发表于 2017-3-4 14:21:37
显示全部楼层
本帖最后由 ryouss 于 2017-3-4 14:42 编辑 4 b% n3 p$ g' T; M
& L- ?1 r7 J+ q. S1 Y
用 Select Case 做篩選循環,
& y2 ^) p7 l: U @# q, Z不過如下宏只是做零件,裝配件及工程圖的叫出再關閉,沒實質意義.
! k7 Z s$ A+ k5 n; c6 l% ~6 g
( K) Z) e9 o y* U% G6 ]# `$ P5 I4 E
: V/ h6 G8 U/ x) w/ U* F5 ^% n: F
- '8 s0 |+ S2 ] B; z8 v0 X j6 _6 E
- ' 在某文件路徑下批量開零件,裝配件及工程圖( Z. j( j+ T+ i( y+ @( N7 m
- ' sc liang 2017/3/42 n% l# i- i# b6 X: T( w o
- ' 測試版 2012 sp4# {5 |+ C. y0 z) B8 D
6 f6 k, g( r7 r+ q! i3 f6 d, ~ - Dim nErrors As Long) I8 {( X! T( O+ X) P: ~
- Dim nWarnings As Long7 T4 h1 d5 M. ?
- 0 L) M- o3 w. [6 w, b; w
- Sub Test()' z8 d9 t0 B1 u9 b& G
- Set swApp = Application.SldWorks" r2 y. Q8 b: O4 w* N8 {
- Set swModel = swApp.ActiveDoc- T7 H& \/ d/ v$ r- p' Q
- path = "D:\Project" '存檔路徑
* }' m- p; r x$ ] _ - sFileName = Dir(path & "*.sld*") '取出SW文件, u! D& i0 c0 J& V
- '循環開檔, p, Z) d+ K3 ^9 O( k9 s3 J
- Do Until sFileName = "": v" d2 q! {- r* U
- Type_ = Right(sFileName, 3) '取得SW文件擴展名後三位7 h# t/ Q3 R: n* ~ p9 X: e
- Select Case Type_ '判定SW文件型式
2 x1 l9 J4 U+ z4 Q4 d9 h$ |/ r - '開零件檔並存檔
4 n# q9 o' l: W4 r - Case "PRT"- n; X2 a9 v( p8 N z: i I
- Set swModel = swApp.OpenDoc6(path + sFileName, swDocPART, swOpenDocOptions_Silent, "", nErrors, nWarnings). M) J; ^& G$ j' v' I1 ^* H9 Y
- Set Part = swApp.ActiveDoc. O' W& U8 W4 o( N
- Part.Save) r$ k' J0 i; j8 @/ B5 t4 C
- '開組件檔
5 _2 s5 U4 z9 T! \' Z - Case "ASM"
1 W* K% Q' P8 [4 U' J; o F - Set swModel = swApp.OpenDoc6(path + sFileName, swDocASSEMBLY, swOpenDocOptions_Silent, "", nErrors, nWarnings)0 F! d. L1 c. a/ q& m; p
- '開工程圖 * x" A" J7 N- M# y. K
- Case "DRW", p& X1 L3 Y8 A! k6 C/ Q: Y& z6 \
- Set swModel = swApp.OpenDoc6(path + sFileName, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
: m, x) T) J& u- |1 }' P - 0 K/ l& u! {$ A2 D/ ?5 a! A- d; u, _
- End Select
( Q1 ~, w: A c% ]8 P t - Set swModel = Nothing1 \, b) ]+ z k0 v
- swApp.CloseDoc (sFileName)
2 [3 C& H1 }) e- k' s* Z1 S - sFileName = Dir '同路徑取出下個SW文件檔名
* i3 h. L; C5 s - Loop
* h ?, t) X) f - End Sub
复制代码 |
