楼主 |
发表于 2016-5-31 09:26:01
显示全部楼层
钣金厂常用的切割工艺
4 S- Z+ X9 g/ g5 g& Khttp://www.custompartnet.com/wu/sheet-metal-cutting
* G1 f# I2 H+ ~' |: Y- \% A! C: ?- c2 N3 k
Laser beam cutting 激光切割
2 r- \' G- R* X; K: B9 { e2 t' ~Plasma cutting 等离子切割
" b3 f% r7 n$ Q- EWater jet cutting 水刀切割$ D4 a7 c9 X2 {9 d+ M
! Z ], v! F$ C4 C9 X+ N
http://www.custompartnet.com/sheet-metal-gauge3 _. @1 g7 {; G0 r' c$ f: M
Sheet Metal Gauge Size Chart 钣金规格尺寸表
3 z0 }, N- @7 X5 p- F有这份表格就可以轻松看懂红毛的几号板
+ C; U2 F9 u7 k: c$ x2 s
8 }/ |/ r0 |# x* L9 b( o* D | Thickness
. F4 M0 @$ e" J0 _: i | Weight Per Area | Gauge | in | mm | lb/ft² | kg/m² | 3 | 0.2391 | 6.073 | 9.754 | 47.624 | 4 | 0.2242 | 5.695 | 9.146 | 44.656 | 5 | 0.2092 | 5.314 | 8.534 | 41.668 | 6 | 0.1943 | 4.935 | 7.927 | 38.701 | 7 | 0.1793 | 4.554 | 7.315 | 35.713 | 8 | 0.1644 | 4.176 | 6.707 | 32.745 | 9 | 0.1495 | 3.797 | 6.099 | 29.777 | 10 | 0.1345 | 3.416 | 5.487 | 26.790 | 11 | 0.1196 | 3.038 | 4.879 | 23.822 | 12 | 0.1046 | 2.657 | 4.267 | 20.834 | 13 | 0.0897 | 2.278 | 3.659 | 17.866 | 14 | 0.0747 | 1.897 | 3.047 | 14.879 | 15 | 0.0673 | 1.709 | 2.746 | 13.405 | 16 | 0.0598 | 1.519 | 2.440 | 11.911 | 17 | 0.0538 | 1.367 | 2.195 | 10.716 | 18 | 0.0478 | 1.214 | 1.950 | 9.521 | 19 | 0.0418 | 1.062 | 1.705 | 8.326 | 20 | 0.0359 | 0.912 | 1.465 | 7.151 | 21 | 0.0329 | 0.836 | 1.342 | 6.553 | 22 | 0.0299 | 0.759 | 1.220 | 5.955 | 23 | 0.0269 | 0.683 | 1.097 | 5.358 | 24 | 0.0239 | 0.607 | 0.975 | 4.760 | 25 | 0.0209 | 0.531 | 0.853 | 4.163 | 26 | 0.0179 | 0.455 | 0.730 | 3.565 | 27 | 0.0164 | 0.417 | 0.669 | 3.267 | 28 | 0.0149 | 0.378 | 0.608 | 2.968 | 29 | 0.0135 | 0.343 | 0.551 | 2.689 | 30 | 0.0120 | 0.305 | 0.490 | 2.390 | 31 | 0.0105 | 0.267 | 0.428 | 2.091 | 32 | 0.0097 | 0.246 | 0.396 | 1.932 | 33 | 0.0090 | 0.229 | 0.367 | 1.793 | 34 | 0.0082 | 0.208 | 0.335 | 1.633 | 35 | 0.0075 | 0.191 | 0.306 | 1.494 | 36 | 0.0067 | 0.170 | 0.273 | 1.335 | 37 | 0.0064 | 0.163 | 0.261 | 1.275 | 38 | 0.0060 | 0.152 | 0.245 | 1.195 |
