查看: 8301|回复: 6
求助-国内有没有什么材料可以替代 Weldox 700 Steel
发表于 2008-1-3 16:48:14 | 显示全部楼层 |阅读模式
大家知不知道国内有什么材料可以替代 Weldox 700 E的材料?具体的化学成分和力学性能见附件
/ U5 _+ `5 ], [# u" B0 s8 P! Q- m
" Z( Q! a; D* K3 J是一种高强度耐磨钢,屈服强度可以到700 N/mm2的钢板
$ u# ]4 r+ U, l4 m  ]
: k: _3 ]( w6 X, A& ~! C 网上找到的资料如下:" m3 w. P8 r4 A7 |  V0 v* |, D
2 e- Q' c) P' q9 i8 ~# q& P$ ^
WELDOX 700 is an extra high-strength structural steel with a minimum yield strength of 700 N/mm2. WELDOX 700 plate is used where its high strength can give weight savings and/or increased loading potential.) y* @( x$ l% \* Z
WELDOX has good cold bending properties and very good weldability. WELDOX 700 E, which has guaranteed impact toughness down to -40oC, is held in stock by the Plate Service Centre.
发表于 2008-1-3 17:00:33 | 显示全部楼层
Weldox 700 Steel
Material:  WELDOX 700  4 q3 }. @2 o" k4 _) S; X/ W3 y
  标准:   PROPRIETARY
7 j% R7 b! I3 a0 P结构钢   SSAB
发表于 2008-1-3 17:04:05 | 显示全部楼层
Weldox 700 Steel
材料牌号: WELDOX 700
3 E& j# ~4 |' x标准: PROPRIETARY ) I  C, ^, h0 C( F( s; k1 z, P3 `5 Y
国家与地区: - 5 N/ t; X' r; |( M% z' ?
钢组: 结构钢  $ d% ]' Y' q' Z8 f4 s  |1 {
产品:  SSAB
/ Y3 N+ Z2 S9 v! v4 B: m7 A6 c 用途: Dumptrucks, mobile cranes, loaders, industrial trucks, lorries, trailers, bulldozers, excavators, forestry , buckets, cranes, railway waggons, dolphins, penstocks, pipes, bridges, steel buildings, offshore structures, fans, pumps, lifting equipment etc.
 楼主| 发表于 2008-1-3 17:24:49 | 显示全部楼层
谢谢JK090909的回复,但是国内有没有其它材料可以代替的。SSAB这里我问过了,起订量要100Ton,太多了。& R- u6 P& B, U, A8 H' z7 R
所以我想能不能找国内材料相似性能的钢板代替。
发表于 2009-12-7 15:13:57 | 显示全部楼层
HAOHAOXUEXIYIXIA
发表于 2010-6-1 10:47:57 | 显示全部楼层
发表于 2016-4-2 13:26:05 | 显示全部楼层
DOMEX700 - `7 x$ n! L0 H: F! `7 W
或者国内BS700
GMT+8, 2025-2-22 23:54 , Processed in 0.053982 second(s), 15 queries , Gzip On.
