查看: 4134|回复: 4
几个概念,哪位高人能解释解释呢
发表于 2015-10-27 16:32:45 | 显示全部楼层 |阅读模式
standy power
$ i: x) A6 ^6 f$ V. v+ ]7 F/ K7 y, [- cprime  power
# `/ v" f5 g# `5 \' X* u# Xcontinous  power" ?# V3 g$ m# n9 d3 [1 m
发表于 2015-10-27 16:58:00 | 显示全部楼层
What's the difference between Continuous, Prime or Standby Generators?' p1 [4 y( ?  F; v# I
. c4 @0 z/ H& R/ IElectric power generators can be grouped into one of three different types depending on their style of operation: continuous, prime, or standby. 6 z  L5 I# p$ D% X8 G/ C4 Y. A
8 d5 l- e+ M, b* S* VContinuous and prime power generators are very similar as they act as the main source of power and are designed to operate continuously or for extended periods of time. The main difference between the two is that continuous power generator sets are designed to operate continually with a consistent load while prime generators are designed to operate for long durations at variable load.
; c0 [3 a  n) i8 x4 s# h5 i% \
+ r, j' I! m( ^: t4 o% hThe alternative type of generator – standby/emergency – is designed to run only in a backup situation when there is a power outage on the main utility grid or the main source of power.  c3 \$ B$ S9 o/ [  t
发表于 2015-10-27 19:53:33 | 显示全部楼层
百度吧
发表于 2015-10-27 20:06:09 | 显示全部楼层
额定功率,常用功率,持续功率?按字面意思么是这么翻译的
 楼主| 发表于 2015-10-28 10:11:05 | 显示全部楼层
dongst 发表于 2015-10-27 16:58
5 a6 ], u' Q) K$ q5 f# nWhat's the difference between Continuous, Prime or Standby Generators?
4 d% v& r, O4 O3 j/ V
# }, {' P* }' g" q; A/ NElectric power generators ...
* V5 @, ]/ Z# e
thank you; r( K5 u3 S7 _7 f0 s
GMT+8, 2025-9-18 18:21 , Processed in 0.072054 second(s), 14 queries , Gzip On.
