# j* T$ }9 @0 I. [1 o: S! c8 I- B+ n) L4 [
如图,这是温水洗净坐便器(就是前一段很火的好多去日本买的那个)冲洗压力测试的JIS标准,原文如下
# ~: t+ e; Q) J' b! l; F6 x0 V" Y9 m2 z4 O& X; T* [
性能要求:- z8 p2 c2 P7 D' e# L& `5 o
6.1.3 Rear washing force8 J' F7 {! E. K/ W7 g. H" I) l8 t
The rear washing force shall be such that the total pressure receiving area by washing water is 0.06 N or over, and the washed area is 80 mm2 or over when tested in accordancewith 9.3.3.; B: {. ?: F2 {2 L
{ `2 Q+ l2 f测试方法
% J' q3 _" w: E9.3.3 Rear washing power" A" ?3 J4 U7 ^. H2 h9 T) U( l3 Y
The rear washing force measurement shall be as follows:
7 C% G# g# s7 Ja) Set the washing water temperature and quantity control both to the maximum. Operate washing for 30 s. Measure the total receiving pressure of the washing water at the flood level toilet rim for any 2 s using equipment as shown in Figure 1, and then,' W# Q m3 m0 S% |8 \
as shown in Figure 2, read the maximum value and the minimum value of the pressure load, The mean value of the two is read as the centre value. The pressure receiving board shall be circular and have sufficient area for receiving the whole washing water.0 W) U2 }$ U2 m3 H
) i" ^' n) M7 W1 U' } @' L
求助问题:测试中用到的压力测量传感器用哪种规格适合? |
