查看: 4054|回复: 8
应社友要求,共享SW钣金零件输出展开DWG的代码
发表于 2016-10-23 10:39:59 | 显示全部楼层 |阅读模式
保留折弯线:
+ O" Z: T" h/ g5 g
  1. Option Explicit
    : R3 d' @& W& ~" b% g- S
  2. Dim swApp As SldWorks.SldWorks
    6 Z& Q0 M; R/ ^% ~6 o5 K
  3. Dim swModel As SldWorks.ModelDoc23 `% D! g- r: \/ c/ |( d3 h* u
  4. Dim swModelDocExt As SldWorks.ModelDocExtension
    ( Q: q( Q: c; N& {! k
  5. Dim FileName As String
    # R" x  l" e% t/ M
  6. Dim NewName As String
    * q2 ~6 C& |" T  r6 _! y
  7. Dim boolstatus As Boolean
    * P% a' x6 D6 Y/ M" k
  8. Dim longstatus As Long, longwarnings As Long6 I6 v) ?1 M" ^: p
  9. Sub main()5 u+ m1 q/ j( m' X( b& z) c
  10. Set swApp = Application.SldWorks- Y3 i3 T0 S4 d8 N4 C
  11. Set swModel = swApp.ActiveDoc
    4 g# ?  z5 Y# R/ u6 E6 l
  12. Set swModelDocExt = swModel.Extension/ t, r3 f$ e6 G( g
  13. FileName = swModel.GetPathName(): e+ M4 S, @# l/ a# b5 b
  14. NewName = Left(FileName, Len(FileName) - 7) & ".dwg"4 w3 b2 g% @$ T# ^8 H: R4 k
  15. boolstatus = swModel.ExportFlatPatternView(NewName, swExportFlatPatternOption_None)
    2 \& t/ h( c# F
  16. swModelDocExt.SaveAs NewName, 0, 0, Nothing, longstatus, longwarnings* x9 M+ m& H$ {2 N
  17. End Sub
    % i6 i" K: O& q/ m+ z( Y
复制代码
移除折弯线:% y& u' J+ M4 ~+ v5 D9 b$ K
  1. Option Explicit
    * |4 J( S! I- y; u3 y0 X
  2. Dim swApp As SldWorks.SldWorks3 o# N( K  W0 b2 ]7 h! Y
  3. Dim swModel As SldWorks.ModelDoc2/ m5 M+ r4 _' q/ k
  4. Dim swModelDocExt As SldWorks.ModelDocExtension% z1 W6 n6 u9 I
    6 t9 R, M# s8 U8 v% X1 j3 B! Y& W, G
    . s7 I$ l/ g5 G/ A( A/ I4 l8 M- i% p4 Z
  7. Dim boolstatus As Boolean. q9 b, @6 f4 L) q2 `7 w% f: V- a
    ' V; g6 N4 h; u
  9. Sub main()
    . r! I0 X; m0 @5 k6 J
  10. Set swApp = Application.SldWorks0 A  P1 O( U9 o% V; f  w- a* r
    ( J1 n$ O8 a7 ?! h$ ^
    7 z  g  K8 {3 s6 w
  13. FileName = swModel.GetPathName()/ b* z& {( T2 p7 [& I
  14. NewName = Left(FileName, Len(FileName) - 7) & ".dwg"9 n: c9 N4 |1 p- R! V
  15. boolstatus = swModel.ExportFlatPatternView(NewName, swExportFlatPatternOption_RemoveBends)0 O( {6 V7 L6 J/ W3 B3 e& Z0 V) ~
  16. swModelDocExt.SaveAs NewName, 0, 0, Nothing, longstatus, longwarnings. Q1 ?- E  j3 p3 V, C
  17. End Sub$ v0 z2 x( G/ U5 \. \
复制代码
0 Z* ~6 e% v% F# ^" J3 q2 I9 M) ]3 Z
参与人数 2威望 +51 收起 理由
管理团队 + 50
野蛮游戏 + 1 热心助人,专业精湛!
发表于 2016-10-23 10:47:29 | 显示全部楼层
必须顶上去!超实用!!
发表于 2016-10-23 15:39:50 | 显示全部楼层
没觉得sw钣金需要改动啊
$ U+ E1 u1 Q- f" B/ z! e/ m, m) h, a
发表于 2016-10-23 16:56:57 | 显示全部楼层
sw工程图里面的平板形式不就是展开图吗?这都要写代码呀?
发表于 2016-10-23 17:46:39 | 显示全部楼层
楼主,这是? 代码要放到哪里?
发表于 2016-10-23 19:23:30 | 显示全部楼层
怎么用啊   新手
发表于 2016-10-23 19:49:24 | 显示全部楼层
楼主好人做到底,说明一下怎么使用啊
 楼主| 发表于 2016-10-24 08:23:43 | 显示全部楼层
7 z* a) G9 ^, F" o: L
newmorn 发表于 2016-10-23 16:56
% n3 l; |4 b2 q0 M# R; S- n) Ssw工程图里面的平板形式不就是展开图吗?这都要写代码呀?
% H* B$ f1 @. M( J7 E, {代码替代了繁琐的点击另存为过程,利用代码做成宏按钮,一键保存平板形式为dwg/dxf下面动画为另存为输出过程和宏代码输出过程8 ]# H  G) Z' Z5 u7 O3 S
) s3 t0 Z& }+ `) R
4 f  v8 R/ \* z9 l2 @% s
 楼主| 发表于 2016-10-24 08:58:37 | 显示全部楼层
hc2003 发表于 2016-10-23 19:49
1 y2 E8 B/ K3 d9 n2 j4 P, c% [楼主好人做到底,说明一下怎么使用啊
. x5 a6 l6 b1 H( D( ^$ ~1.新建一个宏,删除里面所有代码
8 f7 O, g8 |5 s, [2.复制我贴的代码到这个宏里面
; k9 k0 _' U: @& ]3.保存此宏6 e* r: u! [$ n0 L* }3 M; U
4.打开一个钣金零件(可以展开的零件)1 O0 ?. v7 W; f: }# {9 q" ]
5.运行此宏7 W/ V2 c6 C, o# L) h  Z3 q
6.自动输出展开图(DWG)! P; ~3 x" h) V- o
GMT+8, 2024-11-26 23:17 , Processed in 0.060375 second(s), 22 queries , Gzip On.
