查看: 4131|回复: 4
有几个句子需大家帮忙一下
发表于 2008-1-3 23:01:51 | 显示全部楼层 |阅读模式
这是包装挤压试验的结果3 F  u4 C) D9 {- E1 S
Boxes are strong enough to handle double staking for a round trip ( z3 |3 T0 X8 L4 v/ `
Skid did not pass triple stacking test. Triple staking unlikely because stack will not fit in trailer。! p& t3 X4 S% Z7 A* H
这是防止贴错标签的措施Our procedure is to obtain a part out of the container and match the skid label to the part number on the part. This avoids having the wrong label on the skid.: F$ M# h3 A: T( u% U
To avoid having layers underneath with a different part number, partials are covered up.
. Z# e7 _; h9 [* f这是包装破坏性试验的结果$ V, [* H% m# ]/ e2 \8 p) G- F
The results of this last test shows that the paint did not chip off with Packaging Iteration # 2. Placing the parts in bags saved the paint from getting damaged Test per ASTMxxxx0 C1 I% {4 ^" m2 r  T' F
7 [3 n/ j! c2 ~
有关质量控制计划Q:What would be your quality breach reaction plan?( V* F6 P/ k, E/ R. q7 D
A:Contain parts at our facility, in transit, at customers warehouse and production line.
发表于 2008-1-4 09:17:00 | 显示全部楼层
提醒:非包装专业人士,回复仅供参考,另如你已得正确答案,麻烦您将答案做回帖,谢谢!!!
, ?- R& b6 G3 ]& L) Q: @5 ]3 A, B
: r2 r- j; V$ L; ^. v因为语境不详,先举Phrase以供理解:5 u. T4 N; B8 Y1 y
+ f! L/ }" E' A- K5 u& h
包装挤压试验的结果5 X7 @" j" d1 A% a8 M1 f4 U! x- Q
Double Stack双层
' W3 m$ T) m- B3 C( N! H+ k4 I: ^a round trip一个来回(往返)7 q$ t6 q# u% X: {% u. T
Skid垫木
, S& M+ i( E4 htriple stacking三层堆放+ m2 V8 B0 r9 ^6 o- `/ y
trailer 拖车(垫木)2 l5 x) p1 d6 h$ e4 v4 v! m
参考:处理双层堆剁一个往返,箱子是足够结实的.垫木没有通过三层堆垛实验, 因堆垛不适合Trailer(拖车???)不太可能实现三层堆垛.
2 F/ b+ s. B8 u3 c4 e9 a7 O: B8 I. k/ E% C+ K  `4 f
防止贴错标签的措施4 F" q2 v! o  i) S9 D7 p# @
layer垫层/ c; u* R3 Q: J
参考:我们的程序是将一零部件从包装中拿出,并将垫木的标签与零部件的型号对应,以防贴错垫木标签.覆盖"Partials"来防止下方垫层有不同的型号.
# i" ~) b1 w- h# j8 F3 x+ y: h6 a9 Z6 b
包装破坏性试验的结果
" }) J' Y" V6 O$ d/ X" Y参考: 上一实验结果显示表面漆未与"Packaging Iteration"一起"chip off(剥落?)".测试依据ASTM标准XXX,将零部件放入袋中以防损失.
3 Q7 S9 ?. ^( b( ^5 `: N3 N
' P( G8 g/ [( N4 O* }1 W$ H9 y质量控制计划
8 E/ ?. u0 {& j, |# E* hquality breach reaction plan质量问题反应计划
: _  I9 I- Q, H1 h- S" M; @contain控制) M$ {. \3 ^; k4 i! R
参考: 问:贵司的质量问题反应计划会是怎样? 答: 在我司工厂, 运输至客户仓库及其生产线途中控制零部件.0 u8 s& Y& s/ g( w( x' ^) m. ~% c
* b$ F6 C! b+ Q[ 本帖最后由 ivantse 于 2008-1-4 09:22 编辑 ]
 楼主| 发表于 2008-1-4 12:45:49 | 显示全部楼层
skid 可翻译成栈板
 楼主| 发表于 2008-1-4 12:48:22 | 显示全部楼层
skid 可翻译成栈板
 楼主| 发表于 2008-1-4 12:50:47 | 显示全部楼层
回复 2# 的帖子
skid 可翻译成栈板
GMT+8, 2025-4-25 12:59 , Processed in 0.060175 second(s), 14 queries , Gzip On.
