1924 Gustav Overbeck, master of mechanics, opens a workshop for precision engineering in Herborn. , g: X; B# O2 ^7 y+ x \! Z
( T! T$ {3 ?5 f+ V! _. M, F+ K) y
6 {6 _6 ~5 x [! k. W. X! `. a( {/ f1934 The Overbeck company receives big orders from the aircraft industry. Based on the orders developement and technical improvement of the Overbeck special drilling and polishing machines are attained. ! W; U0 R; j3 n1 s5 _
9 {4 q: S6 v& w: s7 M' Q( \
0 W" j, W+ i( D6 a! w1969 The production programme consists of internal and external grinding machines and transfer lines. Electro-hydraulic operated grinding machines, standard machines or fully automatic machines, are controlled by new developed devices. The high precision Overbeck grinding machines on high technical standard are supplied to many big projects abroad. Overbeck has a good name in the world for high precision and technique.
* l' x- {* l( u6 u( r
5 C, q& X! L, e4 L# Y) A
& M" N. T, _ t; G7 E1975 The manufacturing programme is expanded. The new precision external grinding machine type 600 R, to be quoted for all kinds of automatic production, widens the possibilities of the Overbeck precision grinding machines.
I1 F: T+ p* d$ W
% r0 ]& k6 C( d3 q3 R/ A2 g 6 K- A; q7 z; |8 J: v6 I' W
1977 The series of internal grinding machines 250 I / 400 I are expanded with the 600 I series. By this series Overbeck now can quote internal grinding machines up to an internal grinding diameter of 250 mm.
9 z% p. w6 o3 ~" UThe series of internal grinding machines 600 I can also be quoted for all kinds of automatic production.3 d. T* S7 u, T- f
]( V( a# J* `) c; c
" l* V% A4 ?8 Y) R- ~9 e/ [0 H2 D , R# t) y4 Z7 i, O
1978 A grinding and drilling machine is developed and integrated in the manufacturing programme, a machine for universal use with tool shops and mechanical engineering. 8 Z/ o8 E3 H: X y6 S& C& L+ `
* U6 c0 A0 T8 J4 R$ A
3 h* J/ @2 ^) y1 u: O$ X5 K3 r* M1988 Development of special grinding machines for the bearing industry (Flange Grinder). ' x8 }/ A( B* E) k: w% g+ w
1 ]$ F" f0 N8 D) _2 @
0 w) H2 Z) f, S' _1990 Development of NC external grinding machines, fully automated, for diesel injection needles.
3 B4 A \8 w! f' r ( M+ O7 X* O7 j+ K
+ c- a8 N8 y: }' a, p" O4 m* s1995 Develop of new internal grinders product range series IC. ( |7 v4 Y8 _( {9 [3 m; |
% y6 z- U0 Y/ ~. I- ^
) t6 G: B1 G% ~! g' M: ?# D1998 Development of high speed grinding machines 140m/s for gear shafts.
6 ]9 o! g( S; n2 s9 c5 H
* F3 T( u: X4 H0 r4 K
! v1 C, p+ k7 L/ [3 W0 j2002 Overbeck became part of Danobat Group. / z# o$ h' D5 r% g) u7 ~$ j
/ W* h, T A/ c r$ x6 V" B
1 P6 D! ^3 {+ O: [. C2003 Market the new linear motor grinding machines, for application in horizontal and vertical grinders ID, IEV models. |
