发表于 2015-12-24 09:41:14
显示全部楼层
本帖最后由 kyy454425565 于 2015-12-24 09:42 编辑 $ s# \: t1 d% J- b/ {. U* {
翔梦随风 发表于 2015-12-23 23:12 ! I0 B f- h; Q; K. D9 Q9 r3 h* @
大侠可否将表示过滤精度的页面截图发一下,或者发一下相关数据?因为手头有几分资料,不知和大侠发的资料 ...
7 b' B* p+ l1 [ p' E9 l# z上面是没有精度标注的,因为你在选型材料+精度的时候就已经选了精度,懂我的意思吗?9 D# j- g; W: Q+ E7 C$ i" j
DRG60代表的就是DGR材料+60um的过滤精度等级,对应的还有DGR10/25/40/100/200/300/500
" @$ \% Q# \0 z h3 o" j" A# h3.4 Filter material Drg3 E+ B3 {( q w$ W& V; J# E1 q; L
Surface filters made of stainless steel wire mesh with a very low flow resistance designed in the following weaves: plait, twill and linen. Degree of filtration 10 um, 25 um, 40 um, 60 um, 100 um, 200 um, 300 um and 500 um. For a wire mesh filter element the degree of filtration is determined by the largest diameter of a globular particle which would be able to pass the fabric. Wire mesh filter elements are used in hydraulic oil and lubricants filtration as suction or coarse filters, for high viscose fluids as well as safety filters for coolant filtration. Wire mesh elements possess a defined removal size as surface filter and a low dirt holding capacity as depth filter.
% C' W$ A# [( C7 A
+ U3 {7 }( h9 \; R" b) m3 r) Y0 S6 }: c% _* R
如果你选择了其他材料,也有对应精度的选型。 |
