查看: 3256|回复: 8
螺杆转子刀具设计(2) matlab 解法
发表于 2015-6-4 11:00:10 | 显示全部楼层 |阅读模式
螺杆转子刀具设计 数学模型
. U! M$ u# T  v; {9 @
/ f! ~" S2 X' T解如下方程:1679999.7*sin(x)-1679997.5*cos(y)*sin(x)-1499997.5*sin(y)*cos(x)-75000*sin(x)^3-179999.4000005*y*cos(y)*cos(x)+179999.4000005*y*sin(y)*sin(x)+75000*cos(y)*cos(x)*sin(x)=0# h, b, T1 O7 X7 \# B: e
求当x=-1.361时  y=?  . N, x$ b/ J. l- M7 P9 c# I
>> syms x y. E! l( b1 N1 n) q- s  x
>> f=1679999.7*sin(x)-1679997.5*cos(y)*sin(x)-1499997.5*sin(y)*cos(x)-75000*sin(x)^3-179999.4000005*y*cos(y)*cos' R, d# P# m' s" O1 C$ g' [
6 P2 s( y. s% `! B1 x3 \5 v(x)+179999.4000005*y*sin(y)*sin(x)+75000*cos(y)*cos(x)*sin(x)
0 Y0 X  u$ s6 G, @+ t( V) ^2 V$ x  e2 X, j. q" E& c$ f
f =
; |+ i7 h1 ~& ~) }) l0 C* W* T' i6 R& {+ e. a2 }
(7215543768789811*sin(x))/4294967296 - (2999995*cos(x)*sin(y))/2 - (3359995*cos(y)*sin(x))/2 - 75000*sin(x)^3 + 75000*cos(x)*cos(y)8 h: O# f" a) x1 Y; T% `5 C/ ^
" M8 U3 {' U8 S* J* _9 y*sin(x) - (6184732290414159*y*cos(x)*cos(y))/34359738368 + (6184732290414159*y*sin(x)*sin(y))/34359738368- h# N0 p8 O5 f- h" _5 Y
0 r/ l+ V  {) A$ _/ _1 o, ?/ D
>>  subs(f, x, -1.361)( H" |, P, j4 c) [% B4 h
6 ~% g& G5 G) M2 y4 ^; N
ans =
4 ]! s) r( \9 i0 C% ]+ W3 ^3 V* b/ y; N3 q- w& T" I/ R
(3359995*sin(1361/1000)*cos(y))/2 - (2999995*cos(1361/1000)*sin(y))/2 - (7215543768789811*sin(1361/1000))/4294967296 + 75000*sin
4 _# g! {2 n4 F* ]- {
1 X: U6 Z+ u8 w(1361/1000)^3 - 75000*cos(1361/1000)*sin(1361/1000)*cos(y) - (6184732290414159*y*cos(1361/1000)*cos(y))/34359738368 - # N  O+ B2 ]4 {$ z2 k" @/ C( o* O
# G) n  G2 V: N& N& u! @% d& |$ {* ~
(6184732290414159*y*sin(1361/1000)*sin(y))/343597383685 g; K3 y$ k0 |  z; h
' L2 e% Y8 U( o
% d/ D  ]4 n( Q: P+ k
>>  a=0; b=1;, L; ~* x9 w' A
eps1=1e-8;eps2=1e-8;2 `$ y  |1 ]# m0 J  V
N=300;- w5 X' x1 Q' i4 K* W
f=@ (x) ((3359995*sin(1361/1000)*cos(x))/2 - (2999995*cos(1361/1000)*sin(x))/2 - (7215543768789811*sin(1361/1000))/4294967296 + 75000*sin(1361/1000)^3- 75000*cos(1361/1000)*sin(1361/1000)*cos(x) - (6184732290414159*x*cos(1361/1000)*cos(x))/34359738368 -(6184732290414159*x*sin(1361/1000)*sin(x))/34359738368); - @0 ~5 ^; ]+ r: f
Hfun=@Bisection;
  \* R- ~" H! M" t[k,x,f_value]= feval(Hfun, f,a,b,eps1,eps2,N);
  t# u- R! @' M- y# p$ A7 J7 {" s! u. s! \
运行结果
2 a$ B  d1 Q# y0 d! j, Nk ,a ,b ,x, f
( t* }, c- \& [* z+ Y& Y  1, 0.000000000, 1.000000000, 0.500000000,-352805.622314164,
) u+ g  o' J7 g2 `4 s  2, 0.000000000, 0.500000000, 0.250000000,-92968.331400711,. \& ]) _( @/ r  ~" N7 A5 \
  3, 0.000000000, 0.250000000, 0.125000000,-4146.780462183,
% c7 c% `7 U" ~3 F8 F0 n/ J  4, 0.000000000, 0.125000000, 0.062500000,29178.936016433,: V, |; L  u/ v/ l4 |
  5, 0.062500000, 0.125000000, 0.093750000,13458.364371693,9 }2 A- O9 S& ^; h
  6, 0.093750000, 0.125000000, 0.109375000,4890.124291139,
3 Q# z+ a8 E; o  7, 0.109375000, 0.125000000, 0.117187500,430.092693351,
9 w- L0 x* r. M, S1 D9 S! t2 J* B  8, 0.117187500, 0.125000000, 0.121093750,-1843.759437944,
2 X/ G: R6 Y: ^5 m8 L5 P2 i  9, 0.117187500, 0.121093750, 0.119140625,-703.184646645,3 f0 A- ^& q: c$ C7 h  y
10, 0.117187500, 0.119140625, 0.118164063,-135.633470273,* C9 k: Q7 ?$ B+ j* Y6 x" s
11, 0.117187500, 0.118164063, 0.117675781,147.457778641,1 E. }, h- n7 ]# }# Y! N
12, 0.117675781, 0.118164063, 0.117919922,5.969190901,
: A  R% u. M" s+ A 13, 0.117919922, 0.118164063, 0.118041992,-64.817881139,
4 T$ \& _/ s. z, p# o% _/ Y 14, 0.117919922, 0.118041992, 0.117980957,-29.420780403,4 I, v+ S1 |$ o$ i) J
15, 0.117919922, 0.117980957, 0.117950439,-11.724903562,0 [9 ^: y8 b2 ]' A" H$ R
16, 0.117919922, 0.117950439, 0.117935181,-2.877633532,
9 y9 o# n# ^5 {2 R( T 17, 0.117919922, 0.117935181, 0.117927551,1.545834384,4 L+ P, I! R  j( H- c+ C
18, 0.117927551, 0.117935181, 0.117931366,-0.665885649,& |: S- \" P% s- ^! J/ H: o. Y
19, 0.117927551, 0.117931366, 0.117929459,0.439977849,+ S8 p6 g, r  ?: ~
20, 0.117929459, 0.117931366, 0.117930412,-0.112953030,
  A$ y& s# Y$ |! G% w0 c2 s 21, 0.117929459, 0.117930412, 0.117929935,0.163512627,
- a6 K  }% Q- K 22, 0.117929935, 0.117930412, 0.117930174,0.025279853,
4 ~- K2 {" l' s6 h 23, 0.117930174, 0.117930412, 0.117930293,-0.043836575,- H6 ]7 C/ z4 t
24, 0.117930174, 0.117930293, 0.117930233,-0.009278357,
& W$ T- B. u+ P6 z 25, 0.117930174, 0.117930233, 0.117930204,0.008000749,
/ s! O& H# D3 n: p0 B! j 26, 0.117930204, 0.117930233, 0.117930219,-0.000638804,
/ d3 G, L7 R* O) O; R" r* b+ T 27, 0.117930204, 0.117930219, 0.117930211,0.003680972,
8 F2 _- G3 W3 @4 [. K; k% k5 I>>
; W. Y/ x; c; X# m& I7 n  w* p( _
2 i& y9 \9 O& U" O! Q; S9 [结论 当x=-1.361时  y=0.1179302195 y! X& P( j# A9 s8 N  |4 f/ @( p" e
按此方法   可依次  得出150对x与y的值
6 \' B! E! @& r: B3 F
发表于 2015-6-4 12:41:51 | 显示全部楼层
西交大学生??问邢老师
发表于 2015-6-4 19:12:53 | 显示全部楼层
你这个是代数方程?
发表于 2015-6-4 19:45:16 | 显示全部楼层
算法?
二分法 还有一个程序 % Bisection.m function[k,x,f_value]=Bisection(f,a,b,eps1,eps2,N) fprintf('k ,a ,b ,x, f\n') for k=1:N x=(a+b)/2; f_value=f(x); fprintf( '%3d, %10.9f, %10.9   发表于 2015-6-5 08:36
 楼主| 发表于 2015-6-5 08:37:59 | 显示全部楼层
cosxuan 发表于 2015-6-4 19:45 ) V2 U) I" l  ?
算法?
5 o7 X2 u6 Y" w3 z/ h4 b
二分法        7 o5 `) b% M! P" h' d+ w
还有一个程序) [* ]4 {6 r4 q
% Bisection.m7 x8 H. A( e! v% U; I
function[k,x,f_value]=Bisection(f,a,b,eps1,eps2,N)) ~3 j( m# x' s
3 L' ~* u; @, ^- U7 _8 e7 y& hfor k=1:N8 u: J. `, _* y2 x& f+ c/ \3 k: D
    x=(a+b)/2;1 ~9 a# i4 @  B
    f_value=f(x);
& x5 B. I4 `3 n( w8 R    fprintf( '%3d, %10.9f, %10.9f, %10.9f,%10.9f,\n'...
1 U6 A) a& n: r      ,k ,a ,b ,x, f_value)" V0 ?+ A: c" g' {' P
    if abs(f_value)< eps1||0.5*(b-a)<eps2( [" p8 B  Y; |8 S. n
    return
' M8 P8 S2 A- d5 o, k2 Z8 [    else4 g6 d5 h% J/ B* e, e" H# W* w
        if f(x)*f(a)<0/ }. @" k" G8 T8 {" X4 P$ L, {4 ~
          b=x;
; V/ C4 @) k1 s( D. h        else
& Z4 R) R8 |2 b) k          a=x;
0 z$ z+ H+ R& d: X        end
+ B9 y6 e3 f; Z. b        if k== N
6 I/ A4 I0 G! W  H          warning ('算法超出最大迭代数!')     O  T7 }5 V& Q* m
        end* [- x4 V/ R' }' i9 s
    end
- S) Y; L* N8 ]; x7 X% l4 R: ?+ O5 P
 楼主| 发表于 2015-6-5 08:40:05 | 显示全部楼层
单车居士 发表于 2015-6-4 12:41
  W! H9 J9 c: p西交大学生??问邢老师
7 z" E1 Q" L5 {: \- _9 G这点问题   自己就可以解决
5 Q  `) l9 t. f  |. W. x1 g8 ]
 楼主| 发表于 2015-6-5 08:46:07 | 显示全部楼层
明月山河 发表于 2015-6-4 19:12
# F" q9 ]( t, }# S0 F( y# R你这个是代数方程?
5 Z$ \" L" ?. D2 e+ ~
是的呀      不过matlab写出来的方程  括号很多  不好看
4 L+ Z! @& j; G! J" [0 o5 G% G  F$ O2 `! \. B3 U
 楼主| 发表于 2015-6-6 18:55:35 | 显示全部楼层
( S) J$ L; O! B; W你这个是代数方程?
" M# B. A. y+ H  _
% S: j- B5 f  p' V- n' [是超越方程
6 U/ n6 T3 B% G
9 _/ d6 p' K! R3 q7 m# K# }: w  ]( z4 S8 K" r- K6 s7 j3 K+ H
[chāo yuè fāng chéng
1 y6 g* z: A- `7 }# l3 t
用数值方法,超越和代数差别不大。  发表于 2015-6-8 08:35
发表于 2015-6-6 20:19:50 来自手机 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-9-18 19:16 , Processed in 0.068018 second(s), 20 queries , Gzip On.
