发表于 2007-10-16 15:52:24
显示全部楼层
cs154
Colorite Polymers CS1542OR Wire and Cable Jacket Vinyl Compound
0 P. {3 \1 e0 L! j Return to last search 6 ]& c1 |' D$ x" I" q
$ K3 ], W/ Q' @- }* \ Printer friendly version Add to Folder:
( _. s% W( @- b' ]3 n0 o Download to Excel (requires Excel and Windows) Material suppliers 1 x7 [4 u( i, v# y: M8 o6 s
) \# J# o; F& {3 @# [* S3 B6 I/ j- d9 k1 S% I, c- L5 A+ F
Subcategory: Polymer; Thermoplastic; Vinyl
" b# C& F" Q- O+ }- W8 q, |
- \3 [' z- g: }& @/ `" G2 ]Material Notes: , D" p4 v ^& }' f
Description: Colorite specialty wire and cable compounds feature low smoke properties, excellent flame retardance, low temperature flexibility, and resistance to abrasion and chemicals. All are available in UL and non-UL grades. In addition, the engineering-grade thermoplastic elastomers we offer can stand up to the most demanding applications . . . while providing the most desirable performance characteristics at a cost that?s more affordable than ?ordinary? elastomers., B( W0 |; @2 ]* h% P' n
# o) C2 y3 r, v! J; \8 F/ K
Typical Applications: SPT, SJT, SVT. Nonmigrating and oil resistant.
( a! L4 k4 a# G X W" F
( K) y! H9 b8 P. d9 q/ |! T% BInformation provided by Colorite Polymers.
, D" c& k2 u/ N: \: n) m6 q3 g N. h; V9 Y3 N( r
' M7 E$ L* D$ xClick here to view available vendors for this material.
% B5 j4 _; C k7 [& H' \5 e. v7 O: V+ S* j
Physical Properties Metric English Comments $ ~$ U* M& W1 Y* z% r9 X
# [' N! w/ q1 U1 a * L+ R4 y) O) F7 g6 c1 |
Specific Gravity 1.42 g/cc 0.0513 lb/in? ASTM D792
& i4 s! x9 a* A ]0 `Loss On Ignition 28 % 28 % ASTM 2863 . K( M+ T' f1 R+ }5 ~$ L; }* o* h' ]
( l1 n! _! n# x6 U+ Z" ZMechanical Properties ) y' c7 k W2 }# ^/ q k( X4 {6 H2 ~
; g; g9 i8 @, w' H
. b, }( k" x- K; P- S; ~9 N2 s
Hardness, Shore A 80 80 10 sec; ASTM D2240 + {+ }4 l/ x9 {+ ^) j0 R. b# ~ Q
Tensile Strength, Ultimate 15.5 MPa 2250 psi ASTM D412
v' V8 g: s8 R6 V! w, A- F8 I4 F2 ~Elongation at Break 290 % 290 % ASTM D412 ; V5 r7 r* f/ f- H, B) C q; U
8 B/ G! X4 u9 \7 k2 LThermal Properties 4 M9 W+ m4 {1 S1 f
9 c- G; p5 K' y, {
: ]. e4 A$ u# i5 V
Maximum Service Temperature, Air 105 ?C 221 ?F
3 ^8 {7 l! Q9 M1 \$ R5 @0 RBrittleness Temperature -25 ?C -13 ?F ASTM D746 |
