查看: 5089|回复: 5
SolidWorks湍流喷注噪声仿真
发表于 2017-4-18 07:06:08 | 显示全部楼层 |阅读模式
SolidWorks2017SP2带来两个更新,一个是将SOLIDWORKS 3D Interconnect由beta版变成正式版,并且是默认开启。/ ^% F5 u6 P  |0 f% F0 C
另一个就是SolidWorks Flowsimulation2017SP2 增加了声学仿真项目
: S  n( \  z+ g. v, I+ F. V6 \
% X: T! M( X9 E( h$ W6 h4 C, r3 F. O还有,在必将到来的SolidWorks Flowsimulation2017SP3更新中4 e* |  [* `0 Y0 W# f3 j7 K
The Noise Prediction is available with SOLIDWORKS 2017 SP3. The acoustic Power Level is calculated with Proudman formulae, one of the known steady-state approach in CFD. The Proudman’s formula gives an approximate measure of the local contribution to total acoustic power per unit volume in a given turbulence field.
  M4 i" o/ s* s+ E% k$ d2 k' u  r" A' Q. @" G5 O
. D; S7 a- N4 T9 s+ q) N$ t0 b
This can be used to estimate broadband noise generated by turbulence.
Available results include the Acoustic Power, in W/m^3 and the Acoustic Power Level, in decibel (dB).
并且已经有了实际应用
发表于 2017-4-18 08:49:37 | 显示全部楼层
分析软件还是专业的靠谱吧
 楼主| 发表于 2017-4-18 12:07:32 | 显示全部楼层
xiaobing86203 发表于 2017-4-18 08:49$ }2 N) G" d5 A, t& w1 N
分析软件还是专业的靠谱吧
' T1 v5 L4 `; C* F% g9 d2 G  e
solidworks flow simulation本身就是相当专业性的CAE软件,见识少,要加强学习。
 楼主| 发表于 2017-4-26 21:19:01 | 显示全部楼层
Soliworks2017 SP3来了
Solidworks 2017SP3
/ q- X5 c; x3 Y. ^3 R* u( v  @) I( o& r, F/ S: d! S3 n
9 k) J, i6 u5 I7 o
& }0 r% Q5 a$ l
发表于 2017-8-26 19:42:31 | 显示全部楼层
好确实好非常好你看着给* u& X# o# l& f  f# A3 ~& P  m
发表于 2017-9-13 17:25:22 | 显示全部楼层
学习了,。。。。。。敬仰
GMT+8, 2025-4-24 19:40 , Processed in 0.067706 second(s), 20 queries , Gzip On.
