发表于 2015-7-29 09:29:46
显示全部楼层
machined by threaded9 ]( l: b8 i/ F4 w* q) H
螺纹加工方式: T: O% y T/ m* [
value prior to threading
) ]% M: M$ X/ g7 b- M3 M1 K0 o' J攻螺纹之前的尺寸
2 X) B3 R( ?, q. V0 x V* Punless otherwise specified all dimensions are in inches and
. Q4 _. {& `( [' ~除了特殊要求外,全部尺寸为英寸单位
9 L0 B9 d) q/ G& T* T6 E1.overall length is minimum and longer needed to meet customer requirements are always allowed wothout 5 x4 J7 R6 S7 x/ d! [
. w8 A/ g) b" w, U9 ^, |
engingeering approval( P" A& B$ `5 \9 [' g/ N7 J
总体长度尺寸为最小,若按照客户要求增长是被允许的,也不需要工程师批准
- p' z5 b% _# I$ t& x: V2.machined surfaces 250 rms max,thd surfaces 125 rms max $ `" a. z6 F7 I) f7 W0 |9 G) x
机加工表面粗糙度为250 rms(Ra6.3),螺纹表面粗糙度125rms(Ra 3.2). r" z- Y, B: I+ E5 g7 j" ^
3.inside raoius 0.03-0.06 in.
# ]1 ?: p$ K" _/ M3 g1 D 内部半径为0.8-1.5,1.5为最大
' W* f3 S; w3 k% w7 Y9 d4.corner breaks 0.015X45 in.
X' O0 E7 g# a' f, j 棱边倒角0.4X45
% w* Y+ B7 o$ E& c. `5.concentricity between 2 mach.surf.within 0.015 t.i.r/ t) }' g, V; ~
两机器的同心度误差量在0.4内- o: s n9 l$ A2 T% s& v' H+ e( J
6.normality,squareness,parallelism of machined surfaces .005per inch to a max.of.03 for a single surface. a( r" ?! N* |* _7 {5 D5 F, ~
一般的,机加工表面的垂直度和平行度.005/1 ,对单个表面.030/1 MAX
6 q+ ^( y9 o5 O7.all thread entry&exit angles to be 25-45 off of thread axis1 m* k. o; |0 s& `; z4 ?
所有螺纹的起始和脱离角都是与螺纹中心轴夹角范围为25-45 deg& U$ g! K' ]' W
