查看: 2875|回复: 4
请问 non-factorizing 是啥意思?
发表于 2014-12-29 19:58:26 | 显示全部楼层 |阅读模式
比如17和69没有公约数(1除外),就叫 non-factorizing.  8 F8 W' r7 g6 k. ^
难道是无公约数的意思?请大侠指正!谢谢!
发表于 2014-12-30 03:23:47 | 显示全部楼层
应该是类似于 无法分解1 R8 v9 J: }4 `& h: t  ]* x. K9 S
根据维基百科,factorizing 意思类似于因式分解(比此含义广一些):In mathematics, factorization (also factorisation in some forms of British English) or factoring is the decomposition of an object (for example, a number, a polynomial, or a matrix) into a product of other objects, or factors, which when multiplied together give the original. For example, the number 15 factors into primes as 3 × 5, and the polynomial x2 − 4 factors as (x − 2)(x + 2).1 w8 e( D( h! V( a
 楼主| 发表于 2014-12-30 10:26:51 | 显示全部楼层
一点一点来 发表于 2014-12-30 03:23
$ D" l9 g7 \+ x( z, L" T应该是类似于 无法分解6 ^2 ~' a5 M+ M4 P6 P
根据维基百科,factorizing 意思类似于因式分解(比此含义广一些):In mathematic ...
: Y: \& C7 T# y* @
谢谢!我理解如下:" J2 e: g+ F& ~5 q
Like 35 and 19 can not be factorized, which means non-factorizing.
) N+ f7 @: m8 u5 v$ T4 KFor 38 and 74 can be factorized into 2*19 and 2*37, which means factorizing.. |9 @# Z4 k, z6 G' `8 Y
) w8 J8 a0 ^( r+ E! K- _
发表于 2014-12-30 18:25:53 | 显示全部楼层
qdtruck 发表于 2014-12-30 10:26
: U' I5 T$ S0 x; F, Q8 ~4 t谢谢!我理解如下:
6 [2 e8 B5 L. W% ]4 u7 t% _" PLike 35 and 19 can not be factorized, which means non-factorizing.2 Y/ `# H: r6 D5 a( ~
For 38 and ...
1 u6 U/ p$ W; ]# g" q* W
你理解的没错,但是它除了你理解的,还有例如不能因式分解的意思
发表于 2015-1-8 10:29:27 | 显示全部楼层
因子的意思
GMT+8, 2025-9-20 02:24 , Processed in 0.077371 second(s), 17 queries , Gzip On.
