发表于 2016-9-27 00:57:07
显示全部楼层
Bit of a cliché here when it comes to "fast speakers". Most Germans don't even speak English, the rest of them speak with an accent. That must be why it turned out a pain in the ass for you. Working with foreigners can be tricky 'cause you can't simply expect there to be a golden rule that fits all foreigners. They come in abundant varieties. So you must get to know him first, just as with a common Chinese superior. : B5 u8 d8 ~8 X z8 r6 H
9 X9 q, D% ?, V" B1. Clear language barrier ASAP. Start with most common phrases which you use every day. Establish a failsafe system so that whenever communication fails, you may immediately inform him and he will be able to fix problems with you without significant time losses.
6 c N) b2 G- x5 t, w
) }& X7 _9 a7 }+ e8 `3 \2. Review your responsibilities in your current position within your company. Know what your superior expects you to do, and how you're supposed to do it well with your expertise.
; ?6 i+ F( z& A! M4 b8 ]& f% G3 ~1 }& j, J
3. Observe his preferences, what he likes and dislikes. What's the best angle to come to him to express an idea most efficiently. Germans emphasize on efficiency.
* u# M: @+ E; p6 T( p
: Y% z2 G7 r4 A- R9 l4 H5 e) \4. Although it might already be overwhelming to work on your English, I'd still recommend that you start learning German, even just a little bit. Andere Länder, andere Sitten. Deutschkurs sollte sich als nützlich erweisen. |
