[p=160, null, left]美国
, F, q1 Y9 A+ L$ I8 O! X9 T[p=160, null, left]ASTM
8 m7 u* f1 D7 _' w; v5 L2 J% ^[p=160, null, left]无损检测标准目录( d, O3 A: | s. q) C9 h9 l4 j0 ]
y/ W5 o" l: X+ R$ w, e" ]
[p=170, null, left]ASTM
/ G1 @: J1 E; E" V[p=170, null, left]Volume 03.03, October 2005
- K2 p. v4 n& I8 d( T! m4 ]4 x[p=170, null, left]Nondestructive Testing ! I) T- _2 r0 W; ~4 N
4 ?' z& Y9 D$ V% z
[p=170, null, left]Table of Contents
# b+ ?$ o3 A0 `3 Y7 R
" M# k% R* ?) ~( Y# S/ D& a[p=170, null, left]2005
! d$ d% ^1 V6 h4 \1 g[p=170, null, left]年版- s2 f0 U8 u" @
[p=170, null, left]ASTM$ G4 d) x F ^
[p=170, null, left]标准年鉴
- | Q' D9 Y: ^& ^) w9 O6 R[p=170, null, left]03.03$ T4 S, F/ N; W3 ~2 Y" |
[p=170, null, left]卷无损检测标准目录
( U8 |; F5 k8 l6 f: ^5 S1 {+ s
. b1 x: Y% O0 o6 i6 A) M) m0 _[p=170, null, left]E0094-04 ! [7 s" o, J' C" x5 T& g" C
[p=170, null, left]Guide for Radiographic Examination 4 p8 k- p s. t5 H) U( C: |
[p=160, null, left]射线照相检测指南
9 X- @. w5 _0 w
{: ^! H( b; m' I& K* f# h[p=170, null, left]E0114-95R01 ' c! d5 Y( B/ T% [5 W% H( M
[p=170, null, left]Practice for Ultrasonic Pulse-Echo Straight-Beam Examination by the Contact Method
$ I6 r' c! Y% d' u7 e2 l[p=160, null, left]接触式超声脉冲回波直射检测方法
& e f4 h" A3 ?9 z
1 g0 u" C' W$ m1 E) {[p=170, null, left]E0125-63R03
9 V: b$ r; I2 A4 s2 I9 d[p=170, null, left]Reference Photographs for Magnetic Particle Indications on Ferrous Castings
4 z2 U: B; n) u& l7 f/ w[p=160, null, left]铸铁磁粉显示参考照片
0 E- u" U4 }- _& o" y8 V; w8 G: M5 c/ Q; C: W* h$ U2 l# y
[p=170, null, left]E0127-05 Z; }8 |1 a( o5 A5 h
[p=170, null, left]Practice for Fabricating and Checking Aluminum Alloy Ultrasonic Standard Reference Blocks
& i8 s- P2 }6 ]9 J8 |+ i4 B[p=160, null, left]铝合金超声参考试块制作和校验方法
4 t& j" ]7 _% z1 m7 a6 {1 ]5 _) u( ?
[p=170, null, left]E0155-00R05E01 3 Z* v/ C# ^8 j/ R1 ?6 r! m
[p=170, null, left]Reference Radiographs for Inspection of Aluminum and Magnesium Castings
# X- G* I7 S6 r: Z, s+ u[p=160, null, left]铝和镁铸件检测参考射线照相底片 D: [9 o7 Q- r2 m
" S( `$ n' h/ \$ Q2 O
[p=170, null, left]E0164-03 + K6 s5 ]3 Y- v( q4 ~
[p=170, null, left]Practice for Ultrasonic Contact Examination of Weldments
/ T' L. E9 J0 z+ Y1 I[p=160, null, left]焊接件接触式超声检测方法
- U# E- Y+ K0 z- o; |0 f3 M5 h+ L1 ?; L/ U6 }3 E$ K
[p=170, null, left]E0165-02
) w, T) b, y2 C" ?$ s[p=170, null, left]Test Method for Liquid Penetrant Examination
5 b( S. C; Z6 Z" T1 x0 p$ Z[p=160, null, left]渗透检测方法指南6 M+ o* B" z& c `$ U
; W4 m- a" h9 I' L$ `, \: U
[p=170, null, left]E0186-98R04E01
0 r, ^; c; i1 r/ |( }7 g4 v {[p=170, null, left]Reference Radiographs for Heavy-Walled (2 to 4-in. \[51 to 114-mm\])) Steel Castings
- z- ]! x' P; o4 x# D4 x[p=160, null, left]大厚度(! h7 ]1 f2 P+ B' Y* M1 W( q
[p=160, null, left]2
' P$ m5 E5 C" V: N6 S* d1 Q. m0 l[p=160, null, left]~
' V+ ?- K8 Z2 J' N[p=160, null, left]4in \* G( l" n. z
[p=160, null, left],即- x% h0 T! J% O7 ^1 Q! m
[p=160, null, left]518 \# V) {$ f/ ?. o1 T7 e% k4 E; m
[p=160, null, left]~7 d3 K: R/ X( A. a' }2 K
[p=160, null, left]114mm
0 ~ X5 c9 J& @6 E( N0 Q+ n[p=160, null, left])铸钢件参考射线照相底片
p, f, l8 L2 C% H# _$ p, ^, ~# F$ l# o5 E5 L# m! x
[p=170, null, left]E0192-04 ( Z& I* b: l, B- v
[p=170, null, left]Reference Radiographs of Investment Steel Castings for Aerospace Applications 0 \6 V6 {% R2 m
[p=160, null, left]宇航用熔模铸钢件参考射线照相底片! U) [+ j# f0 ]8 y" s$ v n- Y
' e. W8 G. c& A2 w9 T
