牧野机床出现以下问题,哪个大神帮忙解决。多谢了!
6 x3 Q2 O* L9 H" n! v* @# z8 j7 L* O# G
机床问题:
% C( A& x+ `' b) X# T( E! ~$ [1 D$ p) J' X
1、SPNDL SPEED COMMAND IS NOT SET WHEN START SW,WAS PRESSED
$ ]. D8 i6 A+ V$ a) o+ g/ q$ K2 A) P% D2 P; F7 [* w
COMMAND S—CODE AFTER RESET ALARM# A/ Q5 L! `" T% M; K- F- _
8 n5 p* {3 _2 r; F' l1 U
2、NOZZLE CLANT THERMAL RELAY IS TRIPPED
6 Q' V- y; N& x# d* ]$ q" h, r- p. k: i
DI SIGNAL TH2... WENT ON5 n& W. o$ g2 d# Q8 }6 V
: R1 b2 U! ^; A# e3 R/ ICHECK THERMAL RELAY AND THE BREAKER1 J( C2 _' S( S3 x; b: N( E
, U( i$ L( }5 y. v" H
3、NC ALAMRE IS BEING GENERATED* }( W; w9 L5 e0 O
: t$ M r( t4 h0 t0 | @! ~% GBMI SIGNAL AL....IS ON
! p* e8 F- E- w; g+ J/ C2 n" E) Q
& n4 m/ X% r2 }5 u/ Z' `CHECK FAULTY DEVICE# I4 W& a9 r0 T5 ` `- A. B& g
8 y: R J0 y! s& ~5 \8 \' ^6 v( Y1 W
4、TOOL CLAMP SIGNAL TOOK OFF DURING SPINDLE CW ROTATION DI SIGNAL LS00..IS OFF+ [- l; O, A* o# a5 R
+ S$ ?0 a W% M; bCHECK THE CONDITION OF LIMIT SWITCH,SILENOID AND ETC
1 K6 K8 K+ c6 z
) V, ^8 c( B2 u8 w' M' a9 u4 `+ w5、MAN. TOOL UNCLAMP & CLAMP CANNOT PERFORM AT AUTO MODE
' K' w' @1 \* }/ a7 N9 Q) c: c9 f5 ]3 j, I' r2 d
SELECT CORRECT CODE
. e" N o$ @5 T9 \' I5 S2 u4 `3 ] |
