查看: 3811|回复: 0
宏-草圖圓周複製後拉伸
发表于 2018-5-14 14:40:18 | 显示全部楼层 |阅读模式
分享在他網的回題小程式,適合想學sw API的初學者參考!
9 \8 S9 x' p( f. E& M9 E
  1. ' ******************************************************************************
    ' U  O. Q* `9 w
  2. ' macro recorded on 05/12/18 by scliang3 ?. [: F6 w7 i$ |6 F
  3. ' 功能:草圖圓周複製後拉伸
    ) G2 o1 t1 \) X" W- p9 b3 S" r
  4. ' 操作: 開新零件,執行 main7 Q. @6 X/ ~! ?" P& u
  5. ', J, E# B* `* _3 r
  6. ' ******************************************************************************0 S" y+ Y0 V: m/ t" o* I
  7. Option Explicit, D& m, B" c- e, R: R
  8. / m1 B6 ~# D) h
  9. Dim swApp As SldWorks.SldWorks1 T( C5 S- C. J: z
  10. Dim swModel As SldWorks.ModelDoc29 m. n0 j2 H6 b, l
  11. Dim swSketchMgr As SldWorks.SketchManager' a/ m) S* T; u% e- R: ~
  12. Dim swSketchSegment As SldWorks.SketchSegment
    ' k% ^7 C/ u2 ?  \2 ]+ j! x
  13. Dim boolstatus As Boolean. F2 r0 E: i8 O. d; k
  14. Dim Part As Object* Y2 }2 X9 U) F
  15. Dim myFeature As Object% @: ]5 W" Y$ D
  16. Dim pi, ArcRadius, ArcAngle, PatternSpacing As Double
    " |: @% h: y/ J; o6 _
  17. Dim n As Integer' h1 U. ?) r9 e- S6 U0 j8 o
  18. $ T! }1 n% x& y
  19. Sub main()
    6 o& w; m2 ^8 D$ ]3 Y0 h
  20. ( N( O5 e1 A6 I) D+ x* q2 ^
  21.     Set swApp = Application.SldWorks
    % B$ K- q/ H+ k" O/ Z" g
  22.     Set Part = swApp.ActiveDoc
    2 m; J& m3 y) m3 l+ z
  23. ' Create part document
    9 ~' b% S, Z. B$ v3 q% Z
  24.     Set swModel = swApp.ActiveDoc
    . A' q, O! R1 I0 ?/ s5 s
  25.     Set swSketchMgr = swModel.SketchManager
    4 b2 }/ N9 q" Q! G. y" o* \
  26.     pi = Atn(1) * 4 '圓周率
    - X4 B" S* v+ @; e2 [  ]" p4 P% s. F, a
  27.     ArcRadius = 0.05 '圓弧半徑
    . F( R) p+ L$ N4 U8 s
  28.     ArcAngle = 300 * pi / 180 '圓周中心之圓弧角9 Q4 l/ L. j  g
  29.     n = 5 '複製數& L  T: ~6 Q, O' U
  30.     PatternSpacing = 40 * pi / 180 '複製之間隔弧度/ A" W) \9 R. P. b9 b/ N8 Q2 w' {
  31. ' Sketch a circle
    " |4 Y+ ]* F. k3 D5 E6 t( k
  32. 'boolstatus = Part.Extension.SelectByID2("前基準面", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
    4 S: I( m1 T3 c& p. {: O( i
  33.     swModel.ShowNamedView2 "*Front", 1
    , }0 I; f5 I4 _) Z$ s
  34.     Set swSketchSegment = swSketchMgr.CreateCircle(0.01, 0.06, 0#, 0.01, 0.07, 0#) '畫圓
    : F  {" Z1 E3 l! D7 ?! g. I1 T. ~7 r
  35. 'value = instance.CreateCircularSketchStepAndRepeat(ArcRadius, ArcAngle, PatternNum, PatternSpacing, PatternRotate, _# t8 U4 e$ y# S
  36. DeleteInstances)圓弧半徑、圓弧角、複製數、複製間距(+ 間隔弧度正轉,- 間隔弧度逆轉)、圖案旋轉、刪除實例
    & q" e! C, ]$ z) _7 u/ t# r
  37.     boolstatus = swSketchMgr.CreateCircularSketchStepAndRepeat(ArcRadius, ArcAngle, n, PatternSpacing, False, True, True, True, True) '圓周複製
    1 a! n# c6 y2 g% x0 n! I( i. y- Q
  38. 'instance.FeatureExtrusion2(Sd, Flip, Dir(反轉方向), T1, T2, D1, D2, Dchk1, Dchk2, Ddir1, Ddir2, Dang1, Dang2, OffsetReverse1, OffsetReverse2, Merge)
    : o3 x) W* q7 C7 H( q/ k: b
  39.     Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.03, 0, False, False, False, False, _
    5 ]9 `1 M6 h* J0 y$ u
  40.     0, 0, False, False, False, False, True, True, True, 0, 0, False) '拉伸 30mm
    + r+ e# ~) W( i" Z" E# W
  41. 7 |. D: Y8 Q4 u+ f* U
  42. End Sub1 P3 h8 y' d8 t' L  e/ P/ x
复制代码
/ L2 n" x8 q7 q4 |
, ~( t+ f; K( U+ A5 X/ r5 Q4 F: T; U
& b* M$ M0 J' V3 C
- x( p) m) [' B" v
, i; v8 |) r- w( T1 L. B
您需要 登录 才可以下载或查看,没有账号?注册会员
参与人数 1威望 +50 收起 理由
吉吉几几 + 50
GMT+8, 2025-10-16 20:01 , Processed in 0.062577 second(s), 17 queries , Gzip On.
