& U" x- D+ h e5 }/ Y( E) L' W
, O- {3 \: P0 h3 _7 W0 q! ?算了下在1.5MPa时,打入1g水,压力将从1.5MPa增大到2.26MPa。: D2 ^* P. ]: t5 S9 g
公式:P/Pa=3000((ρ/ρa)^7-1)
/ T% {8 I! f' r% }Pa=0.1 MPa ρa=1000 kg/m^34 y' [/ g6 p- z- A9 t0 w/ |( H. N
1、当1.5MPa时:/ U7 {- e. A* o" B6 S* m0 G7 |. C
ρ=((1.5/0.1+3000)/3000)^(1/7)*ρa=1000.071413 kg/m^3% c7 R6 z. `+ N) M- c1 f
v=1000/1000.071413=0.999928592 m^3
/ Z# F' R( {6 j
+ ^3 W' f. H& K, \2、体积不变打入1g水后
c2 p) N* |1 B9 G# N# S9 G5 ]: {# ^ρ=m/v=1001/0.999928592=1001.071485 kg/m^3
0 r0 k: U& ?# e1 E3 a* RP=((1001.071485/1000)^7-1)*3000*Pa=2.257363666 mpa
0 v, _8 P1 q' e! D- q' n; p
6 |$ o7 m& T: ~! ~6 S
& q4 Z2 P8 B* S) z9 b _@2266998 大侠指导下,可是这样的结果,谢谢!
A- _( }2 E& B6 u% z; g) \: k* @+ S! `; t4 W& K! T: a0 M; `5 m
( V+ O2 _/ v- Y8 y# w1 [9 N2 g3 S n7 O# }/ [8 a: i
8 e, P: }6 y; n& m% v. c |
