发表于 2007-7-7 16:57:44
显示全部楼层
Re: 有哪位用野火版2.0M080的请进
1.Use the Keygen.exe to generate your PTC HOST_ID license file;
; C: ?. h' w/ A" y4 i) C2.Install the PTC License Server with your PTC HOST_ID license file which you got from Step 1;
\% Z$ a& d# h* r" W. C$ p3.Install Pro/ENGINEER, and select Single Server license type as the Pro/ENGINEER license;
: o Q8 @3 ^$ s- w/ M then fill "your computer name" as the HOSTNAME in the BLANK before the port "7788".
: y3 i3 M' t8 G 2 E+ h1 k, e" W
*If you click the Setup Option" VERICUT (R) for Pro/ENGINEER" when you install Pro/ENGINEER and wanna the VERICUT as the
1 e% S+ c' @+ Z8 y2 Z6 Y; C' y" z, q *embedded software for pro/e, you should also do the following two steps for the embedded VERICUT:" o3 A9 b9 ~& }. H9 _
* A. Copy the patched CGtech.dll into the installed directory \proeWildfire 3.0\i486_nt\obj to replace the original one.
, w& L& s( _/ y/ A8 x, G * B. Find the following file in the installed directory \proeWildfire 3.0\bin\proev.bat and open it with an Editor software,/ d* g% g0 o' b' C! L
* search
8 p. [9 I5 G6 D& c. p- t3 c' q) @ * Vericut %argstr%
& G: Z# W8 }0 l3 D * and replace it with the following string:, M# X3 [9 s8 [' j
* Vericut %argstr% PTC_KEY=0
! p9 O" C3 ~& O# ]5 I1 d9 X * then save the file. the purpose of the step B. is to forbid the VERICUT to use the PTC lic as its lic.Actually, CGtech9 g$ D' i( ]9 i1 {( `: t
* no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official
: ~- k8 C; b" M: z * website said:
5 m4 v. T: I# G" D2 v* k1 x" `+ f * http://www.cgtech.com/ptc_update/index.htm
9 p, N9 b. I4 ]5 s4 v& p0 O 8 J& y" J5 S; X, f1 g
4.Install Pro/Mechanica(Structural and Thermal Simulation) like Step 3. I) _/ g1 j# f/ p. P6 f
5.Install PTC Distributed Services.this step will automatically get the lic from the lic server installed at step 2.
: u0 c6 `6 f/ i* Y$ i% y6.That is all and enjoy it!
) j Y8 _* R7 Q8 o8 T0 `& w
' _/ z: O& U) n3 W5 J/ ]* s
$ w) o: Y4 ~& R; O, ]) R3 OTEAM ZWT /2006 |
