查看: 3521|回复: 7
solidworks2017前瞻:Part Supply
发表于 2016-3-28 19:24:48 | 显示全部楼层 |阅读模式
( e7 X4 ^9 ]# T, a4 D9 {8 T  F; v* h
A great new service introduced by SOLIDWORKS is called Part Supply, which is powered by EXALEAD technology. Simply put, SOLIDWORKS is building an easy but intelligent way to find a component that fits your design goals. It will be as simple as creating raw geometry in SOLIDWORKS. You click on it and the computer starts thinking and gives you the right solution very quickly。
- r/ n. g2 M0 U现在solidworks推出Part Supply,由EXALEAD搜索提供技术支持。简单地说,solidworks提供了一种简单的,智能的方式来让你找到合适的设计对象。% U2 v6 J0 f% S( {& l8 ^4 @7 [
+ ], h1 @5 X& |6 p
. m0 W  C& t* fAs you can see in this example, simple raw geometry was created. Part Supply will do a geometry search, a contextual search, and a metadata search. It searches your existing parts that you have saved on the cloud. This will help you to very quickly find and reuse existing parts and reduce duplicates. Not only will it search your existing parts, but Part Supply will go out to 3D ContentCentral and TraceParts and search the 100+ million components from the cloud.  |/ D( {, a2 ]6 b0 Z
正如你看到的例子,创建一个简单的几何体,Part Supply将进行几何形状搜索,上下文搜索和元数据搜索。它会搜索你已经保存在云空间中的零件。这将帮助你非常快速地找到并重复使用零件,减少重复。它不仅将搜索现有的零件,它不会扩展出去,到3D ContentCentral网站和TraceParts在线零件库,并在云空间超过100万个零件中搜索。
- z% B( i0 J, R$ Z7 J4 H
% k# H9 s" ^  J: {% S% z, s5 p1 e' y' K
In just a few seconds, you have access to components that meet your exact design goals. All you had to do was create some very basic raw geometry. SOLIDWORKS did the rest. Once you like what you see, you just double click and it replaces the part in SOLIDWORKS and you are ready to go.
( s2 t$ |8 T1 r7 n: x5 I几秒钟,您可以访问到满足您的设计目标组件。所以你要做的就是创造一些非常基本的原始几何体。 SOLIDWORKS来完成其余的事。一旦你所看到适合的,你只要双击它,它就会取代在SolidWorks文件中的那个零件。' @; o+ C  v# a
& |& i/ @# e* {2 c/ m8 b
0 u9 s0 w7 p- E) r+ b& M1 P
发表于 2016-3-28 19:55:22 | 显示全部楼层
一个云“标准件”库吗
搜索的谁的 用户上传的?  发表于 2016-3-28 21:06
关注点难道不是Exalead技术,能进行几何体形状搜索吗  发表于 2016-3-28 20:47
发表于 2016-3-29 08:40:22 | 显示全部楼层
对,几何搜索是关键啦,你只需要画零部件的基本信息,就可搜索。
 楼主| 发表于 2016-3-29 12:02:05 | 显示全部楼层
虎啸而过 发表于 2016-3-28 19:55
0 D  q) m# g( p7 V6 M. R一个云“标准件”库吗
' t5 O  O! r2 H3 K" z
一个是你自己上传的,另一个是公司其它同事上传的,还有第三方,比如3D ContentCentral模型库和TraceParts在线零件库,以后还可能有GRCAD库,最后是全球达索用户和solidworks用户上传到3Dexperience云存储上的共享数据。
发表于 2016-3-29 20:59:46 | 显示全部楼层
道理我都懂 但是有啥好处了 同一个公司直接可以从PLM调用啊,至于上传有的公司保密不让上传吧
不让上传的公司,如何使用订阅服务的solidworks,显然只有开放网络的公司才能使用订阅服务,而只有使用订阅服务的公司才能享受到part supply  发表于 2016-6-15 19:41
GMT+8, 2025-2-25 08:31 , Processed in 0.053008 second(s), 17 queries , Gzip On.
