最近看一本英文的工具维修手册,里面用到一种TO组合密封,相关介绍如下: / ?: G6 Q- B7 X
* q, T3 Z: I" w; G; \$ YWhen I read a R&M Manual, I read the folling text....
1. set O-rings into groove of piston 2. heat up TO-seals in oven to 150 dc 3. take TO-seals out of oven,use high temperature resistant working gloves,stretch TO-Seals carefully and evenly and slide over piston. 4. insert piston into reform sleeve,set mounting bolt at top piston,put all into hand leverage press and push piston in. Leave TO-seal at teh smallest diameter of the reform sleeve for approximately ca.60 sec,then push piston through. .....
I am a mechanical design engineer,I know O-ring, T-ring ect, but I don't know what is TO-seal. So could you can give any information about TO-seal. 1. What is TO-seal? 2. Where I can get more about TO-seal? 3. What is the special funtion of the TO-seal? 4. Why use the oven heat up the TO-seals?
$ _: r$ @* |% g; r, k
不知道有没有国内的同行用过这种密封,很奇怪的,要先将TO圈加热,然后用成型套成型. 8 {, n" J+ ?' v& I' R
什么场合需要这种密封?这样密封的目的是什么?
- E \- D4 G# I) ~哪里有这样的TO密封件厂家? 9 D$ [0 M) S0 d3 o" G# {/ h) ?2 o
