楼主: 望海的日子
misassembled是什么意思?
发表于 2007-12-7 11:03:39 | 显示全部楼层
cannot  be  misassembled ,不允许装错
发表于 2007-12-8 16:35:34 | 显示全部楼层
.$ |- U4 z, q- v; H9 |1 B: a
- o. |  p4 J2 T& B
/ b1 [$ ?, W. \- P; f- w# e  P) n# K' a/ L0 u
* W, A8 C5 r8 m# a  y( O& _: F大家知道吗,disassembled 是卸的意思,可能想表达该含义呢
发表于 2007-12-8 19:10:11 | 显示全部楼层
they also  shall be constructed  so  that  the  indicator  cannot  be  misassembled
: L7 L0 T  d# ~- nto give  an  incorrect  indication  as  to whether  the  valve  is  open  or closed0 z+ t, u) K6 j3 e5 d
从后面incorrect 看出是错装
发表于 2008-1-1 10:51:35 | 显示全部楼层
原帖由 睿智 于 2007-12-8 19:10 发表
6 F8 v' Z( d' }9 l$ K- wthey also  shall be constructed  so  that  the  indicator  cannot  be  misassembled 3 k8 l" w0 l* F4 N7 ]1 s1 S/ A
to give  an  incorrect  indication  as  to whether  the  valve  is  open  or closed" d4 y1 k' ]- f8 x5 h* P% k
从后面incorrect 看出是错装
) S# Y1 k0 f; i4 u3 X! B8 i) N$ }" @
试着翻译下,为了避免指示器显示阀门错误的开闭状态,指示器不允许装错,应该制作他们(某几个特征?猜想是便于装配时定向或防止混淆的零件特征)。
GMT+8, 2025-4-25 13:11 , Processed in 0.053356 second(s), 12 queries , Gzip On.
