7 x Z+ q% ?( c, g+ @+ U. D6 P8 y | 钻, 铣, 磨, 雕刻机床( j# s e: m8 x6 J9 `
| Applications
) _) `: K2 k! ]! W. V | Drilling, Milling, Grinding, Engraving5 O0 I( J& @; s, c$ H5 ^# z
外壳夹装尺寸
2 q8 }! b! o. @5 |0 E/ ? | 60 mm: I1 Y! v( j2 |
| Clamping diameter
0 @# ]7 r: i- g- @ | 60 mm
5 d( V& v: d& ?; ` |
马达类型
# q5 c/ x/ ] s2 B7 F1 p) N& [- k | 3 相异步高速电机
* Q! y5 {' O7 R& c, F& R7 B | Motor system
/ w/ C) ]1 d+ k- G2 X5 ^0 w | 3 Phase asynchronous motor
' o+ X4 s" y1 C& r% W |
转速范! J; ]6 Z6 C+ S. S+ P+ ]
| 3,000 – 24,000 min-1! [" C/ D/ j6 Q# f6 i
| Speed range
+ \# n* F; ?9 L! }1 q | 3,000 - 24,000 rpm
9 H9 L; @- a" W3 x: m |
额定电压. p% Y3 l/ b6 D5 E8 s" p! v
| 220 V
4 s! o4 n( h0 R3 `7 Y | Voltage
& h; U7 C) |, T _5 J# m | 220 V
+ [) X% L5 [4 k1 c; @ |
电流6 |. T2 c; I, t+ X! x5 L
| 最大 14 A, ]3 M9 c; ?8 r0 n- G4 n( s: z; d' y
| Current
- `# P6 R/ T5 V- e; q | max. 14 A
; j' ?/ z3 f5 A7 a |
扭矩9 ~! e: w* p: y1 d. B
| 最大 215 Ncm( B3 O7 k! K* z1 X8 l7 E" h& E2 f6 z
| Torque
: O& I2 Z2 |- X1 H | max. 215 Ncm
& ? L6 i% f+ b. L+ Q4 o |
频率; ^9 t Z* w2 U( `# A
| 50 - 400 Hz
. A0 g$ j- a7 F* z: |7 \4 e5 K8 j) N0 r | Frequency
, g2 A i: D4 \* b* @1 ?- m | 50 - 400 Hz I- J- A) C' T2 B4 H& {
功率5 j1 h2 k& ~ Z; M8 d: r0 A& P
| 最大 2.000 W$ ?/ J! O. L5 W7 S" ~
| Output power
9 j R. P8 H2 W# v | max. 2,000 W
. s) O0 a: p4 d5 o r |
重量: d+ @3 T6 u) {5 g; n0 b; k* o
| 3.5 kg+ G' ^: A+ ]7 @ H9 r
| Weight0 Q8 U% ` J2 B: x& y( [
| 3.5 kg
2 c8 u, H$ r/ y7 Q: D8 W3 i |
轴承1 g. F: n4 `, P
| 3 x 钢球轴承, 油脂润滑
2 n6 l% K w8 D* K! o/ K, ] | Bearing system5 P$ L/ [5 ~8 C) m3 h1 C
| 3 x Steel, lifetime lubrication, h; j/ ?0 C8 r2 r
防护等级
7 u6 K# W, o! B$ P. N2 d2 b- \) n& P | IP 54/57* n/ A7 ~* _# E7 p$ w4 W
| Protection category
# ], x3 C5 k) e# _* m: v& t | IP 54/57
2 F, M0 u5 U6 B3 ^/ | |
电机保护
7 u( H" ?6 H0 l: j% W% O | PTC - 130 °C* f+ e& k1 s v
| Motor protection- s6 }; v Q C1 @4 @0 {, |
| PTC - 130°C/ W6 |" |7 e* i0 R8 M
安装位置
! @5 ?' z5 i. D+ `7 W! D2 d! `- u | 6 X( Q, z0 e& H @
| Working position! }& J' d+ ~! a' c
| & t0 _8 a A! V
负载方向
3 M4 U" f! l* W/ n: U+ j* w | 轴向 + 径向( ?6 j2 T4 Q$ r9 P( J9 h
| Load direction4 y1 S# ?6 t( k. }0 J4 v
| axial + radial" G* R; N9 c/ E0 I( X- w
锥面跳动. ~" ?; F2 X( m" [( A
| 通常 1 µm* u+ ~8 h! t, `
| Run-out (taper)+ C: q5 W [6 d
| [ 1 µm* `& g" ]& k# Y5 I' Y! k0 @) |
刀具夹持范围
. t! O: s; r* Q/ s0 ` | Ø 0.5 – 7.0 mm (ER 11)
8 `: \2 d! j& ]" Q. L | Chuck clamping range, Q& D- P) o0 ?( t9 m
| Ø 0.5 - 7.0 mm (ER 11)0 R0 ]& _8 |4 C; N. K2 e
换刀方式* A# u3 t; J! X
| 1 开口扳手 (SW 13)3 G% X$ `* W% \ H. ?/ p$ ~+ X3 W
| Tool change4 y2 {1 @. ]7 y4 Z: \
| 1 open-end wrench (13 mm)$ f* ~, l8 ^8 D$ b. D1 l
冷却系统
/ B% } p7 W7 ?3 T* u( ?1 A4 n | 外夹具冷却2 Q. }7 t; L) Y4 c
| Cooling system
' m( o8 A6 k$ d' G5 [ | Cooling via clamping bracket
3 ]/ x, O) A! K. T. p2 E2 h% T |
防水防尘措施
" a, ]+ e5 V+ Y6 E- _5 n9 } | 密封气0.8–1.0 bar(管径Ø 内/外 4/6 mm)% O2 Y& x0 `0 p5 W: U" r
| Protected against dirt( U( W9 {# |. Q, V; g0 w
and cooling lubricant
: r: t: D7 ] k: Q | Sealing air 0.8 - 1.0 bar* f! t3 J$ ?0 C# ?1 U
(hose Ø outer 4 mm)
% ^8 Q, F9 o% U8 W, O9 S |
外壳材料
- T l# T( Z. j: m& ` | 不锈钢- b2 ^8 F) Q6 I1 |4 K
| Housing material
! G6 x! @$ P8 Y" ~ s | Stainless steel
0 \/ A; T7 n7 B1 Q0 c |
推荐变频器" i7 F2 o5 J9 P$ f& [$ x" V5 A
| e@syDrive® 4438, TV 4538,
4 E$ H* T& O0 l! J* w- ~2 i EMERSON SKCD200220& W: x- I, v2 i, G
| Inverter recommendation- G# b( `5 z+ I
| e@syDrive® 4438, TV 4538,- S5 ]' {6 [+ }4 F/ l3 r3 [
EMERSON SKCD200220! ^1 U7 }/ _* S/ H+ D/ X, C
2 y# A" I1 c$ W) }% X9 ~ | 不锈钢% m% ^3 U) m3 \2 F, p4 U# k( x$ Z
| 9 L8 Z- q" u$ A& l$ b1 ^7 H% n' M
| Subject to change without notice' k+ G9 f2 u5 h( g C. V$ }
