alloy tool steel 合金工具钢 aluminium alloy 铝合金钢
' m5 l; @$ \1 J/ j. k% [' f. l# E* B% s' @ G
bearing alloy 轴承合金 blister steel 浸碳钢
% _3 S+ B5 C7 F/ b/ I
# j' u8 Q: Q; pbonderized steel sheet 邦德防蚀钢板 carbon tool steel 碳素工具钢
- B! X! B" K M' W
- }; x8 Q c N+ K' Iclad sheet 被覆板 clod work die steel 冷锻模用钢
- w- E7 T4 V2 A" ?+ ^. d, {, b: O
emery 金钢砂 ferrostatic pressure 钢铁水静压力
5 H) ~3 j6 g* |: a# ?: S& S. ]) I4 P* d% I- y" A: N
forging die steel 锻造模用钢 galvanized steel sheet 镀锌铁板 ) C2 b8 y5 s4 |: t+ K u; Q
i9 {) w; y4 C% u, Bhard alloy steel 超硬合金钢 high speed tool steel 高速度工具钢 9 P7 ]/ v( h# H* x
5 J5 U0 z4 p9 f% ~" E( w0 `, Z
hot work die steel 热锻模用钢 low alloy tool steel 特殊工具钢 5 |9 l$ b7 w$ \$ j( G" Q- I- e
7 ^! k8 D- N! f1 P8 G" [
low manganese casting steel 低锰铸钢 marging steel 马式体高强度热处理钢 ( _2 ?' V0 X$ L, t) `9 p7 H# o7 e
% D' D, ] [' m# O0 H u
martrix alloy 马特里斯合金 meehanite cast iron 米汉纳铸钢 $ J, a$ v: n- I( u3 P. g: V
! s Z2 P q9 G; Y- s4 D+ T
meehanite metal 米汉纳铁 merchant iron 市售钢材 / \1 m7 G1 j3 C" m6 A
2 z; D6 M- H, z- x- X3 kmolybdenum high speed steel 钼系高速钢 molybdenum steel 钼钢 9 k+ J+ r4 P |0 |8 F' K3 ^
9 L; w! _# T) v& q6 a* m# O1 [nickel chromium steel 镍铬钢 prehardened steel 顶硬钢 ! e& m. h+ W7 S% C; L
l+ z! D: g/ H" L; o
silicon steel sheet 矽钢板 stainless steel 不锈钢 : C1 R( ?! r1 O$ P
) j" F. d8 I6 y% ~8 @3 s+ g3 q
tin plated steel sheet 镀锡铁板 tough pitch copper 韧铜
2 _5 W& A# [$ P6 {! i" i! ^2 }% d5 w Q+ P% x# [) c
troostite 吐粒散铁 tungsten steel ?钢
& T0 T* R% J0 {7 H; M9 T j& s7 f3 P& }$ N1 \0 t7 |2 R
vinyl tapped steel sheet 塑胶覆面钢板 |
