查看: 3079|回复: 8
AGMA 2001,2000,2007
发表于 2007-11-28 17:03:00 | 显示全部楼层 |阅读模式
Gears-Surface Temper Etch Inspection After Grinding
 楼主| 发表于 2007-11-29 11:53:41 | 显示全部楼层
Tolerances And Measuring Methods For Unassembled Spur And Helical Gears (Including Metric Equivalents)
 楼主| 发表于 2007-11-29 11:55:25 | 显示全部楼层
 楼主| 发表于 2007-11-29 11:56:36 | 显示全部楼层
 楼主| 发表于 2007-11-29 11:59:15 | 显示全部楼层
Fundamental Rating Factors and Calculation Methods for Involute Spur and Helical Gear Teeth
 楼主| 发表于 2007-11-29 12:00:01 | 显示全部楼层
发表于 2008-6-21 12:12:21 | 显示全部楼层
这段时间正需要这些资料,半路出家学AGMA标准及减速机设计,及时雨啊!谢谢楼主的奉献
发表于 2008-7-26 11:45:25 | 显示全部楼层
谢谢楼主共享
发表于 2010-6-1 11:08:10 | 显示全部楼层
ding~~~~~~~~~~~~fafafafada
GMT+8, 2024-11-24 13:42 , Processed in 0.050104 second(s), 17 queries , Gzip On.
