查看: 2733|回复: 3
米其林轮胎工厂维修间用的美国CLAUSING 牌车床,带索尼光...
发表于 2017-11-2 20:42:56 | 显示全部楼层 |阅读模式
本帖最后由 王树大 于 2017-11-2 21:53 编辑 6 `/ _2 _+ ?2 W
% S  F4 @! g7 V! V% J
带有这是美国
回轉直徑:
330.2 mm
頂尖間距:
762 mm
主軸孔徑:
41.28 mm
功率:
2.2 kW
[tr][/tr]
2 f. x* y% d& V" f3 Y7 e" Y% K
主軸轉速:
2500 rpm
橫拖板上最大回轉直徑:
171.4 mm
尺寸:
65"L x 34"W x 48"H
重量:
2,250 lb.
1-(used) Clausing Metosa Model C1330 13" X 30" Engine Lathe, New 2003.
SPECIFICATIONS: * m* c! B5 C, ~8 r
Swing over bed............................................. 13"
2 g' f* D) \$ S. a& q- zSwing over cross slide.................................. 6-3/4"
# h, Y1 L$ i7 H" j6 O. E9 O/ EDistance between centers................................... 30" ; D$ q$ ]1 x" p' }: g: O" _( h
Spindle bore............................................ 1-5/8" 1 X5 g# c3 u- `8 J& u6 S) j
Spindle nose............................................. D1-5"
' v- a& T5 ^( P+ Y. n# jSpindle taper............................................ #4 MT
& K. O; h* m  [9 e* j9 K9 NWidth of bed............................................... 10" . ]5 K9 i, q0 @& z
Spindle speeds (9)............................... 75 - 2500 rpm
4 T3 u! d4 H0 }& M7 w! VLongitudinal feed range (44)............... 0.0018 - 0.0264 ipr ( I% [: B: z0 u% _, \& N% o/ B
Cross feed range (48)...................... 0.0005 - 0.0076 ipr & p  Q( F# R2 p2 D: @8 m
Threading range English (44)........................ 4 - 60 tpi
( x3 o/ W; q: @" UThreading range Metric (44).......................... 0.5- 7 mm 1 E0 r$ o" v" \9 Y
Tailstock spindle travel ................................... 5" + d0 s6 D  b' [6 F7 O
Tailstock spindle taper.................................. #3 MT & b$ N, ]! _8 w. F% _7 q
Dimensions (approx.)........................ 65"L x 34"W x 48"H * x) I1 `1 O# b' N  W
Weight (approx.)..................................... 2,250 lb.
EQUIPPED WITH: 5 y' b3 R. `  p
8" 4-Jaw chuck 6 h* }8 Z: V; y7 _. X& R! P" ?
12" Faceplate
# ^  i3 g: \! X$ z2 O8 fLever type 5C collet closer
+ e+ G- P# }0 x' D3 ~Steady rest
! Z6 R9 P: u8 ~) e2 z' qQuick change toolpost
: j3 c# w9 ~2 K7 e4 L9 J1 @: ITrav-a-dial for longitudinal carriage travel
1 @: d( w. J  u  Q1 fThread dial indicator / Q0 J+ {& t/ O3 S  v" E2 s5 k- q
Full length back splash guard
; F) A9 j0 d: ~Coolant pump and tank
% g  v' G3 w, r9 }7 d# o/ mHardened & ground bedways ' U4 a, _5 q6 E! v  c) Z
3 Horse power main motor
http://www.agreenco.com/ClausingMetosaC1330-2174.html
发表于 2017-11-2 22:03:19 | 显示全部楼层
这种老古董可以拿来珍藏了
发表于 2017-11-3 03:19:29 | 显示全部楼层
这公司停产了吧
发表于 2017-11-3 05:31:30 | 显示全部楼层
这个床子不错
GMT+8, 2025-2-25 09:39 , Processed in 0.055701 second(s), 15 queries , Gzip On.
