http://player.youku.com/player.php/sid/XMjUwOTU0ODEzNg==/v.swf
: M$ F1 I- t8 Q9 y在Solidworks World 2017上,达索公司推出Simulia Enigneer云计算,在Solidworks Simulation、FlowSimulation、Plastics基础上,进一步解决非线性大变形仿真问题。
5 E) i! ^' |7 c, S5 s0 ^
* N2 B% M2 G3 d& }达索SIMULIA公司(原ABAQUS公司)是世界知名的计算机仿真行业的软件公司,成立于1978年,其主要业务为世界上最著名的非线性有限元分析软件Abaqus进行开发、维护及售后服务。2005年5月,前ABAQUS软件公司与世界知名的在产品生命周期管理软件方面拥有先进技术的达索系统合并,共同开发新一代的模拟真实世界的仿真技术平台SIMULIA。SIMULIA不断吸取最新的分析理论和计算机技术,领导着全世界非线性有限元技术和仿真数据管理系统的发展。) S1 G4 u8 c& n. `0 ?
8 w8 O7 |/ M: H3 T% L' H QIn the same way that not all cars are equal, not all structural analysis solvers are either. So what is an optimal solution for solving low-complexity problems is probably not the best for high-complexity problems although they are still both structural analysis solvers. As a result, we need to offer a range of solutions that deliver the best experience across a wide range of problems. This is where the new Simulation Engineer solution comes in. It is tailored to solve very complex structural problems but can it solve the relatively simple cases? Yes, however, it would be like using a sledgehammer to crack a nut. The new Simulation Engineer solution expands the coverage of the SOLIDWORKS Simulation portfolio by delivering the world-leading Abaqus solver on the 3DEXPERIENCE platform. / u4 i/ ^7 E# b5 u1 u9 x
SOLIDWORKS has spent the last 15 years making structural analysis more accessible through UI and workflow improvements that enable any designer to setup, run and understand their results directly inside of their CAD workflow. This focus has not dimmed with the introduction of Simulation Engineer. For example, while Simulation Engineer is on the 3DEXPERIENCE platform, users can easily access and use this powerful solution with ‘one click’ from within their familiar SOLIDWORKS Simulation environment. This ‘one click’ will transfer geometry, materials and many boundary conditions over to the 3DEXPERIENCE platform kick starting the solution. One click, it’s as easy as making a purchase on Amazon. In addition to a new solver, Simulation Engineer users will benefit from a wide range of material models and a robust and automatic contact setup together with advanced meshing tools. Together these technologies from SIMULIA result in a product that will deliver high-accuracy solutions for the most exacting of structural simulation problems.
* a- j; u* r! c f$ ^" B; b9 ~ |
