查看: 4404|回复: 3
要买批钢材,型号是日本标准,如何转换成我国标准?---[求助]
发表于 2007-4-20 11:04:16 | 显示全部楼层 |阅读模式
1 E1 c" g2 q5 M' n4 J; s( O7 a0 j1 R$ x% r6 i: z3 u. ~8 y6 j: E5 g9 a$ _+ I0 B Q& ~- R. J! z' t7 O! b+ h5 Q3 K0 J# {9 B0 g$ K9 E7 E) T& H2 x4 g. H" v2 [! [1 A- [- }3 Z; F5 g6 o+ |1 [0 A) g& Y9 I" _+ Y) ]6 j+ R5 Z' ]& P/ J& W) f' |# w4 k* y7 j0 a* H+ J$ }6 q1 t2 |% ]. o9 `, v; c0 j' C, G" P0 ~) |! u7 V5 f: I9 \! i9 W' l' [5 [- B# D" y8 W3 A8 ^/ Q" O9 K2 A) s. s- F& v* t4 T# W; m e+ |. I& C( U" y4 x. p3 [# e9 D- z1 O# I9 c( \; K7 {" c3 \. M4 ], \/ l! S- R8 ~9 i6 ?# R6 x6 B' `+ ?5 `# P* z6 n+ V* }4 _; ~% E8 f2 Q y+ p# |- Z% Z# s, r& Z: R: S- k1 w& n- d% \( B7 p& U+ H+ m7 U: [7 Z+ M3 _ v( K9 x) C3 d: {* H! Y" H8 ~/ [5 `' E2 e0 `; X7 B/ \. c2 e& ?% x. i$ E4 ^3 `# v% H/ w2 h- H2 n9 @6 [* r0 @2 ], }; B; ^. T4 |" F0 [; x, ^' j. y$ X( @& z# W6 d0 t# w+ E6 _$ ?; o' D9 q) e! V ~6 H- H7 j" |; ~. D, G$ t4 U6 e$ S' G# v4 U0 b0 P5 r6 X: [+ h" e. e( Q6 l5 J4 `5 t- H5 U& z" d9 x0 A3 |5 x8 w3 l3 ?- p7 ], G2 z3 n3 M# K8 Z* J* |/ m% b4 k2 f+ ]8 \ D& g" S+ i; c/ |0 u. s+ [ U2 d, `1 p/ T# j) z8 a' n6 Y2 h' F$ g6 M& B+ N& ^" G0 |& j- D) e9 z& T% a5 z Z0 U" c, {6 ^3 |' q F3 g% K) |2 u, _. [6 \4 |6 x' g$ c; N, ~% l7 d1 H3 K+ C3 [- G' p& q( F: k" S) Z5 o3 G! x) E; ^& z; J: {" ^: n2 U: I% q6 F2 b4 w* @5 O% k1 C+ [7 r/ m) s7 y; O/ f. d4 W5 q$ E9 `% z3 c# [7 o" ~ ?+ [. U7 M$ E7 f/ ?5 X1 l* |4 _0 ?" n: }1 u' j+ j% o0 Y- ?7 f5 E' ?3 R4 i+ P' ^7 {7 {. R4 B/ e6 p4 h2 i* f( k) U$ y/ ^1 h0 Z6 L* j4 e% Z5 I% P& L1 g: q, Z# c, g k# w& a" s4 _* I3 U6 P, g/ W! x1 @$ q) D- A' b2 j6 q3 Z1 p( H7 t' J4 Q9 d" e: A$ g9 ]5 a( t9 l( A h& @" Y7 R* j; i& y- q+ B- A: h% b8 ?% I8 R9 ^0 D6 x4 a; @) |4 I' M2 F5 x8 L4 Z) N H" h& r y7 l3 `* o1 r; d# t9 O1 a0 k) Z; b6 f. {1 _! T6 [( S6 o" W5 E7 E& v0 F: f# V3 P7 x( W2 Y7 {7 @( M K* v& t) c. R* Z5 i3 H: i/ U" r! k* q. K, i% ~- a6 V7 |# ~6 T- A/ {; O5 o4 e9 j! f* f% R4 d0 \# S1 v6 B: N7 A; _. {2 ^) r' r5 B. d% @# k" d% @+ X) ]" I$ U7 r' M3 ?4 t7 g1 A3 y5 Z5 l8 z0 T2 L3 w2 K8 [- `2 \: ~2 B: z; C! W) Y& r3 z8 z% k" J7 \/ x" Q; J; N1 w+ _; k9 @8 v1 O: T( Q8 J; h4 Q/ s# q4 O9 @# M4 V2 c; J( r2 P! D6 o; g1 c M; Z# Y" }1 C/ _# E: z7 Z9 f1 \, r/ K/ I% G1 F/ o4 d+ F' t. A6 k5 |9 q. Q2 i& g) ^7 J$ F8 ]6 A1 n1 H1 }4 g; r9 j6 `& W% f+ v+ _. q* c2 n E! J. ~: a1 D1 X" R# B7 |" _, L. _' m& U& X1 w# f) l- I [! l! y$ ~! k( }* }; m& |9 i8 E4 u" h3 x- w* G( q* E! E# d9 ?7 [' t; _/ g5 Y# m' h! ?6 ?9 V. g7 O% P# A9 q* h" l( O2 \1 L6 e) u" ^0 r5 R3 j T. Z% `! A& e4 E) ?; j' a* S/ Z$ \' k( B- B2 X9 {& p6 d3 x: T$ S5 X; B& i. O! Y7 }1 r+ B1 f0 a8 W2 S5 i" Z& ] T5 Z; n3 J2 N) E9 e! z7 H0 m' i( e8 O2 J' {- z, C! p* ~& {& x5 Y$ }+ T3 P( _' j9 V; p) a6 Y+ r I- |) g- k' B2 V" ~& a- q; W: {' {$ e1 h$ o ^( O4 e. w* \/ H4 P7 c, v' f/ T8 B" i* P# N. G1 i( r( R% X: n9 p8 v7 K& ]4 S- F4 E, r) w3 q2 |8 S2 R8 C$ d! Z5 p* c* ], a/ l0 O3 P' E5 i8 t6 a; p5 _; _1 Z3 c4 W, O4 d& w. D. ~6 T, q6 @* K# |0 i7 C7 P8 |) ]# l; i9 A: J6 e/ ^8 E- k( v% S& k _" T7 y* ^0 D, x6 V2 U1 @2 s3 X8 v# k1 V- B8 Q7 a7 \5 L5 h7 M f" c" e# ^' j) Z. d; t# K0 f9 y1 p. j" Q% `7 v% i- J# ]6 ?0 w2 ^8 _" l, [7 D
" @' A+ o' u* k" [
各位大师,请帮帮忙,很急啊,谢谢了
5 Y5 t3 i% Y) y' N
名称    材质
0 m, ]" b# A$ \- @ [) p4 L
U-BOLT.NUT
8 R4 N: j, f( _4 H) q0 L6 v0 P' q
( k# H7 H) ?, j/ q% _$ T- x& k
0 f" `# }, u- s. k
SS400
PIPE SGP
SGP(w)
plate SS400
BLIND PLATE SS400
union fcmb(w)
fcmb
nipple fcmb(w)
reducing nipple fcmb
fcmb(w)
90oscrew elbow fcmb(w)
90oscrewED elbow fcmb
WELD TEE FSGP
SGP(w)
WELD ELBOW FSGP
45o WELD ELBOW SGP
BUSH fcmb
ANCHOR BLOCK S25C
TUBE BAND
HOSE BAND
PLUG CUP
UNION FITTING CUP
elbow fitting CUP
TUBE fitting CUP
COPER TUBE CUP
REDUCER SGP
BLIND FLANGE SS400
 FLANGE SS400
SCREWED REDUCING TEE FCMB
SCREWED  TEE FCMB
SOCKET  SGP
reducing socket FCMB(w)
WELD REDUCING TEE SGP
REDUCING TEE SGP
GASKET T/#1995
HOLE IN BOLT.NUT MARKET
HEX.SOCKET BOLT SCM435
HEX. BOLT.NUT SS400
5oTAPER WASHER SS400
MALE CONNECTOR 4 p" J5 g% u( t! z# z5 ]' o
发表于 2007-4-23 17:45:13 | 显示全部楼层
Re: 要买批钢材,型号是日本标准,如何转换成我国标准?---[求助]
自己查资料就是了。谁能代劳这个呢。
 楼主| 发表于 2007-4-25 08:42:36 | 显示全部楼层
我查了啊,可是有好多不同的答案
发表于 2007-4-29 21:22:21 | 显示全部楼层
SS400  国标Q235
GMT+8, 2024-11-27 13:49 , Processed in 0.052957 second(s), 16 queries , Gzip On.
