' P, X% M \
