Acme CAD软件可将DWG、DXF 、 DWF格式转换成WMF, BMP, GIF, JPEG, PCX, TIFF, PNG, TGA, DXF, DWG, SVG, SVGZ, CGM, EPS, PDF,HPGL 格式……) x5 h- I' ~9 V8 y
(Acme CAD Converter is a format conversion software for batch and vector files. It can conveniently convert DWG,DXF and DWF files into WMF, BMP, GIF, JPEG, PCX, TIFF, PNG, TGA, DXF, DWG, SVG, SVGZ, CGM, EPS, PDF,HPGL etc., and also enable the conversion between DXF and DWG file versions (AutoCAD R2.5-R2008).Supports eTransmit command like AutoCAD,and batch recover drawing files. ) |
