发表于 2016-8-6 14:14:36
显示全部楼层
7 A1 _) J4 I: i$ |- Q
2 h- @4 K3 r+ fHeli-Coil® inserts are precision formed screw thread coils of stainless steel wire having a diamond shaped cross section.' l2 S g) R( h) M; s
When they are installed into Heli-Coil® tapped holes, they provide permanent conventional 60' internal screw threads that accommodate any standard bolt or screw.
; H ]- x% o# D; m' bUS 亚马逊网站有介绍:
% V& }$ R0 R% e- U- u9 Lhttps://www.amazon.com/Heli-Coil/b/ref=bl_dp_s_web_3030648011?ie=UTF8&node=3030648011&field-lbr_brands_browse-bin=Heli-Coil
+ e- d0 L9 G1 ?6 {, I2 A+ Q& C
" T+ {" b+ W% m/ \3 I! A9 [- o |
