发表于 2007-10-25 22:00:34
显示全部楼层
TAD721VE
下载地址:8 C0 n; w* n* N/ r5 G
http://www.volvo.com/NR/rdonlyre ... 33EC/0/tad721ve.pdf/ N9 c& W+ s0 K' N. }1 C, r3 @( q
是Volvo的宣传资料。8 B4 q- K- V: |; c/ H; h
9 h z$ Q0 I1 I a+ EEngine designation....................................................................TAD721VE$ ]8 f. ~; v! ^/ c% s' e: ~' @6 }
IFN Power at 2300 rpm, kW (hp)..........................................195 (265)
7 ~$ C* p$ k. y, j- r7 |ICFN Power at 2300 rpm, kW (hp).......................................176 (239)" o6 x) `! t8 }2 H% f) M
Torque at 1600 rpm, Nm (Ibf ft)..............................................907 (669)6 T6 L. U) n2 z7 l
Displacement, l (in3)..................................................................7.15 (436). M% K/ C) z, t
Number of cylinders..................................................................6
' K& @! o" J) `6 L- ~Bore/stroke, mm (in.).................................................................108/130 (4.25/5.12)$ L& a2 b) b1 ^7 y E
Compression ratio, EU stage 2 / EPA Tier 2......................19.0:1 / 18.4:1. m; U, H/ ^' c
Dry weight, kg (lb)......................................................................680 (1500) |
