查看: 5812|回复: 19
Advanced Concepts of Bearing Technology
发表于 2008-5-30 16:02:15 | 显示全部楼层 |阅读模式
5 O+ Z0 y% E; b6 O' \
+ O/ R- R0 P; J; M# ~第五版
* C& n. x6 j% i8 _: i' I. s9 K0 a# |  b& W
CRC出版% g9 @4 v; q$ z( o$ o3 z" S& }
1 T& ^) Z9 \' z- v% ^" _: k- a9 P[ 本帖最后由 ivantse 于 2008-5-30 16:30 编辑 ]
 楼主| 发表于 2008-5-31 11:16:14 | 显示全部楼层
作者:Tedric A. Harris, Michael N. Kotzalas
' c: [( U2 _7 f+ U8 G6 Y* i( h1 g/ K  e- n
书名:高级轴承技术概念(滚动轴承分析)第五版* Q' x0 f! O/ b0 `9 ~) s
8 `, [0 y9 t9 X+ i; m
"Advanced Concepts of Bearing Technology (Rolling Bearing Analysis, Fifth Edtion)"- l( }/ t9 u& x2 f, x* U3 i4 H
) c# P+ V8 m, C8 K8 NFor the last four decades, Tedric Harris' Rolling Bearing Analysis has been the "bible" for engineers involved in rolling bearing technology. Why do so many students and practicing engineers rely on this book? The answer is simple: because of its complete coverage from low- to high-speed applications and full derivations of the underlying mathematics from a leader in the field. The fifth edition of this classic reference is divided conveniently into two volumes, each focused on a specialized area of bearing technology. This option allows you to select the coverage that is best suited to your needs. The second of two books, Advanced Concepts of Bearing Technology steps up the level to more dynamic and complex loading, more extreme operating conditions, and higher-speed applications. The authors examine several topics that are unique to the book, including mathematical relationships for internal load distribution under conditions of high speed, combined radial, axial, and moment loading, as well as the effects of raceway and roller profiling. They also delve into the mathematical development of rolling element-raceway lubricant film thickness and contact friction, the stress-life method for calculating bearing fatigue endurance, and the effects of shaft and supporting structure flexure on bearing loading and deflection. Advanced Concepts of Bearing Technology is the perfect aid for analyzing complex performance and fatigue-life phenomena in advanced applications.- P6 T3 O/ G1 \# I( f% W! y5 T
) A# H# U" o; `+ L' L9 T[ 本帖最后由 ivantse 于 2008-5-31 11:17 编辑 ]
发表于 2008-5-31 23:06:33 | 显示全部楼层
感谢,不过,第一部分缺第三节.
 楼主| 发表于 2008-6-2 08:46:30 | 显示全部楼层
不好意思!0 d/ \" S. m/ j% k' \* X% L& Q
" x* [1 g% \: S4 }& H) S补上
发表于 2008-9-2 18:45:20 | 显示全部楼层
  终于找到了!!!; t/ i5 v' E% m; E' a+ q
伊凡,你太好了!!!!
, F$ @2 g4 C6 a" I$ v. d感谢阿 !!!
发表于 2008-9-24 01:01:59 | 显示全部楼层
很高深,下载收藏,呵呵,谢谢!!!
发表于 2008-9-24 17:34:26 | 显示全部楼层
呵呵,又见到你发的好东西了。
 楼主| 发表于 2008-9-26 08:41:51 | 显示全部楼层
现在由于工作性质,没法常来社区了.以后有机会就多发一些有用的资料!
发表于 2008-12-27 10:03:06 | 显示全部楼层
非常不错,经典之作
3 f8 Q0 C0 b0 O感谢分享
发表于 2010-1-11 10:54:21 | 显示全部楼层
太好啦 !!( S' @# S, ^2 H2 |( P
感谢感谢!!
GMT+8, 2024-11-19 05:45 , Processed in 0.059875 second(s), 17 queries , Gzip On.
