本帖最后由 shouce 于 2016-2-1 21:19 编辑 # [' m; ~4 b2 Y$ U$ ]
. g; D/ v$ ]* _* C
function ABCk1 %圆弧包络线 阴推阳 20160131) Z. B4 z% y3 g0 P. X
clc% G$ A/ x1 B9 c8 u m- l# K
clear
% _+ N0 t R, O; R' v+ X1 mt=linspace(-0.2401727,-0.65911,200); %原参数范围
0 @8 u: r+ h# g0 x" a- e9 ?%t=linspace(-1.608786,-1.35,100);
( K+ C! q, F4 Y" M1 Y; s6 Ei=4/6;k=i+1;
% e! @( |5 c1 a9 C* E! Q0 Qa=95.937985;b=8.801204;A=100;r=60;# @ f( a' G2 }5 U
q=-(t - asin((b*k*r*cos(t) + a*k*r*sin(t))/(A*r)))/i; %7 Z: X1 t6 J, l3 c/ D0 o
x=A-(A*cos(q) - cos(k*q).*(a - r*cos(t)) - sin(k*q).*(b + r*sin(t))); , ?, s" n* G% D+ S
y=cos(k*q).*(b + r*sin(t)) - sin(k*q).*(a - r*cos(t)) + A*sin(q);
0 r+ G& J5 i4 r6 B4 p2 bz=0*t;8 f% x& s. O( d: g6 b8 S: C
plot(x,y,'-go') %方便查看点的间距 ' Y# A1 |# m. b. B4 p
ABk1=[x',y',z'];+ V% [2 \0 r3 T \2 m
vpa(x',8) % 输出8位数值 20160201修改
5 r8 p2 W: @6 q6 | ~save ABk1.txt ABk1 -ascii3 y, {; `' F7 Y: b2 U
% 用 matlab 做数据6 `) |5 l: C' w
9 N0 u/ j7 _* z) }- ~5 l; d! ffunction ABCk2 %圆弧包络线
: s/ L! l! `2 c1 z9 A" }7 Fclc
: k! `' n3 t M5 p2 I, K) Y/ Tclear; b }# K! n; Z h( n
t=linspace(-0.6981317,0.65911,200); %原参数范围0 G) @5 A8 ^1 ~/ `& v
- Y$ ^+ F' B& ui=4/6;k=i+1;. t) o }2 {2 Q1 d
a=40.60035549;b=-34.06774331;A=100;r=10;
2 T- O5 e% s% k: k4 {" a8 Aq=(t + asin((k*(b*cos(t) - a*sin(t)))/A))/i;8 N c6 g' r1 M" v$ k3 X
x=A-(A*cos(q) - cos(k*q).*(a + r*cos(t)) - sin(k*q).*(b + r*sin(t))); 0 q7 o* s. M8 n) q0 r
y=cos(k*q).*(b + r*sin(t)) - sin(k*q).*(a + r*cos(t)) + A*sin(q);
* V- ~; l$ z+ e& @# Y" E) m# T$ Pz=0*t;
/ h7 r' Z8 v8 Q1 G3 Vplot(x,y,'-go') %方便查看点的间距 & Q2 A2 C C$ `1 o2 Z
ABk2=[x',y',z'];
7 n1 `; b! U+ |% n$ Y; S; r3 i! lsave ABk2.txt ABk2 -ascii
8 |4 j( Q5 \% w M4 I% 用 matlab 做数据$ s5 d5 ]% S, T
, u$ H- s: R h+ F' F1 Z6 N( |
function ABCk3 %圆弧包络线) |8 z; Y0 F0 u5 q( l- H
clc( j7 l# w5 T# A) S2 @; Z6 q a+ q
clear, _8 p- T$ \: o) {1 E6 w( e, E
t=linspace(-1.59196897,0.30879537,500); %原参数范围% a2 A0 v8 g3 H' r$ R, A
%t=linspace(-1.608786,-1.35,100);* W9 c( \& I$ ?3 D0 d( J4 s
i=4/6;k=i+1;& ~* g. v% N1 j; t2 j1 a
a=57.06675156;b=18.20428153;A=100;r=3.1;( [/ T. H2 y0 _' Y h
q=(t + asin((k*(b*cos(t) - a*sin(t)))/A))/i;% s6 u! i2 O( D' x( \- ^
x=A-(A*cos(q) - cos(k*q).*(a + r*cos(t)) - sin(k*q).*(b + r*sin(t))); 5 w+ {. H v. D! ~" Z: ^
$ S7 R: D; x1 j2 P/ ^" Ez=0*t;3 J9 j- q! b# D2 ?9 m4 }
plot(x,y,'-go') %方便查看点的间距 9 u6 Z% [) B. G- o/ x7 c+ s
ABk3=[x',y',z'];. g( u" d& p2 t+ ^: q4 ?
save ABk3.txt ABk3 -ascii; j% O# W* U1 f9 U$ m8 s
% 用 matlab 做数据1 C2 |& `/ v# t7 U7 ~- p% a
0 A$ a+ G" v/ D s7 z |
您需要 登录 才可以下载或查看,没有账号?注册会员
