It's probably true to say that when you think of SolidWorks 3D CAD software you think of mechanical design of pumps, valves, machinery, processing products, conveyor belts etc. You don't always associate it with the design of furniture, display stands, shop fittings and other fixtures and fittings. But G-Plan Upholstery, Ercol Furniture, Athena Kitchens and Howdens Joinery are all examples of companies using SolidWorks to design their products. SolidWorks Professional for Woodworking adds significant benefits when designing your products in 3D. Here is what just three of our customers say about using SolidWorks for furniture design: "Easier product visualisation, improved component and assembly accuracy, ability to identify and use similar/modular components, reduced design and build time." G-Plan Upholstery "The key benefits for our clients are: easy and precise design review/sign off; superior build quality; dramatic build-time reductions, on-time completion and tight budget controls." Panaloc "As a result of using SolidWorks Zoeftig can now run and change design ideas very quickly. We are capable of producing three designs in the time it took to produce one." Zoeftig Come along and see for yourself just why these companies have chosen SoldiWorks and how it will benefit you too7 V- H+ u* g( x) q2 s+ I- j; P1 r" f
4 z- G( R6 U6 w, q
当提到solidworks时,一般只会想到机械设计,不会联想到家具设计,装修设计,店铺展示设计。不过,G-Plan Upholstery, Ercol Furniture, Athena Kitchens and Howdens Joinery 这三家却是应用solidworks作家具设计的。solidworks的专业木工设计带来了明显的好处,,G-Plan Upholstery说“solidworks带来了更简单的产品可视化,提高了部件和装配精度,能够识别和使用类似/模块化组件,降低了设计和建造时间” Panaloc“作为使用SolidWorks 现在可以运行并更改设计思想非常快的结果。
0 ]5 ?' {# ~9 K2 N, v- d7 f
' b# [8 ]# S. ^$ d$ J |
