发表于 2016-10-21 13:49:04
显示全部楼层
7 W; R9 y% C. j5 z D1 E移除折弯线代码如下:5 D# x( k# ^1 f
- Option Explicit
4 r, _+ S: M2 _% v - Dim swApp As SldWorks.SldWorks/ [1 |/ V0 X4 D, g3 X" S
- Dim swModel As SldWorks.ModelDoc2
7 u) `- d& O! C- u. T y' k - Dim swModelDocExt As SldWorks.ModelDocExtension
) }4 X$ W+ Y, i$ h4 \* f" ?+ w - Dim FileName As String i" T; g/ T1 k, n8 B
- Dim NewName As String
. j1 r; I. `; n7 k# L! j, r - Dim boolstatus As Boolean: Z. _1 M. X, E- o" ~3 t
- Dim longstatus As Long, longwarnings As Long! r; m0 m/ z0 I4 t/ h
- Sub main()5 C- z* g1 _0 b5 k* X! q
- Set swApp = Application.SldWorks$ A- i8 e n+ u; }
- Set swModel = swApp.ActiveDoc
Y) `; }. u6 h3 Q - Set swModelDocExt = swModel.Extension& @* L! `. ?. h7 y( a5 ]
- FileName = swModel.GetPathName()
4 ]9 F& D, R( d5 b - NewName = Left(FileName, Len(FileName) - 7) & ".dwg"
6 x4 g4 X7 L, N$ n9 U4 L - boolstatus = swModel.ExportFlatPatternView(NewName, swExportFlatPatternOption_RemoveBends)2 e# p, d; p# l, @& G4 c1 i8 ?
- swModelDocExt.SaveAs NewName, 0, 0, Nothing, longstatus, longwarnings
8 _ m. T$ C" X$ Z/ B( q - End Sub* f2 W' Q& Z- a( f0 ^
复制代码 . D% B! Q/ }% q5 ]- y' Z
' ?0 f4 G9 o8 |4 C3 _5 v4 s) [ K8 [
