Dim swApp As Object% M; y: t6 D8 n0 A: @8 ]
x' ]& D- H9 y% i8 w3 D# Y
Dim Part As Object
$ ]% R$ r3 n1 T2 z. g" }* @Dim boolstatus As Boolean
& ?! @; v/ W |. M& gDim longstatus As Long, longwarnings As Long* {6 E, d" w4 L# z
Dim path As String; s0 m0 j$ e8 }8 w# A! ]
Dim fname As String. h5 y, z, C5 W3 I7 D$ W7 e
Dim m As Integer
) X0 }& a' ]/ c Y3 X( M3 PDim shname() As String
9 u) r* ^% c8 u! M4 K P
1 c4 Y$ ?' T: K* Y/ [, j
: `0 g3 K* [* u' ZSub Main()7 [3 h! Q* e4 H" b7 a: t/ R
F" a" b; N$ m6 m3 F8 |* P' X
Set swApp = _: b) G: v$ f, w6 ~/ }
Application.SldWorks
- R' B# Y. @4 }% S* P0 }path = InputBox("D:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\lang\chinese-simplified\Tutorial", "批量替换图框")6 p7 {/ Y7 k+ [/ P, X0 O
fname = Dir(path & "*.slddew")
. Q+ n) g8 i7 I) e- BDo Until fname = "": H* }8 [( ]; V+ ^* ]# f
Set Part = swApp.OpenDoc(path + fname, 3)
/ c1 G9 [( E2 \. z CSet Part = swApp.ActiveDoc
5 L$ Z! J8 n! J& u! }, @9 Q; Vshname = Part.GetSheeetNameS()" R" N5 C7 E2 ]' g( r; w
For m = 0 To Part.GetSheeetCount - 18 g0 Z! }& w! H9 p R
If Part.ActivateSheet(shname(m)) Then0 p3 Q; e$ B/ y) E) E, d* e3 _
boolstatus = Part.SetupSheet5(shname(m), 8, 12, 0, 0, True, _7 T- A1 u! N, \5 R0 }0 j8 D+ P7 k
"C:\ProgramData\SOLIDWORKS\SOLIDWORKS 2020\lang\Chinese-Simplified\sheetformat\a3 - gb.slddrt", _
6 ~9 ^8 C1 g: _6 F: ~ 0.42, 0.297, "默认", True) f: n0 h7 F- x5 \) l2 s' Y) l* X
End If
& l) X Y* V- L; w Next
' V9 E# g% y; }+ s& \) `% q& m( LPart.Save# ?$ ^ l" I( ]1 ]
swApp.CloseDoc (Part.GetTitle)9 g0 B( H( C/ n' d/ I W. N; @, x
Set Part = Nothing Z3 f3 A. f7 G, A1 @% `2 v
fname = Dir
" _ K' Y4 |4 U" j; l7 s. x. M3 yLoop
3 t2 n7 I$ m( M3 H+ j" d) A7 j( y. Y: D' K- m. h( x" V/ O- N
End Sub |
